Question about Getac W130 PC Notebook
GETAC W130 Remove Hard drive
Have battery removed ETC started with screw removal, Including rear facing hinge cover mounts.
Unable to proceed!! Not sure what would be next DUE TO COMPOSITE MATERIAL USED ALL METAL CONSTRUCTION.
?? Should I place Flat screw driver under Front low panel ?? Panel where power button is located?? I looked for STANDARD?? Under keyboard entrance Points None visible??
Looked for manual everywhere I could think of. Support via web site ETC etc.
I need to get to hard drive for data recover and repair OS. This model does not have a CD onboard .
  • tnjaybird Jan 13, 2009
    Im in need of an ac adapter for the Getac W130 as well as a hard
    drive caddy or connector and battery and battery cover i just bought what was supposed to be the right adapter but it didnt fit and now they want to know the tip size ?? tnjaybird@hotmail.com
  • ohlipp May 22, 2009
    I got the same unit without the harddrive caddy but I only need a ribbon cable for hardrive that goes to mbo. Any help?
    Problem Solver:
  • 11 Answers
Hope I'm not too late.
You can access the hard drive by removing the bottom panel.
You need to first remove the battery cover, battery spacer, and then the two screws in the battery compartment.
Then remove all the large screws on the bottom plate.
Don't remove the little ones that hold the rubber port flaps, just open each flap so it won't get hung up on them.
Then take a flatblade like a mechanics size and insert it in the slot at the top edge just inside from the corners. They will be at the handle end of the laptop.
What you do is stand the laptop up on end.
Insert the blade at an angle while holding the handle in the other hand.
Lift the screwdriver handle upwards so that the blade grips downwards and lifts the bottom off the laptop. The slots I mentioned are not so obvious, but think of them as access holes and the bottom plate is wedged into the case like a can of sardines. If you stick your driver in there you can pry it up at the top and then it will open up and still be attached at the back until you open it up a full 90 degrees.
It will be a little tight at first but once it moves it come off freely with a couple wires attached.
I can send you a photo if you can't find the two openings.
You can access the hard drive in the middle left area without removing the entire cover.
You just need to open it wide enough to pry up the connector from the hard drive where it plugs into the board.
These are supposedly 1.8" drives so most likely you'll need to find an adapter to be able to recover your files. Usually a ZIF to IDE and then use a USB 2.5" enclosure or you might be able to order a ZIF to USB enclosure. I can help you figure that out once you pull it out. I swear I counted 46 pins on the mainboard side. I'm stumped until I see what you pull out of there.
I'm interested in photos and info on the drive and connector since mine is missing and I was to find something that might work instead of paying full cost from the manufacturer.
I also need an AC adapter for this damn thing, but it sure looks cool!
As far as laptops, it's way too heavy but the most Bad *** case on the planet.
Makes me think of the bad guy in those action movies...it's like some kind of super detonator tracking monitoring bleeping minefield activating superslick laptop the hero must disarm or destroy!
TELL ME THE DISARMING CODES NOW!!!!
Posted on Jan 03, 2009
I replace the screen on my gateaway mt 6916 and cant install the video controler driver
Instructions
Prepare the laptop for disassembly. Shut down the laptop completely, then wait a few minutes before removing the battery and unplugging the AC adapter. Turn the laptop over and lay it down on a flat surface so that the battery area is facing away from you and the hard drive is located at the bottom left corner.
Remove the hard drive cover. Remove the two screws located on the left side of the hard drive cover, then lift the cover to remove it completely from the unit.
Remove the memory cover. Unscrew the eight screws holding the memory board in place; this cover is located above the Gateway product sticker.
Disconnect the Wi-Fi adaptor. Remove the Wi-Fi cover by unscrewing the single screw holding the Wi-Fi adapter in place; this is located directly above the hard drive. Remove the two cables connecting the wireless card to the adapter and snap the card out of the holder.
5
Remove the memory modules. Gateway computers typically have two memory modules located in the center of the motherboard; lift these out gently with your fingers and set them aside.
6
Release the heat sink. Unscrew the four screws around the heat sink assembly; this unit is located to the left of the ventilation fan and is surrounded by a copper base. Carefully lift the heat sink and the cooling fan off the unit and unplug the cable attaching it.
7
Remove the CD/DVD drive. Unscrew the small screw located to the left of the CD/DVD drive, then push the drive out to remove it from the laptop completely.
