Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
NOT WORKING FDW20p What does it mean
Hiya people, This message is for hotpoint dish washer FDW20P Witch has stopped working The machine fills up withwater then about 10secons later it empty's then displays x2 Flashing lights (WASH & DRYING) - I HAVE LOST the booklet so i can't check what this means Anybody know.
  • Brian Green
    Brian Green Apr 21, 2007
    THIS IS GOING OUT TO ALL!!!!
    I HAVE FOUD OUT WHAT IS WRONG
    (WASH & DRYING) lights mean the temp is not high enough - aka means the heating element has gone requires a new one at a cost of £40 for the part and £90 hotpoint call out charge - but we are covered with
    http://www.domgen.com
    so it's cost £0.00
    cheers 2 every one thats looked
    raverbaby
  • siya5 Nov 17, 2008
    Dishwasher FDW20P
    WHEN TURNING ON TEH MAHINE IT JUST STAYS ON PREWASH AND NEVER GOES ONTO WASH. tHE WATER DOES NOT FILL
  • 868 Answers
Hold the start key down and it should re-set . Please Rate This ! Thanx!!
Posted on Jun 07, 2008
Washing machine wont spin
Hiya,
the 1st thing to check on this would be the drive belt most machines have an easy access point at the rear of the machine if you open this you will clearly be able to see the belt comming from the motor to the drum if it is loose or damaged this would stop the machine from spinning..
Always remember to disconnect the power before opening any apliance & a qualified enginer should be considered however this simple check could save you a call out charge & a costly repair bill
Hope this helps
Apr 22, 2010 | Hotpoint WMA30 Front Load Washer
Water fill problem on Hotpoint Dish Washer Deluxe Model DF 31
Pl check the small filter fitted near the water inlet hose. Probably you may have to pull this filter as this is housed in the threaded pipe attached to the body.
Remove the hose from the machine and try flushing. see whether you get sufficinet pressure from over-head tank!
Clean the filter with tooth brush or reverse clean. Do no for get to fit rubber washer.
Mar 30, 2010 | Hotpoint 24 in. DF55 Free-standing...
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
On a hotpoint aqualtis aqxx149pm i get error code f8 flashing
Hi.
F8 means that heater relay cannot be activated, you need to call an engineer.
Could be expensive, possibly a new control board needed
Nov 19, 2008 | Hotpoint WMA35 Front Load Washer
Hotpoint first edition few12 wont fill
hiya
if your machine wont fill it will more than likely be a faulty inlet valve.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Jul 07, 2008 | Hotpoint First Edition FEW12 Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
FDW20P Error lights.
Hiya, i have the same problem. I am getting mine repaired on the 16th Next monday Booked an appointment with Hotpoint there coming to see and fix it. I will ask about the flashing lights and if you keep in contact i will let you know Ok"
Sep 20, 2006 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
440 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
