Question about Frigidaire ATF6000ES Front Load Washer
Error 20 on washer its a frigidaire front loader M# atfb7000seo
  • 3 Answers
Take off the front panel, two screws on mine. On the right side you will see the pump with a black drain "boot". We raised the washer onto blocks and put a basin under it to catch the excess water. If you can't drain it, your gonna need a shop vac. There were three approximate 1 1/2" clamps, you'll need a pair of straight and channel lock pliers. (I replaced two of the clamps with radiator clamps to make it easier next time) Once you remove the 3 clamps theres a spring loaded clamp at the top of the boot. Lossen that and remove the boot. There is a plasic seine inside with about 3/8" holes. Clean it out. I found the missing blue sock, a string from a sweatshirt, two wire clamps, a paperclip and $1.26 in change. Check the pump impeller and make sure it is clear ans put it back together. Run a load before rplacing the front panel in case you need to tighten the clamps more. Hope this helps.
Posted on Mar 19, 2009
E20 .... I ALSO HAVE AN E20 WHICH I BELIEVE HAS SOMETHING TO DO WITH THE FACT THAT THE WATER IS NOT DRAINING FROM THE UNIT. MY ISSUE IS THAT THE PROPELLER IN THE PUMP BROKE AND WILL NOT PULL THE WATER TO DRAIN THE MACHINE. LISTEN TO IT WHEN YOU TRY TO RESTART THE CYCLE AND IF YOU CAN HEAR A RATTLE NOISE FROM THE BOTTOM OF THE MACHINE YOUR PUMP MAY NEED TO BE REPLACED OR NO NOISE MAY INDICATE THE PUMP HAS BURNED OUT. ONE OTHER THINK YOU MAY WANT TO CHECK BEFORE YOU GET SET ON REPLACING THE PUMP IS TO CHECK YOUR COIN COLLECTOR. REMOVE THE FRONT BOTTOM PANEL AND YOU WILL SEE A RUBBER BAG LOOKING THING THAT IS ATTACHED TO YOUR PUMP AND TUBE WITH CLAMPS. YOU MAY HAVE LINT OR A SOCK STUCK IN THE CATCH WHICH MAY BE PREVENTING WATER FROM DRAINING. I MUST WARN YOU IF YOU CANNOT GET YOUR MACHINE TO DRAIN BE PREPARED FOR A MINI FLOOD. HOPE THIS HELPS.
Posted on Dec 23, 2008
Is there a recall on Frigidaire front load washers. i have had mine for less than 5 years and motor is coroded. Very disappointed. especially for the cost. Debbie Richardson 706 8886362
You need to contact Frigidaire customer service for this, they will have all that information. I don't know of any recalls on any front loaders personally, but based on my experiences with them they are to be avoided, more trouble than they are worth and the are problem plagued compared to top loaders (my 2 top loaders have lasted about 20 years each). And then there is the cost to buy versus a top loader.
Nov 04, 2016 | Frigidaire Washing Machines
Code E 21 Error on Affinity Washer Front Loader
I've had problems starting my washer because the door does not close properly, and then I get an error or pau code
What has worked is to unplug the washer for a minute, close the door, and then plug it back in. it then starts normally with 2 pushes on the start button
Jul 06, 2014 | Frigidaire Affinity ATF6000F Front Load...
Error e 12 frigadaire front end loader washer
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Dec 14, 2012 | Frigidaire ATF6000ES Front Load Washer
Frigidaire lft6700fso washer not filling with water
water pump is clogged i pulled it out and cleand it and put it back and its working like it should and the part n is m222-5 on the frigidaire front loader
Mar 12, 2012 | Frigidaire ATF6000ES Front Load Washer
My frigidaire front laod washer has an E20 error message.
E20 error is known for pump out issue.The first thing I recommend is to take off the front bottom cover(below the door) tilt the washer back some,remove the clamps and hoses from the drain pump.It should be on your right hand side.Check the pump and hose to remove the clogging.This tends to be a common problem with Frigidaire front loaders.Now when you all done with that put it back together and do a test run.
Apr 11, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
No spin
E47 and E48 are door lock error codes, also check the wire harness connections too.
Oct 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidare front loader washer error message 20
If you open the top of the washer , there is a "tech" sheet in there to tell you how to reset the error codes.
My washer started this. Then stopped spinning. Now it will not even wash a load. It stops mid-cycle. The ER 20 means that something is not draining right. We checked all of the tubes leading to the pump. Nothing was clogged. The technition seems to think it is a motor controller error.
Oct 27, 2008 | Frigidaire Affinity ATF7000E Front Load...
I have a Fridgidaire Front Loader Washer _ Affinity. It has an error message flashing. E10. What does that mean? What do I do to fix it?
I have a Fridgidaire Front Loader Washer _ Affinity that flashed the E10 error code. I also had the problem with the fabric softener dispenser not emptying, and staying full of water. The problem was the cold water filter on the back of the washing machine that was semi-plugged. Cleaned the filter and now works perfectly. My machine is no longer flashing the Error code 10. The dispenser works perfectly.
Oct 05, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
