Question about Cuisinart DCC-1200 Coffee Maker
Unit leaks out of the bottom
Warm, clear water leaks out of a hole in the bottom of the coffee maker.
  • 5 more comments
  • azstacy Nov 04, 2007
    My machine is leaking from underneath the front part. I don't know what to do with it.
  • Anonymous Dec 05, 2007
    Coffee maker worked fine for 2 years, now it leaks so badly that 12 cups of water make barely 4 cups of coffee.
    I have tried to find the leak but cannot get inside to see.
  • lalin Dec 05, 2007
    After teo years, my coffee maker suddenly started leaking. Twelve cups of water make barely 4 cups of coffee. Cannot see inside to find leak.
  • Jean Gordon Jan 19, 2008
    My coffee maker DCC-1200 is just 3 months old and has leaked several tablespoons of clear water underneath it interrmittently since bought. I figured I had over-flowed it when filling, but with total care in filling, still had to mop up under it. I had found an article that stated this is a manufacturer's defect with a water tube in the bottom of the unit. Having spent over $70.00, I'm sending it back under the warrenty and hope I get one that works right. What is the alternative?
  • Anonymous Mar 16, 2014
    when adding water the water runs out from the bottom
  • Anonymous Mar 26, 2014
    We found the brass adaptor (one with O ring) which was broke and causing water to leak out. Having trouble finding the part.
  • Anonymous Mar 31, 2014
    Water leaking from bottom of coffee maker
  • 4 Answers
Mine just developed the same problem. Me being an engineer, I decided to take it apart and found the problem. There is an aluminum tube shaped like a "C" with a heating element inside of it. Water flows through this metal tube, is heated, and then pushed via steam pressure. There is a metal brace that holds this "C" piece securely to the bottom of the machine. This brace is sharp and overtightened, which caused a small hole to form in the metal, causing the leak (in my machine of course). I am currently researching how to patch aluminum so I can hopefully fix it.
Posted on Jan 06, 2008
  • cforsberg01 Jan 28, 2011
    Andy, did you ever fix your coffeemaker? I have the DCC-1200 too, I've had it for around 7 or 8 years, actually, but all of a sudden it started doing the clear water leak out the bottom of the machine thing....did you find out if fixing the hole in that aluminum is possible? I've heard of metal-bonding glues. Please let us all know if the machine CAN be fixed, or if its ready for the scapheap now -- thanks!
My bunn coffee maker leaks at the bottom. Can you tell me what to do
Okay no model given,
* Pour over brewers only leak if over filled (more than a pot). If it leaks just sitting there then there is a hole in the tank. Call for service or replace.
* Commercial machines like CW, CWTF, Single, Dual, Urns, are plumbed into a water line. Leaks may come from the water line, Tank, or urn.
* If the water leak is clear and not hot then it's the water inlet line.
* If it's hot then the heater is leaking,
* If it's coffee colored then it's the urn where the coffee is being brewed.
* In All cases call your vendor for service as this is a hazardous situation. Unplug or turn off the power to the unit. It should be on a large throw switch near any large brewer. Have maintenance turn off the breaker and leave of till the vendor can service.
Aloha, ukeboy57
Aug 09, 2017 | Bunn Coffee Makers & Espresso Machines
It goes through all the cycles but no hot water comes out. Unit is two months old.
Have you tried brewing with no k-cup in the unit? If water comes out then the needle that punctures the bottom of the kcup needs to be cleared out. I use a paper clip and put it into the kcup holder where the puncture needle is. I move it up and down the hole until cleared out.
Jul 19, 2014 | Keurig Elite B40 Coffee Maker
Gaggio syncrony, water leaking from bottom after coffee is made
Remove the brew unit and clean the small hole under the white plastic valve make sure the little drain from it leads into the drain tray is clear.
Jun 25, 2011 | Gaggia Syncrony Compact Coffee...
My Saeco spidum divina leaks water from the bottom. The water is clear and warm and I can still make coffee. What is the problem?
Could be a leak in the high pressure lines or the boiler. The boiler leaking was a issue on the order models by saeco.
Here is a link the boiler that is most likely in your machine. 2 element boiler
May 07, 2011 | Saeco Spidem Divina Deluxe Fully Automatic...
The water drains from the water container into the bottom of the unit. The water container does not leak, I have tested this by filling the container up and leaving it the sink. I have adjusted the...
Hi heeg_mark,
Leaks problem most often occurs when the water tank is not seated properly allowing water to drain out of the tank and into the base. There are alignment pins on the tank that fit into holes in the coffee machine. Make sure this alignment holes are clear of any debris. Coffee beans have been known to make their way into these openings. Please use a flashlight and a small mirror to see down into the alignment holes. You can easily fix this by following the steps below.
1. Please remove the water tank.
2. There is an access opening like a round hole in the base beneath were the tank fits into the machine.
3. Using an absorbent cloth material dry the water through this opening. Please be patient, it can take sometime.
4. Once the water is gone the machine will operate normally again.
Hope it helps.
Thank you for using FixYa.
Jan 09, 2011 | Miele CVA615 Espresso Machine
COFFEE MAKER LEAKS CLEAR WATER FROM THE BOTTOM EVERY TIME I USE T
Have the same issue, looking for my receipt for warranty. All of us having this problem can't be wrong and it must be defective
Dec 30, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
Leaking water
Take out the brewing unit and look in the chassis behind where the brewing unit was, you will see a little hole, put in your finger and make sure the hole is clean.
Have a nice day
/Mirran
Oct 20, 2008 | Saeco Vienna SuperAutomatica Coffee...
The water hose on the bottom of the coffee maker is worn, due to the heat. It needs to be replaced. this is the second time for mine.
Mar 24, 2008 | Cuisinart DCC-1200 Coffee Maker
Water leaking into machine
it's possible, like mine with the same problem, that one or more of the plastic feet under the water tank has broken, then making the tank move and upsetting the valve underneath. My one always leaks clean water, never dirty and I have a broken foot.
Sep 29, 2007 | Saeco Primea Cappuccino Touch Plus Coffee...
Cuisinart DCC-1200 Coffee Maker Logo
2,086 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Norman Worley
Tom Howe
Tom Howe
Level 1 Expert
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
