Question about Fuji FinePix S7000 Digital Camera
I have a Fuji FinePix S7000 and the lense in stuck in the out position. I put new batteries in but it still won't work. Any ideas?
  • 3 Answers
TURN IT ON TO TAKE A PICTURE WAIT 5 SECONDS, THEN TURN IT OFF IF IT STAYS IN THE OUT POSITION THEN THE DRIVE MOTOR MY HAVE GONE
Posted on Jan 06, 2009
Fuji S7000 shuts itself down...without a reason
remove the xdcard and use compact flash. also put camera in set mode and run the battery drain function. it seems to reset the battery voltage meter. clean batery contacts with q-tip and rubbing alcohol. worked for me
Dec 27, 2009 | Fuji FinePix S7000 Digital Camera
Fuji finepix S7000 the battery cover is damaged, it will not stay closed to hold in the batteries in. its need a new cover where can i get one or get it fixed. thanks
Yes you can get these as repalcement parts by contacting Fuji, or one of theior repair agents, in your country, or you can return the camera to one of the repair agents to get the job done for you.
Nov 08, 2009 | Fuji FinePix S7000 Digital Camera
Lense stuck in out position
Hi. If your camera is turning on with the lens stuck out. Turn the camera on, and without turning it off, open the battery door, and take the batteries out. Leave it for about 1-2 minutes and try again. This process is call power reset. Usually works. Good Luck.
Dec 22, 2008 | Fuji FinePix S7000 Digital Camera
Zoom on fuji f650 stuck
Hi Sandra, Try power reset for your camera. Turn the camera on, and without turning the camera off, open the battery door and take the batteries out. Leave it for a minute or two. This helps camera get reset and helps correct the basic functionality and also zoom error. Hope it helps u otherwise u will have to take it to authorised repair center. Good Luck.
Dec 03, 2008 | Fuji FinePix S7000 Digital Camera
Fuji S8000fd camera power won't stay on
put in lithium batteries.
I have the s7000 if we put in regular aa's then it will only last like 20 shots tops. But with lithiums we get a few hundred shots.
hope that helps,
Caleb
Jul 04, 2008 | Fuji FinePix S7000 Digital Camera
Dead batteries when fully charged
Does it work with "no batteries" - only plugged into power source? check your usb cable by trying to power up something else.
Jun 28, 2008 | Fuji FinePix S7000 Digital Camera
Fuji finepix s7000
I just then took the previous posts idea and pulled the lense off and cleaned light sand out of it , extended lense as told, put back together and turned on.so far focus seems good
Apr 29, 2008 | Fuji FinePix S7000 Digital Camera
White Square with brighter Oval in middle on LCD and Pictures
have you checked the lense assembly. One of the possible cause may be any of the lense element, inside the lense assembly may have dislocated from its fitting. Just swithc on the camera look inside the lense from the front and try to zoom the camera. if you happen to find any obsticle in the movement may be i am right.
Sep 07, 2006 | Fuji FinePix S7000 Digital Camera
Lens will not extend
normaly S7000 have a manufacturing designing defect of lense not extending. This happens due to broken gears in the lense movement assambly. The replacement of the broken gears will fix the problem
Aug 08, 2006 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
83 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