8
Remove all screws around the base of the laptop. You will now be left with a total of 18 screws located around the edge of the base of the laptop, and in between the stickers and hardware components in the center. Remove all of these carefully and set aside in a safe place.
9
Prepare the cover for removal. Turn the laptop up on its edge so that the back of the laptop is facing you; you will see two screws on the hinges of the computer. Unscrew these and set them aside.
10
Remove the hinge cover. Open the laptop so that the screen is laying flat; use the flathead screwdriver to pry open the hinge cover and pull it off gently with your fingers.
11
Remove the keyboard. Lift up the keyboard and reach behind it to release the cable. You will need to tug gently on the cable to unhook it from the motherboard.
12
Unhook the LCD screen from the notebook. Unplug the Wi-Fi antenna cables located on the right side of the motherboard directly under the screen, then unplug the video cable located directly under the hinge cover. Remove the pair of screws located to the left and right of the LCD screen and gently lift the LCD screen off the notebook's base unit.
13
Remove the system board. Turn the base unit over and unscrew the five screws securing the motherboard to the base. Two of these are located near the hinge cover, and two are located beneath and to the right of the hard drive unit. The fifth is located a few inches below the top right edge of the laptop.
14
Disconnect the motherboard. Lift the system board, then unhook the cable connecting it to the base unit.
Jan 10, 2013 | Gateway DX4200-09 PC Desktop
How do i safely remove the cable that attaches to the motherboard on my toshiba laptop
Toshiba satellite motherboard removal.
A motherboard is usually replaced for one of two reasons. You either replace a motherboard because it has gone bad, or you replace an older motherboard with a new or upgraded motherboard. In either case you will have to completely disassemble your laptop to even gain access to your motherboard. Fortunately, the Toshiba Satellite laptop can be completely disassembled even if you don't have a lot of technical knowledge.
Turn off the laptop, disconnect the power cable, remove the battery pack and disconnect any miscellaneous cables and peripheral devices. WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Attach an antistatic wrist bracelet to prevent shock from static electricity. Static electricity can harm your computer's internal parts. Place the laptop face down, and remove the single Phillips-head screw attached to the hard drive cover. Remove the hard drive cover, then set it aside. Remove the single Phillips-head screw attached to the wireless card/memory cover. Remove the cover and set it aside. Slide the hard drive out of its compartment. This will disconnect the hard drive from the computer. Set the hard drive aside very carefully. Push on the ejector tabs on either side of each RAM module. Slide the RAM modules out of their compartments at a 45-degree angle. Remove them from the laptop and set them carefully aside. Disconnect the antenna cable from the wireless card, and then lift the wireless card out of the laptop. Remove the four retaining screws from the modem card. Lift the modem card slightly out of the laptop, and then disconnect the modem cable from the motherboard. Set the modem card aside. Remove the single Phillips-head screw securing the DVD/optical drive. Slide the DVD drive out of the laptop's frame and set it aside. Remove all marked screws from the bottom casing of the laptop, and then place the laptop face up. Open the laptop as far as it will go. Use a small flathead screwdriver to pry up the keyboard bezel. The keyboard bezel is a small plastic strip sitting between the keyboard and the LCD display. Remove the two Phillips-head screws securing the keyboard in place. Lift up on the keyboard and disconnect the keyboard's ribbon connector from the motherboard. Remove the keyboard from the laptop and set it aside very carefully. Close the laptop. Place the laptop vertically so the LCD display hinges are face up. Remove the two Phillips-head screws from the hinges. Set the laptop down and open the laptop as far as it will go. Remove the four Phillips-head screws securing the LCD display. Lift up on the LCD display, and then disconnect the video cable from the motherboard. Remove the LCD display from the laptop and set it aside carefully. Disconnect the DVD control board cable, the touchpad cables and speaker cables from the motherboard. Disengage the plastic latches on the rear of the laptop casing near the hinges, and then remove the top casing from the laptop's base and set it aside. Remove the two Phillips-head screws securing the CPU fan and heat sink in place. Disconnect the fan cable from the motherboard. Remove the fan and heat sink from the motherboard and set it aside. Remove the single Phillips-head screw securing the motherboard to the bottom laptop casing. Disconnect the USB port connector from the motherboard and remove the jack from its housing. Lift the motherboard from the bottom laptop casing and very carefully set it aside.
