Question about A D S Dual Link DLX 180 (0757887180003) Serial Adapter
Having trouble with drivers...
Hm - this refuses to let me load drivers for this device. It tells me that there is already a "newer driver" loaded and it can only load the drivers if there is no service pack loaded onto my system. Well, it also can't FIND a driver for this when I search for it automatically...so it can't load the driver because a better one exists, but it also can't find a better one to use. I've tried many things - thought maybe it had to do with the 1394-SP2 issue, so i tried about a hundred various solutions that i found all over the net to no avail. And no matter what I do, it won't recognize drivers for this device. Oddly enough, the USB seems to be working fine, no issue at all. Its just the firewire thats malfunctioning, and in the device manager, it has the little yellow exclamation point. Please help! Thanks.
    Problem Solver:
  • 20 Answers
Delete the yelow exclamation listing from device manager. restart the computer. Comnnect your device from serial port. Let the computer to detect it. If add new hardware wizard starts, you just click next and go to the (for xp)"I will find the driver manually" go to browse button go the driver location (cd or folder where it is located). Select it and click next and finish the wizard. Now see if the hardware is working. if not Then ensure that the hardware is properly connected to the serial port. Again delete the yellow exclaimed listing for the device from device manager. Ensure that the driver you want to install is exactly the driver of specified device. Some times it happens that the advance versions of operating systems has pre loaded updated drivers for common devices so the old drivers not work. you also ensure that the driver you want to install is made for the operating system you use. Restart the computer an ensure that the driver is ok.Install it directly from the cd by setup.exe file if you have and see it is working.
Posted on Jul 24, 2007
Security device not found when trying to load Bernina v4.0 Software
Be sure that your dongle is plugged into the computer when you boot the software. If it is plugged in and you are having trouble, your computer may not have the proper driver for the dongle. If you are on a newer operating system, it is also likely that the older version of the software are no longer compatible with newer operating systems.
May 22, 2014 | Bernina Sewing Machines
Can't get driver loaded for Zeepad 7 9XN
Hi code 43 can occur if the device driver fails uninstall the driver ,& install a new driver .cheers
Nov 04, 2017 | ZEEPAD 7 inch Android 2.2 Tablet
I have already down load driver but he can,t instal, bcoz my cam driver cd is lost pls help me
1st You download Webcam Driver.
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Dec 28, 2010 | Manhattan Mini WEBCam
How do I activate printer if I don't have CD that came with it? I had to do a system recovery and now printer won't work
depends on the printer and the computer. If you have a newer computer just go to "printer/faxes" . Make sure you printer is all plugged in and turned on and tell computer to find the computer. Many of the drivers are already on your computer and it will load the one that is necessary. If not then search the internet for a driver for the printer, and load it into the computer and all should be ok.
Sep 18, 2010 | Epson Stylus Multifunction Inkjet Printer/...
I found I needed a USB/Ethernet adaptor in order to connect my new broadband and purchased an ASIX AX88772A vai your product A31GY from Maplins. I'm having trouble in that the Broadband set up refuses to...
I allowed Windows Update to search for the right driver. This took a long time - I'd tried earlier but evidently hadn't let it run for long enough. It located and loaded a driver and everything was then fine: the ethernet connection (via adaptor) 'went live', my new broadband set-up software recognised it and proceeded sussessfully from there.
I assume that the device manager on my PC was correctly identifying corrupt drivers on the small CD supplied with the adaptor and that I'd managed to find uncorrupted ones on the internet via Windows Update.
Robin Lovelock
Dec 09, 2009 | Computers & Internet
DVDRWBB mechanic trouble
try uninstalling, turn off your pc, check the cables are connected properly then restart and let windows pick up the drive and reinstall the driver.
let me know how you get on so i can help you further if needed
Feb 11, 2009 | Dell Computers & Internet
I have a dvd writer model LG GSA-E60L an when i install windows xp tells me that it is not digtally signed and also it comes up with error41 cant find hardware wont let me install and also i cant find my...
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Jul 08, 2008 | Computers & Internet
Cannot install software
Did you connect the scanner to your computer before loading the CD? There is an updated driver available from Canon that your operating system may have found and already installed. Try loading your CD again and this time select "Custom Install" instead of "Easy Install." After selecting Custom Install, the next screen will show all of the programs that will be installed. De-select the ScanGear box so that this software doesn't try to install as it is the updated one that is already on your computer most likely. Click install and the install should proceed this time.
Jun 02, 2008 | Canon CanoScan 4400f MultiFunction Color...
Omni MP3 Player
I had the same problem! Later found that my USB cable was broken! Try another USB cable.
May 31, 2008 | Omnifi DMS1 Home MP3 Player
A D S Dual Link DLX 180 (0757887180003) Serial Adapter Logo
184 people viewed this question
Top A D S Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an A D S Computer and Internet Expert? Answer questions, earn points and help others
