Question about LG WM2277 XL Front Load Stackable Washing Machine with 7 Washing Programs in 3 Colors ....
Overload in motor noted as LE
Sir I have jsut finished doing a load of laundry and was preparing to do a second when the my washing was beeping. When I checked the LE was on signifying an overload in motor. I chut off the water and unpluged the power instructed in the manual. The solution in the manual is to call for service. This machine is 5 months old. I have a large family with lots of laundry. Is there something I can check first before I call for service? I appreciate you taking the time with this.
  • Joseph ROY Apr 08, 2007
    thanks so much for you excellent advice. I did shut the machine off and when I plugged it back in I ran a cycle with nothing in the washer, the washer seems to be running fine now. I did put heavy wet towels in the washer and then continued to load it. Do you think this was the problem?? once again thanks
    President:
  • 878 Answers
Frenchie, the LE has to do with the motor sensor, There should be a 3 pin connector in the motor harness that connects to the stator. It could of come loose, or the sensor itself gone bad. The other scenerio would be the sensor harness to the main board had opened or came loose. Since this machine is under warranty, you wouldn't want to void it. You can try to put it into the self test by doing the following: Turn the unit off. Press the spin speed and soil level buttons together, while holding them, press the power button. The buzzer should sound twice. Now by pressing start/pause button you can advance it through 12 tests. Everything from slow tumble, spin, inlet valves, circulation pump, drain pump. The 12th being door unlock and power off. I don't know if this will work or not but it's a chance to get you going again until factory service can get out there....Catriver...post back.
Posted on Apr 08, 2007
Washer won't fill. code LE
Try unplugging and replugging. Apparently it does a reset of something. It worked for me. I would make sure you don't have to much laundry in the machine too.
Dec 10, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
I have a front-loading LG WM2277HW - the drum will not spin - it "attempts" to start - but then will just not move - after some time, I get the error message "LE" - which I understand indicates "motor...
Here is a link so that you can access the service manual http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf
note page 18 regarding the error display LE.. This manual should allow you to better understand how to diagnose that problem.
Hope this helps you.,.
Regards,
Rick
Feb 21, 2009 | LG WM-2277HW Front Load Washer
I have a LG TROMM washer.It is not washing properly.
LE stands for overload in motor. Wait 30 minutes before restarting. If it happens again try again without a load.Good luck. Please rate me so I know how I'm doing. Thanks.
Dec 30, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washer
Product Laundry Washer
Symptom Error Codes
Sub Symptom LE error code
Question Locked motor error code.
Answer
LE error code: This indicates a locked motor condition. Please check the following conditions. Large loads of laundry can put a strain on the motor causing the LE error code. Try removing some clothing and restart. Excessive suds can cause the LE error code. Make sure the customer is using an HE (High Efficiency) detergent. They should decrease the amount of detergent until the machine washes without suds. A few bubbles can be expected. Areas that have �soft� water will usually need to use less detergent. If you suspect that excessive suds are the problem, let the machine stand for 30 min (motor cool down) and then run a rinse and spin cycle before restarting the load. If these directions are followed and the code persists, the machine will likely need service. .
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | LG WM2277HSW XL Front Load Stackable...
Lg wm2277hs
Symptom Error Codes
Answer
Washer
Greetings jannd,
The message "LE" can indicate that the thermal overload protection circuit in the motor has been tripped. The remedy for this can be to allow the washer to stand for 30 minutes to allow the motor to cool, then restart the cycle. If the LE error code still appears, unplug the washer and call for service. Keep in mind that this unit carries a 7 year warranty on the motor also.
I hope this helps!
Best regards,
Dorothy
Go Ahead. Use Us.
May 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
F-H code and beeping noise
error code which is serial communication error with motor contrl.
replaced M.Contl.brd but still have error.
Dec 03, 2007 | Kenmore Elite 45986 Front Load Washer
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
188 people viewed this question
Top LG Washing Machines Experts
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