Hope this helps.
Dec 13, 2012 | Computers & Internet
How do I remove the harddrive from the HP Slimline S3100n?
Shut down the power to your HP Slimline computer.
Remove any memory cards or other devices from the desktop.
Disconnect the power cord and peripheral devices from the computer.
Lay the computer flat on your work surface.
Remove the three screws on the rear of the computer cover with a Phillips screwdriver.
Slide the cover toward the back of the computer then lift it off the tower.
Set the cover aside.
Raise the wire latch in front of the hard drive mounting area.
Pull the cables straight out of the connections to disconnect them from the hard drive. Unscrew the retaining screw in the side of the mounting tray with a Phillips screwdriver.
Grab the tab on the hard drive tray and slide it back out of the mounting area. Remove the screws that secure the hard drive to the tray with a Phillips screwdriver.
There are four screws, one on each corner.
Slide the hard drive out of the tray.
http://www.youtube.com/watch?v=hcChcrjCILo
Replacing an HP Slimline Hard Drive
hope this helps
Sep 30, 2012 | HP Hewlett Packard Pavilion Slimline...
I cannot find the memory slot to add extra ram into my asus x5dc
There are 4 screws on the rear(2 either side of the hinges),remove these screws.With the bottom of the laptop facing up then remove the battery cover(should already be removed along with power supply and battery),there should be 1 shorter screw in the corner of the battery compartment,remove this.The full bottom panel should be slid towards the rear just under an inch.The panel should then just lift of revealing the memory slots.Hope this helps.
Jul 27, 2011 | Computers & Internet
I do have a problem with my presario M2000 Compaq laptop which whenever i open the laptop, it keep asking me password. Futhermore, my dvd rome cannot response to cd. can u help me. Tq
  1. Disconnect the power cable and any printers, monitors or other peripherals you may have attached your M2000. Lay the laptop face down on a table, with the front of the laptop facing you. Remove the battery by sliding the release latch to the left. The front end of the battery will pop up. Rotate the battery toward the back of the laptop to disengage it from the laptop base.
  2. Locate the hard drive on the right side of the laptop. Remove the two screws holding the hard drive cover in place and remove the cover. The hard drive will have a mylar tab on it to help remove it. Grab the tab and lift up on the left side of the hard drive until it disconnects from the motherboard. Pull the hard drive straight up to remove it from the hard drive bay.
  3. Remove the single screw holding the optical drive in place. Stick the end of a bent paper clip into the disk tray release hole on the optical drive, located on the front of the disk tray. This will eject the disk tray. Grab the tray and slide the optical drive out of the laptop base.
  4. Remove the memory modules. The memory compartment is located in the center of the M2000. Remove the two screws holding the cover in place and remove the cover. Use your fingers to spread the latches on the sides of the memory modules and slide the modules out of the sockets.
  5. Remove the mini PCI card by first removing the last cover on the bottom of the M2000. Remove the screws on the cover and remove the cover to reveal the mini PCI card. Disconnect the white and black wireless antenna cables from the card. Spread the latches on the sides of the card and slide it out of the socket. Disconnect the antenna cables from the clip attaching them to the laptop base.
  6. Remove the keyboard cover and LED board by first removing the two screws in the battery bay. These hold the keyboard cover in place. Flip your laptop over and open it up. Slide a flat-head screwdriver into the notch behind the "F1" key to unlock the keyboard cover. Do the same thing at the "F5," F11," and "Insert" keys. Pull the cover up to remove it. The LED board is under the cover. Disconnect the data cable from the motherboard and remove the two screws holding the board in place. Remove the board.
  7. Remove the keyboard by first removing the four screws holding the keyboard in place. Lift the back end of the keyboard up and tip it over so it is resting face down on the palm rest of your M2000. Disconnect the data cable from the motherboard and remove the keyboard.
  8. 8 Remove the display panel by first disconnecting the video cable from the motherboard. Disconnect the wireless antenna cables from the clips attaching them to the top cover of your laptop. Remove the six screws holding the display panel in place. Lift the display panel off of the laptop base.
  9. Remove the base enclosure by removing the three screws on the top of the laptop connecting the top to the base enclosure. Flip the laptop over and lay it face down with the front toward you. Remove the 18 screws holding the base enclosure in place. Lift the rear end of the base enclosure up until it comes free from the laptop. Once it's free, slide it back to remove it.
