Question about KitchenAid KSM103 Professional 5 Series Stand Mixer
Bowl becomes loose and unstable when mixing
My kitchenaid mixer's stainless steel bowl moves around from its base when mixing. It moves no matter how many times I try to turn it into its base. I thought maybe the three screws on the base plate were loose but they were not. Any suggestions?????????????????? I need my mixer desperately.........................
  • Anonymous Jan 18, 2009
    My husband says it looks like I have worn out the groove on my mixing bowl which helps it lock to the base. I have been using it for over 8 years. I am off to buy a new one today at Bed Bath and Beyond to see if that will solve the problem.
SOURCE: Paddle Scraping - KitchenAid Professional 600
There is an adjustment screw and a system for setting it. You can find a video of it here (or just a ton of people who know all about these mixers). I just found it while trying to troubleshoot the same problem for my wifes mixer.
http://forum.kitchenaid.com/forums/forum.asp?FORUM_ID=196
Posted on Nov 02, 2007
SOURCE: Stainless Attrezzi Bowl
I found mine on eBay a while back. You can do a "saved search" that will send you an email if anyone lists one. Just use the search phrase "Attrezzi Bowl" and it can send you an email when anyone lists one. Maybe someone will list a stainless one soon.
Posted on Jun 05, 2008
SOURCE: Can't get the screw adjustment to change the height of the bowl
I had a similar problem with mine - the problem turned out to be that I hadn't clicked the bowl into place corectly. If you find the bowl is tilting forward slightly then you probably need to push it into the clip at the back.
Posted on Jun 25, 2009
  • 145 Answers
SOURCE: Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
hslincoln
  • 235 Answers
SOURCE: Beater rubs bottom of mixing bowl.
JOE:You don’t say if you have a ‘tilt-head’or a ‘bowl-lift' mixer, but you can easily download a PDF version of your Owners Manual from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number (in your case, use KSM90P)and select the last file listed that appear under Owners Manuals:KSM90PSWW0.pdf (2930.74 KB)and save that file to your PC.You’ll need to have Adobe Reader to be able to open it. Turn to Page 11 and you will find the instructions for adjusting the mixer head height.I have extracted the instructions below:
Beater to Bowl Clearance
Your mixer is adjusted at the factory so that the flat beaterjust clears the bottom of the bowl. If for any reason, the flat beater hits thebottom of the bowl or is too far away from the bowl, clearance
Tilt-Head models
• Unplug mixer.
• Lift motor head.
• Turn screw (A) SLIGHTLY counter clockwise (left) to raise flat beater or clockwise (right) to lower flat beater.
• Make adjustment with flat beater, so it just clears surface of bowl.
If you over adjust the screw, the bowl lock lever may not lock into place.
Bowl-Lift models
• Unplug mixer.
• Place bowl lift handle in down position.
• Turn screw (B) SLIGHTLY counter clockwise (left) to raise flat beater and clockwise (right) to lower flat beater.
•Make adjustments with flat beater, so it just clears surface of bowl.
I hope this helps! –Howard, Burke, VA
If this solution has helped you, please rate it, thanks!.hslincoln
Posted on Nov 28, 2009
Testimonial: "Thanks to this answer, I was able to fix the problem in about five minutes. I am very grateful. Joe McCutchen"
KitchenAid ACCOLADE 400 Mixer.When mixing dough the bowl jumps out of the the bowl lock. How can this problem be resolved?
I know this sounds a bit simple but the bowl cup can sometimes actually wear out and a very fast (# screws) and a new one and the problem is solved. If however there is a problem on the head hold down set screw (under the mixer in the cavity ) it can come loose then the mixer head can bounce all over the place causung the bowl to get loose in the holding cup at the base of the mixer., I hope this helps, let us know if you need more, we can FixYa
Feb 22, 2015 | KitchenAid Food Mixers
Kg25h0x mixer
Type not found at Kitchenaid. no_image_available_kad_71x71.png 5-Qt. Stainless Steel Bowl with Comfortable Handle
5-Qt. stainless steel bowl with comfortable handle offers enough capacity to mix dough for 9 dozen cookies, 4 loaves of bread or 7 pounds of mashed potatoes in a single batch. The bowl is also dishwasher-safe for quick and easy cleanup.
Mar 04, 2014 | KitchenAid Food Mixers
Bowl stuck in base
Try harder, there is only one way to get it off and that is to turn the bowl.
Dec 04, 2012 | KitchenAid KSM150PS Artisan Series Stand...
Bad switch on kitchen aid mixer
Unfortunately you will probably need to split the gearcase to sort out the speed control arm.
Nov 30, 2012 | KitchenAid Kitchen Aid Mixer Stainless...
KitchenAid KSM150 bowl won't stay put
I'd be looking at making sure the beater is not banging on the bowl and that the head hinge isn't loose. The bowl is secure on the base with this system that has been in use for decades so you are looking for a fault not a re-design of the system. The friction of the mix in the bowl should logically tend to tighten the bowl, not undo it. I have seen a malformed bowl once where the lugs weren't big enough and I suspect that it's possible for there to have been the odd malformed bottom plate with not big enough lugs.
Jul 08, 2017 | KitchenAid Kitchen Aid KSM150 Artisan 5...
My kitchen aid mixer bowl falls out when I'm mixing
Hello Heather,
Either the grooves on the bowl lock plate are worn out, or the grooves on the actual bowl are worn out. I would start with replacing the bowl lock plate. Here is a link to the part: KitchenAid Mixer Bowl Lock Plate 4163032
This part is really easy to replace, it is held into place with three screws, remove those screws (make sure to hang onto those you will need them to re-install the new part). then you should be able to pop the old plate out. To install the new plate like up the screw holes, and press into place, sometimes you need to lightly tap it into place with a rubber mallet as it is suppose to be a very tight fit.
Once that has been replaced your bowl should lock into place tightly. However there is always a chance that the bowl has been worn down and may need to be replaced. Here is a link to the 4.5 Quart bowl: KitchenAid 4 5 Quart Stainless Steel Bowl
- Colleen @ Mending Shed.com
Aug 12, 2012 | KitchenAid K45SS Classic Stand Mixer
KitchenAid K5 Mixer Bowl Rocks Back & Forth
This may be explained with the bowl assembly. Being a bowl lift mixer, please follow the following steps to make sure the bowl is being secured before mixing:
There are the bowl-holding arms on the left and right hand side of the mixer. You will place the bowl on these arms, securing it onto the pegs.
Also, take your fingertips and press down firmly at the back of the bowl where it is resting against the base. You will hear an audible click as the bowl secures down into a spring latch mechanism on the stand mixer base, allowing the mixing bowl to sit flush and secure.
May 03, 2009 | KitchenAid K5AWH Stand Mixer
I bought a stainless bowl for a kitchenaid mixer and it fits
Jun 05, 2008 | Jenn-Air Attrezzi JSM900 Stand Mixer
Replacement stainless steel mixing bowl for kenwood chef A901D
I have the spare part number for the bowl.
KW638821 - bowl - polished - stainless steel
KW672487 - with handles bowl - mirror finish
try to find a store near you to get one.
Apr 15, 2008 | Kenwood KM300 Chef Stand Mixer
KitchenAid KSM103 Professional 5 Series Stand Mixer Logo
321 people viewed this question
Top KitchenAid Food Mixers Experts
Steve Allison
Steve Allison
Colin Stickland
Colin Stickland
fordexpert
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
