Question about Westinghouse Remote Fan Speed Control
Westinghouse 77870, ceiling fan remote.
Trying to install this remote,, instructions say,, do not use the dip switch settings from factory,, use your own,, but there is no explination as to how..like what are they for,,I know you have to do the remote hand held and transmitter the same,,but ,,says simply to use your own settings,, with no further explination as to what they control or do..Thanx.
  • Bobby Slagle
    Bobby Slagle Apr 11, 2007
    I threw away the instructions, created my own, works fine now,, Fan and remote under $200 at Ace Hardware.(In Honduras)
  • 5 Answers
SOURCE: Westinghouse ceiling fan with 3 lights ( not sure of model)
maybe a bad remote module in the fan
Posted on Aug 14, 2008
joshuakuan19
  • 48 Answers
Try "oiling the fan" and also if that doesn't work, change the fan.
Posted on Sep 06, 2008
SOURCE: westinghouse universal ceiling fan & light remote control #77870
make sure that you have the power cord on the fan in the right position. Pull it once to see if that starts the motor. Then go back to your remote and try starting the fan from the remote.
Posted on Oct 05, 2008
miguel1017
SOURCE: trying to replace 3 speed
Hi
The pull switch has 4 wires, L, 1, 2, 3.
Connect ' L' to the reverse switch red wire or the wire that is free.
Connect ' 3 ' to the main black ( hot ) wire entering the fan.
Connect ' 1 ' to the capacitor's lowest uF eg. ( 1.5 uF )
Connect ' 2 ' to the capacitor's next uF eg. ( 3 uF )
the Capaciotr also has to be connected to the neutral wire entering the fan, usually black attached to another color wire. If you have a VOM tester, veryfy that it is a neutral wire.
Regards
H. Montero
Posted on Apr 17, 2009
SOURCE: trying to install a westinghouse ceiling fan into
NO NO NO..... Blue is Neutral...
BLACK is PHASE, BROWN is PHASE, RED is PHASE
WHITE is NEUTRAL, BLUE is NEUTRAL
Green, Green/Yellow is EARTH
Posted on Feb 21, 2010
How do I get the remote to work fan and light
There are dip switches in the fan and in the remote that need to be set to the same numbers. You can set them to whatever you want, as long as they match. If these numbers don't match it won't control your fan.
Here's a few lines from the user manual:
"IMPORTANT! Before installing this control, check the factory dip switch settings. Refer to Figure 1. Be sure the dip switch positions of the transmitter and the receiver match, or the ceiling fan will not function."
Here's a link to the PDF manual, which has an explanation and a figure in the middle of where you can locate these dip switches on the transmitter and the receiver both.
http://www.hunterfan.com/uploadedFiles/Support/Downloads/41316.pdf
Jun 24, 2014 | Hunter 27185 Remote Control
Harbor breeze ceiling fans
There should be a setting inside the fan housing..there are usually a 3 position tab.. move one fan to a different position and corresponding remote...
Aug 29, 2017 | Hunter 27185 Remote Control
Hunter Ceiling fan remote is operating all the other ceiling fans as well
Sounds like all the dip switches are set to factory still. Easy enough to fix.
Slide open the battery compartment on the back of the remote control and remove the fan's canopy against the ceiling. Then just change the switch to a different setting but make sure that the remote and fan have the same setting. Repeat this in each room so that all the fans have a different setting to each other.
Hope this makes sense.
Aug 02, 2012 | Hunter 52" Ceiling Fan With Light And...
I have a Westinghouse 77870 remote control with a light problem
read your intruc. manual and proceed according. download from www.fitness.manualsonline.com or www. retrevo.com
However you retight the spring contacts with pliers for better contacts batteries. 2) Open the re.control and clean the keypads for dirty, oxide with special spray contacts. 3) If the problem persist go to the repair shop TV for fix it.
God bless you
Jul 06, 2012 | Westinghouse 77870 Remote Control
How do I change the frequency on the remote and the ceiling fan? We are on the same frequency as our neighbour.
You'll need to find the dip switches. The dip switch for the remote is inside the battery compartment. You usually have to remove the batteries to see it. The dip switch for the fan is usually on top of the motor. It can also be inside the switch housing or the ceiling canopy. You can set the switches to any combinationan as lonf as they are the same for both.
Jan 02, 2011 | Westinghouse Electric Ceiling Fan 3-way...
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
Need code for remote to ceiling fan
There is no set code from the factory; usually all the dip switches are in the same direction. In order to find the code, you will have to take the fan down, pull the remote out far enough to observe the dip switches, and then set them the same way on the remote.
May 19, 2009 | Hampton Bay 13087 70450 Carousel II...
Two ceiling fans, both remotes control the same fan
Most likely the dip switches on the remote receivers don't match (on the second fan, the one that doesn't work). While the remote dip swithes on both remotes match the working fan. You can simply reset the dip switches on the second fan receiver to match the one working remote, i.e. you don't need to have a second remote, one can work both fans as long as the codes (dip switches match). If you want you can make all the remotes the same, that way you have two remotes, or if you want them independent each remote and remote receiver must have unique codes (dip switch settings).
Nov 30, 2008 | Universal Remote Control Hampton Bay...
Westinghouse universal ceiling fan & light remote control #77870
Oct 20, 2007 | Westinghouse 16093 Remote Control
Dryers Logo
99 people viewed this question
Top Westinghouse Dryers Experts
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Westinghouse Dryer Expert? Answer questions, earn points and help others
