Question about Kitchen Ranges
Won't bake, but all else works
Hi, My maytag oven is model # MGR5755QDS. The oven is not igniting. No sounds but one click about 6 seconds after you set the temp. Then it just sits at 100 degrees. Cooktop, broil and clock work fine.The temp sensor seems to work. After I have it on broil and the oven warms, then go back and try to set it on bake, it does show the rise in the temperature. There's nothing in the trouble shooting that seems to cover it.Well? What do you think? Thanks! Joe
  • sgordo02 Jan 10, 2009
    the same thing happened to me twice after I used the self-cleaning oven function. What a horrible oven!
  • Kitchen Ranges Master
  • 8,220 Answers
Swap the broil and bake ignitors(they are both the same) see if the bake works. If the oven bake works then you need only replace the ignitor. If it does not then I would say you should check the valve for continuity. If open, bad gas valve. If continuity is detected, bad oven control.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 22, 2008
We have a Maytag CRG9700BAL. The Oven Will light and come to temp but will not relight to maintain temp. We have replaced the oven temp sensor and the clock assembly but the problem persists. Could the...
Yes
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Feb 21, 2011 | Maytag Kitchen Ranges
Stove has quite loud bang when ignited
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 12, 2010 | Maytag MGR5755QDS CleanDesign Gas Kitchen...
Maytag gas stove model CRG9830CAE the oven will not work
Hi. This sounds like a weak igniter, the symptoms usually are: burner won't light, or takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature or burner does not come on fully. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, the igniter needs to be replaced. Good luck.
Mar 27, 2010 | Maytag Kitchen Ranges
Stove and broil work, but bake mode wont light, temp reading stays at 100 and controls lock up.
Know it's kinda late. I had the problem in March and hadn't had time to get to it. I need my oven though. I'm thinking of looking at the igniter, replacing it. Don't want to get hit with a $200 repairman bill. What did you end up doing?
Feb 17, 2010 | Maytag MGR5755QDS CleanDesign Gas Kitchen...
Gas oven model MGS5875BDB comes up to temperature fine but then won't hold the temp. the overn does not restart after it cols a bit. It is the same in bake or convect bake cycle.
Hi, what you describe sounds like a weak igniter. The igniter (which lights the oven burner) doesn't go out all at once and will cause problems like this for a while, then quit working all together. I'd say replacement is the answer. Good luck.
Jan 12, 2010 | Maytag Ovens
Oven will not ignite in bake mode. Broil function works.
When the bake igniter becomes weak or burns out, your oven would not bake. The bake igniter is usually mounted on the oven burner. It's about 1 inch by 4-8 inches (depending on the model), and comes in round or flat styles. If you don't see the igniter glow at all, it's probably burned out. Replace the igniter if found defective. Note: one of the exceptions could be that your oven is set to automatic mode instead of manual. If this is the case, set your oven to manual mode and check again.
If the bake igniter glows red and not bright yellow or white, it is probably because it is too weak. When this happens, the safety valve would not let the gas out into the oven burner. A weak igniter must be replaced.
A faulty igniter is probably the most common cause, however there are others:
-- defective thermostat
-- defective selector switch
-- defective gas safety valve
-- defective gas valve coils
Oct 12, 2009 | Maytag MGR5755QDS CleanDesign Gas Kitchen...
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag mgr5870 not baking correctly
hi there,
sounds like the TOD may be at fault. can you supply me with the model # on your stove please?
as far as the popping sound, that would the spark module.
Aug 23, 2008 | Maytag CWG3100A Gas Single Oven
Kitchen Ranges Logo
372 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
