Question about Magellan eXplorist 210 GPS Receiver
My Magellan Maestro 3100 has a blank screen and will not turn on.
This unit is 2 years old, have had no problems with it. Worked great. Was plugged into car charger. Had functioned fine for two hours. Shut car off for two hours and blank screen when next tried to initiate. Nothing I have tried will get the unit to turn back on.
Cannot find link to Magellan repair.
  • Anonymous Feb 17, 2009
    my Magellan maestro worked fine until one day it just gave me blank screen and will not turn on need help on this product.
  • Anonymous Apr 15, 2009
    worked fine for 2 years, screen going blank after starting up, won't come back til i restart it, repeat
  • 20 Answers
SOURCE: Magellan Maestro 3100
Bin it - get a Tomtom.. my Roadamte 700 has had so many problems and Magellan support just don't care/respond.
Am getting a Tomtom 720T with maps and cameras preloaded - updates automatically each time you place it on its cradle attached to your PC/internet.
Posted on Jan 08, 2008
  • 3 Answers
SOURCE: Magellan Maestro 3100 stuck on
If you followed the procedure closely, you now have an SD card with your backup on it. The backup consists of two folders: BACKUP, and USBTRANS. Insert the backup SD card in your PC's reader slot and open a "file explorer" aka "Windows Explorer", not to be confused with "Internet Explorer". You will use Windows Explorer to click and drag the USBRANS folder to the Maestro.
With the Maestro 3100 connected to the PC, a couple of Explorer folders will open and you can see the file structure for the GPS in 1, and in the other one a separate file structure for the blank SD card needed for the update. Look at the file structure for the GPS and you should see a handful of folders including "SYS".
  • Start the upgrade program, following the procedures.
  • Click the NEXT button at the bottom of the procedures screen.
  • Immediately copy the backed up USBTRANS folder (and all contents) to the SYS folder on the GPS.
  • The update should now find the Maestro 3100 and proceed with the update.
SUMMARY: copy USBTRANS (it should contain 1 file: UNIT.DAT)
  • from your BACKUP SD card (not the one in the Maestro)
  • to your Maestro 3100's SYS folder.
Posted on Oct 29, 2008
SOURCE: Magellan Maestro 3140 blanks out
There seems to be issues with magellan batterys, being subjected to the cold has also been proven to effect the battery life, magellan offers a 1 year service on all units. I hope this has answered your question.
Posted on Jan 14, 2009
gregcarolann
  • 32 Answers
SOURCE: magellan maestro 3100 turns itself off
Try using the RESET button . Make sure the battery is holding its charge
Posted on Jan 21, 2009
SOURCE: magellan maestro 3100 failed update
go to Tech support at www.magellamgps.com tell them what has transpired and ask for 2.18 Update Recovery Files. This fixed my problem. Took a few email exchanges but I thought the responses were very quick.
Posted on Mar 13, 2009
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
Hi My Magellan Maestro powers up with the Magellan screen and the bar scrolls but thats all it does? Carl Lucas Aberdeen MD
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Aug 03, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Mine isnt telling me where to turn at all
make sure the gps in not muted. check the mute on and the sound turned up on the map screen and also check the sound in the options/system/ sound, if they are both ok and the try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already. READ UPDATE INFO BEFORE UPDATING,VERY IMPORTANT
i cant stress enough that patients is a must here. this update is huge 1.75GB takes atleast 30 - 60 minutes depending on your system.
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 30, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 turns itself off
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
have you updated the maps on it? if no try and update the maps also do a firmware check to see if you need an update.
Nov 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 failed update
Oct 04, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Feb 25, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 3100 locks
You can try a hard reset. Hold in the reset button (left side of unit, use a pin or toothpick), while turning on the unit. If you don't get the blue Magellan screen, you'll have to try again. If you get a screen with a blue background and a menu, turn it off and try again.
So far, this has fixed:
1. unit won't go on
2. unit reboots when routing
3. unit turns off after a few seconds
At least, it's fixed it for me. No idea why this happens, but it's pretty damn annoying. Give it a try.
Dec 26, 2007 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan eXplorist 210 GPS Receiver Logo
771 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
