Question about Bunn TB3Q, 29" Trunk, 3 Gallon Tea Brewer
TB3 Brewer is brewing weak tea - how do I adjust?
Is there a way to simply adjust the water ratio so less cold water goes into the basin and more hot water goes thru the tea basket?
    Novelist:
  • 125 Answers
Hello. Yes, however, you would need to adjust the brewing cycle time to make up for the lost bypass water in order to get the same container level. In other words, the cold water part of the brew cycle is separate from the hot water part of the cycle, if you put in less cold water, and want to keep you container filling to its current level, you would need to increase the hot part of the brew cycle to make up for it, other wise it will brew less into your normal container. If you go to:
http://www.bunnomatic.com/
find your unit by model/type, you should be able to get a owners/installation manual, this will tell how to do it, or call the manufacture.
Hope that helps, and thank you.
Posted on Feb 22, 2009
Why does the coffee maker cycle but water does not run over the grounds in the basket?
First I'm not a Brewmatic tech, but I have worked on this and other similar brands. You should call your vendor for service. Especially if this equip is on loan. *** the following is for information only.***
* This brewer has a multiple timer selection as well as multi function. (it can brew in different ways and sizes.)
* The batch selector determines the brew time. This is set up according to your needs and the pots you will be using. If you change pots then the machine needs to be re-calibrated to the new sized pots.
* Each timer setting needs to be individually calibrated and checked. This is usually done by the tech. Some brewers can be set without taking the cover off but most are locked out by the vendor to prevent tampering. You will need the operator/tech manual to make adjustments. (check your MFR online site)
* There is usually 2 tubes from the tank (top) to the brew head. The 2nd tube which usually branches off the brewing tube is a by-pass port which will trickle down between the wire basket and funnel. This is why it is important to keep the metal wire basket inside the larger metal brew funnel. Some may come with a separate by-pass solenoid but most have a needle valve. I usually set this needle valve by closing it all the way down (clock-wise) and opening it back up 3 full turn (counter-clockwise) I've found and average of 3-1/2 turns works for most 1 gallon brews. Opening it more will give you more watery brew and closing it down a stronger and sometimes bitter brew. It really depends on your grind size and brew amount. You will need to test it at least 3 - 5 full brews to find the sweet spot. But, stick with 3-1/2 turns if your not sure.
* If there is a 3d tube , it usually runs to the hot water faucet which is gravity fed so it does not need a solenoid valve.
* Some brands may have one more tube that has a solenoid attached which usually runs to the middle of the brewer near the top of the decanter. This is the water by-pass for Iced tea. Tea brews into the funnel the same as coffee but the funnel has a smaller drip hole. This allows the tea to steep longer in the funnel. This tea concentrate is then cooled down with the addition of cold water from this extra middle port. Most brewers with the tea option has a taller appearance to fit the tall Iced tea dispenser.
* Final; the brewing spray head should fill with hot water unless the timer or brew solenoid is not working.
* Short brews can also be caused by water probe or water control board problems. Check the water probe for crud or fixed too low in the tank. Low water in tank will lead to slower brewing and longer brew times.
* Brews are also affected by water fill valves. Not opening or intermitent operation. Note some valves are not rated for hot water feed. If your connected to a hot water line then the inlet valve needs to be rated for hot water.
* Final, check if your operators are pushing the right batch size button. Call your coffee vendor for help.
ukeboy57
Feb 10, 2018 | Brewmatic Coffee Makers & Espresso...
Water does not come out of water spout and will not brew after pressing start button
make sure the water is hooked up in the back properly and turned on. the solenoid tells it when to brew, but the spigot feeds right from the waterline.
Jan 21, 2015 | Bunn CWT15 Automatic 12 Cup Coffee Brewer...
Own the 3 qt ice tea maker. When making tea it leaks around the seam in the front of the machine and pours out all over the counter and not into the tea maker; any fixes or suggestions to remedy this messy...
I have this same problem. There seems to be two sources of the leak, described below. However, I think Mr. Coffee should re-design the offending parts.
1) bad fit between the brewer and the pitcher, caused by a pitcher that stands too high, preventing the pitcher's spout from snuggling into the brewer. I avoid this problem by brewing without the lid on the pitcher.
2) the brewed tea does not flow straight down from the brewer basket, especially when the tab is set to "strong". In this setting, the brewed tea is forced through a tube, in order to spend more time steeping. However, if you watch the tea flow out and down, you will see it bend to the left and thus miss the catch spout of the pitcher (and flow onto the surface, leaving the impression that one of the parts is "leaking") . I think this is caused by buildup of particulate matter from the tea and/or hard water deposits. My solutions here: try the tab in the "mild" setting; and/or clean the basket drain holes occasionally, especially if you have hard water (soak in vinegar to remove hard water build-up). You may need a tiny bristle brush to clean the small holes in the basket. Also, try to fit the pitcher into the brewer as far to the left as possible.
