Question about Brother LS-1217 Mechanical Sewing Machine
I lost my manual for my sewing machine?
I can't even use my machine because I am a beginner. I need to know how to thread my top & bottom thread.
    Scholar:
  • 65 Answers
Here is the brother site and downloadable manual is available for the LS-1217
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/model_top/HomeSewingMachine/hf_ls1217eus.html?reg=us&c=us_ot&lang=en&prod=hf_ls1217eus
I hope this helped!
Posted on Jan 24, 2009
Why would that thread break?
Hello, Pat -
Which thread on your sewing machine are you referring to? With either the top thread or the bottom (bobbin) thread, the problem is most likely due to the tension.
Another reason for the top thread breaking could because the machine is not threaded correctly.
If you have the owner's manual for your sewing machine, check it for the settings for the top thread tension and for the correct threading. Also, check the manual for information on the bobbin (bottom) tension.
This web page gives some generic information on sewing machine tensions:
https://www.thespruce.com/easily-adjust-sewing-machine-tension-2821432
Another option is that you are using old cotton thread to sew with. Over time cotton thread deteriorates and breaks easily. I only know this from personal experience. :)
Jan 06, 2018 | Sewing Machines
Starting to sew basic stitch
Most sewing machines have the same mode of operation. You'll have to learn things such as threading, inserting the bobbins, selecting the right stitches, using the presser feet, setting sewing speed, getting used to the foot pedals, etc. The Brother SE400 is one of the most popular sewing machines and not difficult to use. If you are completely new to using a sewing machine, I'd suggest that you buy a sewing machine book from Amazon. One of my favorite sewing machine books is "First Time Sewing: The Absolute Beginner's Guide: Learn By Doing - Step-by-Step Basics and Easy Projects" by Editors of Creative Publishing international. It teaches you everything you need about a sewing machine. Here are a few videos on youtube that can help you start sewing with your new sewing machine You can also find information from a few websites like the links below. https://crazylittleprojects.com/how-to-use-sewing-machine/
https://www.sewbroidery.com/best-sewing-machines-for-beginners/ https://www.instructables.com/id/How-to-Sew-using-a-sewing-machine/
Oct 06, 2016 | Brother SE400 Computerized Sewing and...
How can I fix the top stich
I like to adjust with 2 colors, then you know which is from the spool, and which one is from the bobbin.
Most bobbin shuttles have a small screw to adjust the tension.
It sounds like your upper thread is adjusted too tight, but only if the loops around it (from the bottom thread) are tight and small. If those loops around the top thread are loose, then you need to tighten the shuttle screw. ;)
I notice this happens to me if I change thread types, also if I sew different thickness of cloth on the same settings. I tend to adjust until the point of breaking thread, then loosen the top a teeny bit.
Sep 06, 2014 | Sewing Machines
Thread looping at the bottom of my fabric on my Elnita 120 Sewing Maching
here is a link for a manual for the machine
http://ifixmachines.com/index.php?page=shop.product_details&flypage=&product_id=1540&category_id=1575&option=com_virtuemart&Itemid=54&vmcchk=1&Itemid=54
try changing the needle--use one that is correct for the fabric being
sewed
the top tension adjustment for the bottom loops
make sure the bobbin is turned the right way in the bobbin case
make sure the top thread has not come off the thread take up lever
Feb 11, 2013 | Sewing Machines
How to adjust tension on a Juki 1541s machine
If you have loops on the bottom of the seam it's your top tension giving you problems.
Sep 01, 2012 | Sewing Machines
Where do i fix the tension at? i understand there is a top and bottom but i just dont understand. The thread keeps getting bunched up. It sews good for a bit then it just bunches up and i dont know what...
why dont you visit this website and read up some of the general info on sewing machines, should help you get started.
http://sewing.about.com/od/sewingmachineindex/bb/sewingmachines.htm
Usually you should only need to adjust the top tension a little bit for different fabrics but generally it should be fine on 5. Bottom tension is set by a little screw on the bobbin case (if yours is a removable front loading type) or sometimes a little dial if fixed horizontal bobbin case design. If machine has been set up correctly from new then bottom tension should not need to be touched at all.
It sounds more like your machine is not threaded properly, causing the thread bunching up to occur. If you don't have a manual you may find a threading diagram at www.sewusa.com or www.singerco.com, the Singer website has instruction manuals for download free for many models.
It sounds like you may be a beginner sewer, in which case, I highly recommend taking a few classes to learn how to best utilise your machine and save lots of frustration too.
Jul 07, 2011 | Singer 1507
I need a sewing guide, basic , starting with threading
Hi! You can find manuals for Husqvarna Viking sewing machines at http://sewingpartsonline.com/viking-sewing-machine-instruction-manuals.aspx. Another place to look for an instruction manual for your machine is http://www.sewconsult.com/husqvarna/husqvarna_instruction_manuals.htm. I didn't find anything about replacement instruction manuals on Husqvarna Viking's website--BUT they have a neat feature called The Sewing Room that offers how-to-sew instructions. (http://www.husqvarnaviking.com/us/3368.htm)
You can also take a look at my Hints and Tips about threading your machine.
Let me know if this helps!
Happy Sewing!
Feb 12, 2010 | Husqvarna Viking 1
How do you thread a kenmore sewing machine I can't figure out how to thread the bobbin for kenmore machine 1385.15343600.  I am a beginner, so I will need pretty detailed instructions. Thanks! Jenny
Put the bobbin on the short metal stick on top of the machine. Unthread the machine. Put the spool of thread on the tall, left side stick on top of the machine. Take the thread and wrap it counter clockwise around the circular, short, metal thing on the left side of the top of the machine, only 180 degrees. Thread the thread through the hole in the bobbin (which should be on top). Press the bobbin to the right, into the little white thing. Pull the turning wheel on the right side of the machine out. While holding the end of the thread, softly press the presser foot so that the thread goes around the bobbin a few times. After that, cut the end down to the bobbin. Now, press the presser foot down and wind the bobbin until it stops on it's own.
Mar 05, 2009 | Kenmore 15343
Bunching thread underneath
When your thread is bunching at the bottom, your top tension is not tight enough, or you did not thread the machine correctly. Make sure the thread goes through the tension blades. Check your manual how to do it properly. you can check if there is any tension by pulling on the thread before threading through the eye of the the needle, and with the presser foot down. By pulling with the left hand and adjusting the tension with the right hand you should be able to feel a difference. Normal setting is between 3 and 5
Oct 12, 2007 | Singer Featherweight II 117
Brother LS-1217 Mechanical Sewing Machine Logo
154 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
