Question about Frigidaire FEX831CS Top Load Stacked Washer/Dryer
I would like to shut off buzzer in dryer please do not answer if there is a charge
  • 3 Answers
If you are trying to shut off the buzzer because it sounds constantly, there is a problem with the dryer timer motor, and that is an entirely different problem.
However, if you are like me and find it really annoying and loud - and are trying to disable/remove it this is how to do so:
Tools: #2 Phillips head, 8-10" long
#2 Phillips head, 3" long
Optional but recommended: Vacuum cleaner with flex hose. (Unless your dryer is new or you maintain regularly, it is full of lint that is a potential fire hazard - this is a great opportunity to clean it out)
Optional but recommended: Duct tape, the metallic sealing kind, not the elastic adhesive tape
Steps:
1. REMOVE THE POWER PLUG FROM THE WALL. TURN THE DRYER CONTROL TO TIMED DRY AND TURN THE START KNOB TO ENSURE THE POWER IS OFF (IF THE DRYER STARTS, YOU PULLED THE WRONG PLUG - TRY AGAIN)
Note 1: As you start removing panels, it would be a good idea to clean as you go, otherwise you will have a big dusty mess...
Note 2: As you remove the panels either screw the screws back in to where to took them out of, or screw them into the holes of the panels you are removing, they can get mixed up or forgotten easily...
2. Remove the 2 screws that hold the cover from the underside of the dryer tumbler (above the lid for the washing machine)
3. Remove the 7 screws for the tin sheet that covers the blower/tumbler motor
4. Remove the 2 screws for the front control panel with all the knobs for the washer/dryer
5. The panel can be lowered out slots on each end by applying some pressure inwards, then down. Mine was a little more difficult to remove because of all the lint/**** built up so I used a screw driver for a little prying action. If you try this, pry on a side the that is not exposed in case you cause any dents, scratches, etc... for aesthetic reasons.
6. Once you have the panel down, vacuum this area very well, there are exposed contacts and terminals here that will be a source of ignition if a contactor goes bad and there is a lot of lint build up.
7. On the left side where the dryer controls are, there is is a little black rentangular box with two wires going into it - mine was between the dryer cycle knob and the start knob. It is the only component on the backside of the panel that will not have a corresponding knob on the front of the panel. Remove the screw that is holding it in place, and pull it up at an angle to clear a metal clip that holds it in on the side opposite the screw.
8. Once you have the buzzer free, follow each wire from the buzzer to its termination point on the dryer cycle controller. The buzzer should have black a wire going to the "common terminals" labeled either B or C, the other black wire is for the switch terminal of the dryer cycle controller. There should be "female" connectors on the wires from the buzzer, connected to the "male" terminals of the dryer cycle controller.
9. Remove these female connectors, which will disconnect the buzzer from the dryer. Be sure that you do not accidentally pull off an incorrect wire - and if you do, make sure to reconnect it before removing any other wires to avoid confusion as to what goes where.
At this point, get a flash light and take a look around the inner dryer housing. With your vacuum - if you have a brush attachment, use it - clean out all the built up lint from everything you can reach, especially around electrical connections, wires, the dryer motor windings, etc... Take your time, do it right - you spent the time taking the thing apart, it will not kill you (and actually may save your life) to spend 15 minutes cleaning the inside of your dryer.
If you have some duct tape, tape the blower exhaust connections from the plastic blower housing to the metallic duct and the flexible duct. I also taped the plastic piece that the lint screen inside the dryer door sits in because the foam rubber stripping had come apart. There areas are the main places that lint escapes into the inner parts of your dryer.
10. When you are done cleaning, reassemble the dryer in the reverse order you took it apart in.
11. Once reassembled, plug the unit back into the wall.
12. Turn the dryer control knob to as close to the end of a cycle as you can, turn the start knob to start the dryer. If the dryer starts, then stops at the end of the cycle without a buzzer - you were successful.
Posted on Mar 06, 2010
The buzzer does not sound at the end of a drying cycle. I've replaced the buzzer but the problem of no buzzing still remains. How is this remedied?
About 21,300 results (0.60 seconds) Search Results
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric ...
