Question about Jet AFS-1000B Air Purifier
Jet AFS-1000b Air Purifier quits after several minutes
I can start it remotely or manually with same results. It will start again and quit in seconds. Removed filters with same result.
Thanks
  • dmb76 Feb 04, 2009
    I have had a very similar problem. Unit worked fine first time I used it, now won't start, seems like fuse triggers.
  • ikayak2 Feb 21, 2009
    I have not used my AFS-1000B for several months and was going to spend some time in the shop and I could not get the unit to stay on. It will run for a few seconds and then shut it self off. If I try to change the speed while it is on, it turns itself off. Change filters, changed batteries in the remote. Still only runs for a few seconds and then turns off.
Remote will turn the air filter on but will not turn it off. Have two in my shop with the same problem
I had similar issues and by replacing the 2200 micro (Mu) Farad, 10 Volt capacitor on the PCB, all of my issues ceased.
Below is a link with information supplied by "fixya" that explains the procedure/details.
Hopefully this will solve your current issues.
Good luck,
Mike
http://potlash.org/feast/2010/11/20/repairing-a-jet-afs-1000b/
PS Linda Haus of "Rockler" Technical Support was kind enough to supply me with this link.
Jun 02, 2014 | Jet AFS-1000B Air Purifier
Won't start
Check the fuse inside the unit, it is located where power cables hook up.
Aug 26, 2008 | Jet AFS-2000 Air Purifier
What can I do for two Ecoquest fresh air 2.1 that both flicker on start up?
It doesn't sound fixable in the field. It may be a control panel issue. Contact Vollara (which bought Ecoquest) & get through to tech support. 800-989-2299.
Apr 27, 2014 | Ecoquest Fresh Air Air Purifier
Runs but not for long and now the motor simply hums.
Stay with the one that you ordered. There is no variance allowed between 2200 uF and 1000. The voltage is the variance that you are allowed to change.
Dec 16, 2013 | Jet AFS-1000B Air Purifier
Problem with Jet AFS-1000B Air Purifier Afs-1000b
Mine had this same problem, it was a 1000 uf capacitor on the circuit board. It is replaced and working fine
Nov 04, 2013 | Jet AFS-1000B Air Purifier
Green light is on red light is off
Replace the Air Flow Sensor (AFS). The thermistor could be compromised.
Sep 13, 2011 | Trion SE1400 Air Purifier
My dad has an ionic breeze that quit working. A repair shop told him it was the power supply. Where can you buy a replacement part?
Hi.
If the model is post 2007, to get parts or repair contact Ionic Breeze support. Here contact page.
If the model was manufactured before 2007, read below, in that case I suggest not proceeding with the repair.
I want to call attention on the fact that several of old Ionic Breeze models are not being manufactured anymore because of health concerns. New model use a completely different technology. Parts for old models that raised concerns are not distributed anymore.
I suggest contacting manufacturer, if parts are not available, then the purifier was among the ones related to health concer. In that case I suggest replacing the ionic purifier with a different air purifier.
Please read the article below:
Ionic Breeze Health Concerns
Regards.
Ginko.
Sep 17, 2010 | Sharper Image Ionic Breeze 3.0 Air...
It dont blow out air,,doe;tsclean air quite
these things are junk. you could also be doing more harm than good to yourself and the indoor air quality in your home with the amount of ozone these appliances omit into the air. throw it away
Sep 08, 2009 | Sharper Image Ionic Breeze 3.0 Air...
Ecoquest Fresh Air Purifier Quit Working
My husband came home and checked out the unit. He discovered that the cord was bad, so he replaced it with one we had. It works fine. The cord plugs into the unit at one end and into the wall at the other end. There was no rewiring needed. Problem solved!
Aug 04, 2008 | Ecoquest Fresh Air Living Air Purifier
Jet AFS-1000B Air Purifier Logo
78 people viewed this question
Top Jet Air Purifiers Experts
Michael Youngman
Michael Youngman
Are you a Jet Air Purifier Expert? Answer questions, earn points and help others
