Question about Akai PT4298HD Rear Projection Television
Picture distorted and double vision
Help me solve this issue
  • 2 more comments
  • djmiller_14 Jan 08, 2009
    Double vision on screen. thin red bar at top left corner
  • tracyleelaws Jan 19, 2009
    everything on my tv is double everyone looks like they have four eyeballs and big lipstick on its all unclear help me
  • natt19742001 Feb 03, 2009
    distorted pictue/ double vision
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    do you see double or 3D type picture on TV?
Adjust the convergence..........push mute 1 8 3.....and it will take you into it. pnce in 2 will change the adjust mode, and 7 8 9 change color options
Posted on Dec 23, 2008
Distorted pictures icon blured
Do any of the Icons have double vision? and the display is distorted also? If so then your analog / digital board is bad and needs to be replaced, If you remove the bezel of the monitor and are able to get the monitor apart to get to the board, be sure to search for the correct part number listed on the board and Vola, you be back in business again. You can find these boards on Ebay for not too much money. Hope this helps.
Oct 17, 2012 | Dell E173FP 17" Flat Panel LCD Monitor
My Toshiba 53H71 rear projection TV's picture looks like double vision with a heavy tint outline how can I fix this???
Double vision/ picture problem occurs due to failure of convergence output ICs in rear projection tv and it is common problem of projection tvs.
Please replace convergence output ICs in tv to solve the issue, there is convergence repair kit available for $70 on This Site that has required parts/ ICs, instructions about how to replace ICs etc for a handy person.
Hope these info will help.
Thanks.
Jun 11, 2011 | Toshiba 53H71 53 in. Rear Projection...
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Picture has ''double vision'' with red.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • TV shutdown - does not display video
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2010 | Televison & Video
Double vision with color distortion
how do i solve a double vision and color distortions
Oct 08, 2009 | Hitachi Televison & Video
Put it together myself now wont focus past 5 ft and has double vision i tryed using the adjustment knobs and stillno luck
loosen the the thingy behind the lens adjustment, you can turn it clockwise or anti-clockwise which it will go down or up, thats it..problem solve for your 5ft focus problem..in the double vision, you gotta line up the eyepiece center to your both eyes..problem solve again
Apr 29, 2009 | Optics
Double Vision (Mainly around the edges of the screen)
Look for your Convergence amps and check the solder connections on them....you may only have to resolder the amps...and if they fail in a couple weeks, then replace them...
If you don't beat up the convergence amps for WEEKS operating them with the bad connections, they can survive...
Jan 29, 2009 | Toshiba 50HDX82 50" Rear Projection...
Distorted picture,After power loss
Replace both STKs covergence chips 392-56or 570s use same STK numbers.
Dec 12, 2008 | Mitsubishi VS-50805 50" Rear Projection...
Mitsubishi Model # VS-50609
try to resolder the convergence amp ICs that may help if not the ICs may need to be replaced. Let me know if you need further assistance.
Jun 22, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Akai PT4298HD Rear Projection Television Logo
115 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
