Question about Apple iPod MA446LL/A MP3 Player
I have a ipod video 80g and it will not put out sound when i plug it into a stereo with a audio cable and it wont play thru my car stereo thru the aux port.can you help me please
  • 728 Answers
Try it on regular headphones and see if it works. If it does, then you might just need a new audio cord. If it does not work, check the volume, and if it still does not work, then you will need to get the headphone jack repaired at a shop.
Posted on Jan 01, 2009
IPOD cable doesnt work on my DNX570HD
I have the same problem, did you find a solution?
Jan 10, 2014 | Kenwood DNX570HD
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
How can I view my ipod pics on my TV screen
1. OK on your iPod and click "Videos" from the main menu. Click on "Video Settings" and then switch the "TV Out" function to "On" by clicking on it.
Plug the iPod audio video cable input to the correct iPod plug-in. The cable's input varies from cable to cable but will either plug into the headphone jack or the power output.
Plug the other end of the audio video cable into the television's video output. The cable has three audio video plug-ins colored red, yellow and white. Plug them into the TV's corresponding inputs.
Turn on the television and change the input to the same one you plugged the iPod into.
Select the video you'd like to play on your iPod. The iPod's video and audio will be redirected to your television.
Jan 24, 2010 | Panasonic VIERA TH-65PV500 65 in. Plasma...
When I plug my iPod into my car stereo, it's a Kenwood KDC-W3041, sound only comes out of the speakers in one door, but when I play a CD, sound comes from speakers in both doors. What's wrong?
If your using the aux plug in the front make sure the plug is fully inserted into the ipod and the stereo. then make sure all audio settings are set correctly. If you are using any other type of connection for your ipod ensure the connection is not loose.
Dec 10, 2009 | Car Audio & Video
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
80g ipod video. screen has ipod logo and screen
hold the select and menu buttons until the apple logo shows up, then quickly switch to holding the select and play buttons, this should put it into "disk mode." plug into itunes and click restore.
Nov 16, 2009 | Apple iPod MA446LL/A MP3 Player
I have a Y-cable (dual RCA plugs one end and
you have a stereo rca plug set to a mono audio plug.
you need a stereo rca plug set to a stereo audio plug
Oct 07, 2009 | Pioneer DEH-P690UB CD Player
Jensen vw9312 wont play ipod video
This unit does not have iPod video capabilities only audio, If you want to view video from your iPod you can get a universal cable that would charge it and also give you a audio and video output, this cable needs to be powered and grounded and hooked up to one of the radio audio video inputs. This link will take you to it. http://cgi.ebay.com/ALPINE-JVC-PIONEER-SONY-Aux-Input-Cable-for-IPOD-VIDEO_W0QQitemZ370164615429QQcmdZViewItemQQptZOther_MP3_Player_Accessories?hash=item562f87c905&_trksid=p3286.c0.m14&_trkparms=66:3|65:15|39:1|240:1318|301:1|293:1|294:100
May 15, 2009 | Jensen's VM9312 Car DVD Player
Can I connect an ipod to Onkyo tx-ds595?
I connect my iPod to my Onkyo using a stereo cable with mini-plug on one end and RCA L&R outs on the other. Just plug the RCA plugs into the AUX or TAPE IN on the Onkyo, and the stereo mini plug into the iPod and play as usual.
Aug 21, 2008 | Onkyo TX-DS595 Receiver
Mp3/iPod compatible connection
hi , instade of going thru USB, just plug a stereo RC pin to the Headphone socket of the iPod and the other RC connectors to the line in of the stereo system, play the Ipod, u can now hear it from ur steroe system.let me know
Jan 02, 2008 | RCA RS2664 Shelf System
Apple iPod MA446LL/A MP3 Player Logo
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