    ? 1:11
    https://www.youtube.com/watch?v=vsLyHfJLfqk
    Jul 15, 2010 - Uploaded by RepairClinic.com
    Dryer Buzzer Replacement - Whirlpool/Kenmore Electric DryerRepair ... Additional dryer repair, troubleshooting tips, help with finding your ...
    Questions and Answers for Whirlpool 694419 Adjustable ...
    www.appliancepartspros.com/questions-for-whirlpool-adjustable-buzzer-...
    Customer Questions and Answers for Adjustable Buzzer Kit by Whirlpool ... At theend of the dryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool 694419 Adjustable Buzzer Kit ...
    www.appliancepartspros.com > ... > Washer > Whirlpool Washer Parts
    $27.64
    Adjustable buzzer kit 694419 / AP3019850 made by Whirlpool. ... At the end of thedryer cycle the buzzer sounds but does not time out and shut off.
    Whirlpool® Duet® 7.3 cu. ft. Front Load Electric Dryer with ...
    www.whirlpool.com/-.../WED80HEBW/
    Whirlpool Home Appliances
Feb 08, 2016 | Whirlpool Dryers
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Dryer does not buzz when cycle complete
Hello, Thank You for using FixYa. I will be helping you today.I looked up your model and there is no end of cycle buzzer.
Thank You and please rate my answer if it was helpful..
Jun 13, 2011 | Whirlpool LGR4600 Gas Dryer
Buzzer won't shut off. only when door is left open
could be a number of things, but you may want to test with an ohmmeter if you have one.
It sounds like your timer needs to be replaced. If the buzzer is not shutting off, the timer may not be turning to the off position. It may be really slow our out of wack, not letting the dryer completely dry. It also could be an error with the dryer's control module (kind of like a computer for the dryer)
I also recommend playing around with door switch, it to may be faulty. If the dryer does work with door closed, it is unlikely to be the door switch. You will have to test timer and door switch with ohmmeter or voltmeter to determine that the voltage current is constant and not speratic or shorting out.
May 18, 2009 | Kenmore Dryers
Timer and Shutoff
Go for the timer. The timer is nothing but a bunch of contacts and some minor electronics. When the timer reaches the end of it's cycle, it closes a set of contacts which sends power to the buzzer, which could be bad, therefore continued buzzing. If the timer continues on to the next cycle either the electronics or contacts are shot. This is also age dependant on the dryer how the timer is built. You might go into price shock depending on model. This is not ruling out that if you have a buzzer on off switch might be bad, but I doubt it. Hope this helps. If you are unsure and are good at reading schematics and a meter, then you can be sure.
Jan 09, 2009 | Dryers
Buzzer wont quit
have you tried to turn the knob slightly at end of cycle to see if it would shut off? try that if it does shut off then replace your timer
Jan 06, 2009 | Kenmore 73952 Gas Dryer
I would like to know how many belts a kelvinator dryer has made 8/1991, and the model number is DET 400-G2D. Serial number: XD13423136. the end cycle buzzer will not shut off once the cycle comes to an...
Hello dmjohn39,
Welcome,
I am Huuum at your service!
You said,
You would like to know how many belts a Kelvinator dryer has made 8/1991, and the model number is DET 400-G2D. Serial number: XD13423136.
The end cycle buzzer will not shut off once the cycle comes to an end
It appears to take only this one belt according to the book!
You can find the belt at one of our many our Sponsors, site below!
I have typed the belt # and cost for it at the site.
I am sure they will have the buzzer too!
Item # Price
3372 $14.10 + 4.00 shipping I believe
Dryer belt length 87 3/4”, width 1/2”, characteristics, flat
Recommended related item(s):
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Thank You for using fixya.
I was happy to solve your questions!
Please remember to leave a rating!
Oct 13, 2008 | Frigidaire CWS3600AS Top Load Washer
Dryer continues to spin periodically after the clothes are dry - doesn't shut off completely
yvonne sorry but that isn't a feature you are able to turn off. It happens that the buzzer goes off as well that people don't like. Only the top of the line model allows the buzzer to be turned off. The wrinkle guard is just that, to help prevent wrinkles.
Jul 22, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Frigidaire FEX831CS Top Load Stacked Washer/Dryer Logo
328 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
