Question about SATO CL408e Label Printer
Cannot Print Correctly on Sato CL 408e Printer
Hello, I have a Sato CL 408e Printer running on (Windows XP , SP3) connected via a Parallel Port with the latest driver installed. I need to print in Landscape Format but it changes to Portrait Format and even with Manual Changes it does not print the way I want it to Print.  Some help will be much appreciated as how I can fix this problem.
Regards, Karan
  • karanbheda Feb 25, 2009
    Hello People ... I managed to solve the problem .... Thank You !!!
  • Dave Busselle May 11, 2010
    what software are you driving with?
  • 155 Answers
I recommend that you use the drivers from www.seagullscientific.com, they have the best drivers and let you adjust all the printer settings.
Roberto Martinez
Posted on Oct 06, 2009
Hello, I have a SATO CL408e, with a parallel connection. I have used a parallel to usb to connect to my laptop and i have istalled all the drivers. I have the port set to LPT2. The problem is the device...
In the past I have got that problem several times. The truth, it will always be better to use technology from this century. ;)
The problem with adapters is that they are usually chinese and those drivers are horrible. I usually solve it by buying the most expensive adaptor on the store, which usually includes a Driver CD. The OS could be helping to make it even more difficult. If you have a Windows Vista, you will not have an easy time printing.
Apr 05, 2012 | SATO CL408e Thermal Printer
I receive a "Cannot connect to PC" when I try to scan using my HP OfficeJet T45xi printer/fax/scanner/copier using Windows XP Home Edition with SP3 on my Dell Inspiron 600M. I have downloaded and run the...
That is the correct driver.
Make sure you have a good cable (with bidirectional support). Check that the ECP mode is enabled for the parallel port in the Device Manager. Click Start > Properties (Control Panel). Click on the Hardware and then the Device Manager. Open the Ports section and look for the parallel port option (LPT1). Double click on this and look at the Resources tab. If the printer is connected in ECP mode, you will see two entries for the I/O ranges. This may need to be enabled in the BIOS (often reached by hitting F1 or F2 when restarting the computer before the OS loads). If you adjust the BIOS setting for the port, you will need to return to the Device Manager and adjust the Port Settings to Enable Legacy Plug and Play.
If you use a USB to parallel adapter, make sure you got one that supports bi-directional communication.
I hope this helps.
Aug 02, 2010 | HP OfficeJet T45xi All-In-One InkJet...
I have a HP Laserjet 4P that had been used on my company laptop and home computer. When I upgraded top a new Dell Vostro 420 running Windows Vista Business and moved the printers over to this unit the...
You don't write how exactly is your printer connected - if I remember correctly, HP LJ 4P doesn't have a USB connector, and Vostro doesn't have the parallel port available.
So how did you connect it? Is it via some USB to parallel adaptor, or via JetDirect network card in the printer? There are multiple separate issues that may be applicable in either case...
Dec 30, 2009 | Office Equipment & Supplies
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Sato 408E problem
Using direct thermal labels it can dirt the printhead and platen roller, you must clean them with isopropyl alcohol and a flannel. Also adjust the darkness to less value to best print.
Roberto Martinez
Jun 29, 2009 | SATO CL408e Thermal Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
Spare Parts Catalog for SATO CL 408...
it is available on the Sato web site, by printer model
Oct 29, 2008 | SATO CL408e Thermal Printer
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
Oct 07, 2008 | Canon Office Equipment & Supplies
SATO CL408e Label Printer Logo
746 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
M_Butkus
Howard
Howard
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