Hope this helps.
Gary in Torrance
Mar 02, 2011 | Mr. Coffee Iced Tea Maker TM1S
How to use mr coffee tea appliance
First clean the pitcher, lid, steeping basket and steeping basket before you use it the first time. Run a brewing cycle without any tea the first time and discard the water.
With the unit unplugged, fill the pitcher with water to the top water level mark on the pitcher and then pour the water into the reservoir. Do not overfill. Place the steeping basket and lid on top of the machine. Place a tray of ice cubes into the pitcher. Turn the steeping dial to open. Put the lid with the spout open on the pitcher and slide it, spout first, under the machine. Plug in the unit and turn it on. Wait until it turns off automatically.
For brewing, fill the pitcher with water to the line for the desired amount of tea. Pour this water into the reservoir (with the steeping basket and lid removed). Place a Mr Coffee filter into the steeping basket and add the desired amount of tea bags or loose tea. You can add sugar or lemon over the top of the tea if desired. Slide the steeping basket into the unit and put on the lid with the steeping dial set to closed. Fill the pitcher with ice to the desired ice level or with cold water to the same volume as poured into the reservoir. (If you are using water, put the pitcher in the refrigerator to chill.) Slide the pitcher with the lid on under the brewer and make sure the lid is open over the spout. Plug in and turn on the brewer. When the brewing cycle is done, it will turn off. Turn the steeping dial to open to drain the remaining tea from the steeping basket. (Let the remaining tea sit longer before opening the dial if you want stronger tea.)
You can get the manual from http://www.mrcoffee.com/Products.aspx?cid=43 . Click on the link for the TM3 (all the models in a series work the same way).
I hope this helps.
Jan 16, 2011 | Sunbeam Mr. Coffee Iced Tea Maker, TM3PS...
I have a keurig b 60 brewer and i don't feel the water is hot enough. i just got it last night 12/23/10 can u suggest anything?
Sorry to read about your problem, I hope this helps you out.
ProgrammingBrewTemperature (187°-192oF)
The Brewer brews at a preset temperature of 192°. You can adjust this temperature down by 5 degrees if you prefer a cooler cup of coffee, tea or hot cocoa. Simply follow the instructions below.
1. Press the Menu Button on the LCD Control Center five times to program the Brew Temperature feature.
2. The LCD Control Center will now display the programming options with a small arrow next to "SET BREW TEMP" (fig. 15). Also, the temperature 192° (initial setting) will be displayed at the bottom of the LCD Control Center to indicate the current temperature setting.
3. A minus sign will appear over the Small Cup Button and/or a plus sign over the Large Mug Button. Use these buttons to raise or lower the temperature one degree at a time.
4. Once you have reached your desired brew temperature, press the Menu Button once to exit the programming mode. "BREW TEMP SET" will be displayed in the LCD Control Center if you have changed it from 192°.
5. To change the brew temperature again, repeat steps 1 through 3 to change the temperature up or down, remembering that the temperature can only be between 187° and 192°.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Keurig B60 Coffee Maker
Water flow is weak and slow during brew
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
bcvb
cbcb
cvbcbc
Dec 23, 2010 | Keurig B60 Coffee Maker
My Keurig B60 SE has recently started brewing k-cups very, very weak. I have a filter that I can put coffee in and that works fine, and I've even found that when I put the coffee from a kcup into the...
Sorry to read about your issue. plus you may have a bad k kups
Dec 22, 2010 | Keurig Special Edition B60 Coffee Maker
Hi! Quite often, when I put a K-Cup in to brew, the Keurig will attempt to brew but just continues to make a humming sound and nothing will come out. I try turning off the power, just opening the lever...
Dec 21, 2010 | Keurig Special Edition B60 Coffee Maker
How do I set the brew ratio?
Hello, I have worked on many bunn and other make ice tea makers but am not too familiar with this one, but as is common to all there should be 2 timers, one for the hot one for the cold. They are normally located under the top panel or inside the front panel. for 3 gallons you should be brewing 64oz of hot water through the 1oz tea bags (3-4) depending on taste as a rule of thumb. Please feel free to comment again if you have any other questions. Good Luck! Mike
Aug 15, 2009 | Bloomfield 8742 iced tea brewer, 3 gallon
Bunn Tea Maker ~ flashing green light and not working
Check the top of the brewer, there is a limit thermostat on the tank between the elements, disconnect and check resistance, if no reading replace. If you have a good reading, there may be another inline fuse on the line from the element to the ready light, disconnect and check resistance. If no reading replace, if you get a good reading, then the problem is with the pressure stat(box with the black knob for on off.
May 12, 2009 | Bunn Iced Tea Maker 3 Gallon Tall w Ready...
Coffee Makers & Espresso Machines Logo
164 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
gbob59
zimcloud
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
