Contact your local technician and specialist of the company in which you bought this product. Check out their FAQ page and help page then contact them for further information. Follow this link to get started https://www.manualslib.com/manual/889218/Gibson-Room-Air-Conditioner.html
if you did not turn off the unit at the wall when you defrosted it , it is possible that it went into overload and tripped a thermal breaker or reset button
check for one and reset or call in a technician for a diagnosis and quote
Press down on the battery, which will allow it to pop up, as if you were going to remove it. Press the power "on" button. More than likely, your Min-Etune will now work fine.
Hello John - Let's try resetting the dishwasher by either
unplugging it or flipping the household circuit breaker to the off position. It
is important to wait roughly ten minutes and then turn on the unit. Confirm that the door is properly latched and
try selecting a cycle. If resetting the power does not correct the issue, it
could potentially mean a number of things: a potential wiring failure, damaged
cord, faulty door latch assembly or control board. Because it could be a number
of any one of several underlying causes, I would recommend contacting a
professional to properly diagnose and repair the unit.
Sounds like you have a bolwer motor or fuel pump that has bad bearings, as it runs, it starts to bind up, and get to the point where it is pulling to much juice to turn it, and the fuse does it's job and blows?
If you could give be a bit more detail, I can help you furthur.
Please rate the new guy :)
And get back to me, so we can get the problem fixed for you.
Lets get this fixed.
Sincerely,
Paul Gibson
You need to call a reputable service technician. The freezing up usually is associated with a low refrigerant charge or low air flow. Check your return air filter and replace as needed.
Nothing...Maytag SUCKS!! I have the same problem and Maytag says it could take months before they get new parts to fix the faulty control panel. My unit never shuts off. Only way to turn it off is by unplugging it out of my wall socket and it has already caused my living room electrical socket to blow out. I will never buy Maytag again.