  10. Disconnect and remove any remaining components including the speakers, Bluetooth module and USB card. All of them are removed by the same procedure. Disconnect the cables from the motherboard and remove any screws holding the components in place. Lift the components straight up to remove them.
  11. Disconnect the fan cable running from the cooling unit to the motherboard. Remove the three screws holding the cooling unit in place and lift it straight up to remove it. To remove the CPU, turn the locking screw counter-clockwise until it clicks. Grab the CPU by the edges and lift it straight up. Put the CPU in an antistatic bag for safekeeping.
  12. Remove the motherboard by first disconnecting the touchpad cable and remove the five screws holding the motherboard in place. Lift it up by the left side and remove it from the enclosure.
  13. please comment on these solution by saying how helpful.rating or voting.
Dec 24, 2010 | Compaq Presario M2000 Notebook
Pavilion dv4 1431us how to remove the hard drive. Don't know which section is the hard drive screw to unscrew.
The Battery Compartment Cover is to the outside.
(By the way. Have all power sources removed from the laptop. The AC adapter {Charger}, and the Battery)
Laptop upside down, face the Battery Compartment to the top.
The long middle cover in the middle, under the Battery Compartment Cover is the Harddrive Compartment Cover.
On the Left side of the Harddrive Compartment Cover are two screws to remove. One in each outside corner.
After the screws are removed, lift up on the Left side to remove the cover.
(They may just loosen to a loosened state, and not actually remove)
The Harddrive Compartment Cover is 'hinged' on the right side, with a couple of plastic tabs coming from the cover itself. After it is tilted up far enough so that these tabs will come free from the slots they're in, the cover can be removed.
There are 3 screws which hold the Harddrive Caddy in place. (The Harddrive is mounted to a sheet metal Caddy, which goes across the top of the Harddrive, and down each side)
The first screw is in the Middle to the Left outside.
The other two screws are on the Right, and are on the corners.
After removing the screws you will see a Black strip of cloth/plastic coming from the Left side of the Harddrive/Caddy combo.
The Harddrive is eased up slightly on the Left side, and pulled to the Left side with the strip of cloth/plastic.
(On the Right side of the Harddrive is the interface. The pins that come out of the Harddrive. These pins insert into a female socket in the laptop)
The Caddy around the Harddrive is mounted to the Harddrive with 4 screws.
Two on EACH side.
Holding the Harddrive in the direction it came out of the laptop, (Interface pins to the Right), look at the mounting screw on the Right side.
The one that goes through the sheet metal Caddy, and fastens it to the Harddrive.
Now look at the same screw on the Left side. It goes through a tab.
Remove these screws, and DON'T loose them, or mix them up with the other screws.
(Use a multi-compartment container. You can use a clean egg carton in a pinch)
Remove the screws from the other side.
Install the new harddrive in the Caddy, then install the Harddrive/Caddy assembly in the laptop.
DO NOT overtighten the screws.
Regards,
joecoolvette
Oct 18, 2010 | Computers & Internet
I want to remove hard drive on a k40ij-d2 notebook
unscrew 4 screws on the back.<br /> remove battery cover, remove one screw there too.<br /> slide the bottom panal forward.<!-- from fixya rte -->
Aug 16, 2010 | ASUS K40 Notebook
Hard drive
These instructions should help.
Toshiba® Satellite 100, 105, 110, 115, 200, 205, 210, 400, 405, 410, 420, 430 Series
Hard Drive Installation Instructions
  1. Turn notebook upside-down.
  2. Remove the battery compartment cover.
  3. Remove the battery pack.
  4. Remove the 2 Phillips screws that mount the hard drive down.
  5. Slide the hard drive away from its connector and gently lift it out of the notebook.
  6. Remove the tray from the old hard drive and assemble it onto the new hard drive.
  7. Slide the new hard drive into its connector inside the notebook.
  8. Replace the 2 Phillips screws used to mount the hard drive into place.
  9. Replace the battery pack.
  10. Replace the battery compartment cover.
Jul 28, 2008 | Toshiba Satellite A100-S8111TD Notebook
Getac W130 PC Notebook Logo
1,040 people viewed this question
Top Getac Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Getac Computer and Internet Expert? Answer questions, earn points and help others
