Question about Samsung HT-WX70 Theater System
System turns off automatically
No Heat issue,Diagnostics is passed,No Error Msgs,So What could be the problem
    New Friend:
  • 111 Answers
Loose connection of the printed circuit board.
Posted on Jan 08, 2009
Motherboard Led codes
Is this a bios error code onthe onbaord diagnostics?
As this is a server board be careful - reset the bios to defaults is the first step in solving motherboard issues.
Remove all cards and begin testing - remove all ram chips except one and test replacing stepwise until you have isolated the issue - usually the bios error code is the last item to pass before failure.
Looks like it could be DMA controller failure but you would need the manual for the board to be sure.
Jan 30, 2013 | Tyan Computers & Internet
Black screen
It can be a possible hardware issue or a software issue
Try to run the dell diagnostics
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If it fails replace the part on which it fails.. If it passes reinstall the OS to fix the issue
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Dec 22, 2010 | Dell Inspiron XPS M140 Notebook
UNDI INITIALISATION FAILED ERROR 1000-0141
Dec 21, 2010 | Dell Latitude C400 Notebook
Error code 0141 internal hard drive not found
Dec 20, 2010 | Dell XPS M1330 Notebook
My Dell inspiron 1501 went to a blue screen and gives me an error message when reading the Hard Drive upon boot up. I am told the disk is either malfuntioning on logic or may have crashed. How can I find...
fortunately dell has built in diagnostics that can assist you with identifying the problem. here is a link on how to run them. if the drive is bad then you would need to replace it and reinstall windows and drivers. if it is good then run memory diagnostics as well just to be safe. if both pass then you may have to do a destructive reinstall of windows because you most likely have a virus issue. copy and paste this link into your browser it will help you run the diagnostics.
http://www.cs.utexas.edu/~deke/laptopsupport/manuals/d600/diag.htm
hope this helps
Dec 10, 2009 | Dell Inspiron 1501 Notebook
Once i powered the avision 220 on, The moniter shows E and 7
When you first turn the scanner on, the READY light will blink, indicating that the diagnostics are in progress. Observe
the front panel Error LED (Red) closely. In a short time, the Error LED indicates the results of the offline diagnostics as
explained below.
Ready LED(Green) is off and Error LED(Red) indicates 7, the error indication is"Face down light check failure".
Followings are the solution for the above problem:
1. CCFL is on? Yes. CCD error, Optical assembly is to be replaced.
2. CCFL is on? No. Inverter error. Lamp inverter circuit is to be replaced.
3. CCFL is on? Yes. Issue resolved.
4. If the CCFL is still off, then CCFL is to be replaced.
Hope the above information is helpful.
Please revert if you have any doubt.
Thank you for contacting FixYa.
Regards,
TechSatya
Nov 01, 2009 | Ambir Technology Avision 220 Pass-Through...
Hi, I have a dell d505 laptop and am getting a dst short test error when running the diagnostic. someone told me I should run the recovery cd, but I no longer have it. How can I get one ? Is there a way to...
You can download Dell Diagnostics from Support.dell.com for your model system, and see if you get a failure indication there. If you get a failure during Dell Diags, then it should help you ID the failed component. If the Diags pass, it is only indication it didn't FIND a failure, so there still MAY be a hardware issue. (Diagnostics only look for a limited selection of possible errors, so failures may still exist, even though a component passed a diagnostic.)
If you are having a memory issue and have two ram modules, best test is to try each module in the system by itself and see if issues go away, if they do, then the one module that generates errors is likely bad.
Jun 28, 2009 | Dell Latitude D505 Notebook
Dell laptop error message no boot sector on hard disk
Sounds like you'll be getting a replacement hard drive.
Here are some things you can try.
  1. Reseat the hard drive, ensure it is seen and ID'd in the system BIOS.
  2. Run diagnostics on the drive is detected.
  3. If Diags pass/unavailable, you can try booting to an XP CD, enter recovery console, see if you can run a CHKDSK /R and fix the issue.
  4. Reformat the drive and reinstall.
If the drive fails to format or fails diagnostics, replace the drive.
Jun 29, 2008 | Dell Computers & Internet
Dell laptop
Remove the CD Drive from the computer , disconnect the charger from the computer , flip the laptop and remove the battey, with the battery disconnected , push the power button for 10 secs to release the flea power , open the memory slot , remove both the memory sticks and then put back only one of the memory stick and then try restarting your computer. If it gives out the msg amount of memory changed , then Strike F1 to continue...
Apr 21, 2008 | Dell Latitude D600 Notebook
Samsung HT-WX70 Theater System Logo
128 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
