Question about QMark MUH-35 Heater
QMark MUH108 heater element not working.
Thermostat and fan still working away. I noticed a burnt smell for a few hours one day, several weeks ago. In retrospect, this must have been when the heating element died.
Any guesses... fuse, wiring, heating element?
2 Suggested Answers
frcs68
  • 1605 Answers
SOURCE: MUH108
4awg is about the size of battery jumper cable. or 240v multi-strend cable. and 48A is big. double 40A brakers.
the heater is 208v 3-phase 34,000BTU
it is call out to use the 240 comercial wiring.
Posted on Dec 02, 2008
The heater runs constantly, the thermostat seems to work, I check continuity through it, it opens and closes. What else could cause not to shut off?
QMark MUH (0521) Compact Heater Wont shut off ... - Fixya
www.fixya.com > ... > QMark > QMark MUH (0521) Compact Heater
QMark MUH (0521) Compact Heater, wont shut off related issues. Get free help, solutions & advice from top QMark experts.
QMark MUH (0521) Compact... Repair Questions - Fixya
www.fixya.com/support/p437492-qmark_muh_0521_compact_heater
Recent QMark MUH (0521) Compact Heater questions, problems & answers. ...thermostat on and contactor makes buzzing noise, fan dont run but its not seized it willfreewheel when you spin it ... How do I turn off my q mark wall heater there.
QMark MUH (0521) Compact Heater Shut - Questions - Fixya
Dec 01, 2015 | QMark MUH (0521) Compact Heater
Our Lakewood 5101 oil heater gets warm, but over the last few days, it is not getting hot like it used to. It seems like it has slowly been getting colder over the last week or so. I can feel the heat...
Appears you have a heating element issue. Many of these elements are segmented for temp control. If one part goes fubar the heater will work but not put out the heat it used to unless you replace the element with a new one that has no burnt out sections.
May 03, 2017 | Lakewood 5101 Oil Filled Radiator Heater
Muh108 single phase what size breaker to use 40 or 50 amp
IF it is 10KW at 208 single phase it should be on a 60 Amp breaker.
3 Phase would be 35 Amps. Always check the nameplate for additional information. It may be configurable for different voltages. Best to check manufacturers data if available.
Mar 05, 2011 | QMark MUH-35 Heater
No heat after burnt smell
Either your Fan motor is faulty or the fan control resister assembly is burnt out, either of those will cause the smell.
Dec 28, 2009 | 1999 Cadillac DeVille
Melted plastic floor in Freezer
The refrig is possibly a Magic Chef . This refrig has the coils AND defrost heater , under the freezer floor . If the defrost thermostat sticks , the heater will eventually burn thru the aluminum coil cover and melt the freezer floor . However , with the freezer floor burnt thru , the freezer fan is not pulling the complete air flow , over the coils , which in turn , a lot more electricity is being used , to try to keep the complete refrig cool . To repair , you would need 1 ) defrost thermostat , 2 ) freezer floor , 3 ) foil coil and heater cover , 4 ) a few hours or days ( if not done before ) .
So , no , not an easy fix .
Oct 05, 2009 | Refrigerators
Heater no longer works on auto fan, only manual fan
When you call for fan in auto ensure your getting 24 volts at pin on control board, if it is not energizing then there is a problem with the relay.. Before you change out the expensive control board, try the therm..
Dec 09, 2008 | Heating & Cooling
Washer stopped filled with water, smells like burnt plastic
REPL/ PUMP BURNT PALSTIC SMELL ,AND RUBBER SMELL, ONCE REPL./ SHOULD FIX
Nov 29, 2008 | Maytag Atlantis MAV6000 Top Load Washer
MUH108
Sep 10, 2008 | QMark MUH-35 Heater
Belling Synergie fan oven.
the elemet has burned out round the fan
Dec 05, 2006 | Belling XOU174 Electric Single Oven
QMark MUH-35 Heater Logo
90 people viewed this question
Top QMark Heating & Cooling Experts
Paul Carew
john h
Danny Kuhlmann
Are you a QMark Heating and Cooling Expert? Answer questions, earn points and help others
