Question about Pioneer GM-D510M Car Audio Amplifier
AMP Problems
I have a pioneer amp and pioneer sub. I hooked thim up in my 05 trailblazer this weekend. Everything worked great for about a half an hour then I started blowing fuses. I don't listen to it very loud. I just like the added boost. I put another set of 25 amp fuses in it and it worked for about 30 minutes. Blew fuses. OK. So I trased the lines going from the amp to the speaker and there was a bad spot in the line. I replaced it and then I replaced the blown fuses. Now I don't have any sound... The light on the amp is on but about every three seconds the light blinks. I didn't notice it doing that before. anybody with a solution?
How can i fine the fuse that goes to the gas tank meter.
Posted on Apr 26, 2009
  • 15,935 Answers
May have blown an output transistor. Remove the wires from the speaker terminals and see if the problem still persists. If the light comes on with no load, it will need servicing by a technician.
Posted on Dec 22, 2008
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Oct 26, 2013 | Jamo SUB 200 Subwoofer
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Amp dosnt work right
your amp cant handle the impedance of your subs i.e your running a 2ohm sub on a 4ohm amp!
Change the wiring on the sub so instead of running at 2ohm your run at 4
if you need to know how to wire up your sub to run at 4 then take a look at this wiring diagram
take a look at option 2
Click here
Hope this helps if so please dont forget to rate :)
Upfront Audio
Apr 13, 2009 | Pioneer GM-5100T Car Audio Amplifier
RCA jacks not working DEH-P470MP
does the amp turn on when the deck is turned on ? is the ground hooked to the body of the car to bare metal w/out paint ect ...under it ? you may want to take it to a installer there are many things it could be they can also test your rca outputs if thats the problem. curcuit city is a cheap place to have your equipment tested if you live close to one
Aug 07, 2008 | Pioneer CD Receiver - DEH-P470MP - CD/MP3...
Pioneer amp and sub problems
That's a 4-channel amp, not a 2-channel, which makes me wonder exactly how you have it hooked up to your sub. Is the LED light on the amp coming on? How many subs do you have hooked up to it, and how is it wired?
Mar 04, 2007 | Pioneer GM-6200F Car Audio Amplifier
Amp is on, Subwoofer works, but no sound.
here is a short test you can try, remove the rca audio cable from the amp & connect a diskman or toher audio o/p device that you can hook up with the same rca wires, turn on the amp & see if you have sound. you can also remove the speaker wires from the sub & using multi meter read the ohm's of the sub, most subs are 4 ohm. Hope this help locate your problem
Oct 24, 2006 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-D510M Car Audio Amplifier Logo
112 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
