Back to:
Tags:
Yamata FY101-1A
Loud noise is heard every time i turn it on, is...
By paulrmc - usenet poster
Loud noise is heard every time i turn it on, is there anything i can do?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 15, 2006
FixYa! (100)
bmwrider
Rank:Wiz Wiz
Rating: 85%, 1768 votes
bmwri... indicated that his solution for
2049LX Mechanical... Problem
is valid for all Sewing Machines
Could it be the motor trying to turn over but getting insufficient voltage from the foot control. It could be either a faulty foot control or if it's when you try to sew, it could be the motor on the way out.
Please give us more info.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Loud noise is heard every time i turn it on, is there anything i can do?:
I don't want to Accept this solution
Solution #2
posted on Aug 27, 2007
Not Rated (0)
RickE1
Rank:Guru Guru
Rating: 92%, 49 votes
This is pretty much a NORMAL start up noise on all of the 1000 to 1031 series Berninas. Most likely it is the needle bar centering itself. Don't worry about it unless its really bad. If its really bad you need a tech to clean, oil, and adjust it. Or at least adjust it if you can clean and oil it.
Rick
Thank You!
Solution #3
posted on Jun 25, 2007
Not Rated (0)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I just had that problem. As it turned out, it was the parts complaining they were too dry. I would highly suggest oiling your machine (if the areas are not marked, look for places where the machinery goes back and forth a lot, or areas that are already slightly greasy).
The shaft had gotten too dry, so it just stopped (seized up) running. I hadn't oiled it in a while, so I should have known better. After taking apart the bobbin area and making sure nothing was stuck in there, changing the needle in case I bent it, checking all the insides for slipped belts, etc and not finding anything wrong anyplace else , the oil did the job finally.
Thank You!
Solution #4
posted on Aug 08, 2005
Thanks for Trying (70)
Ross
Rating: 0%, 0 votes
Clean machine.
Disassemble machine and clean shuttle.
Thank You!
Can you Help with these Sewing Machines problems?
Sewing Machines
I am trying to wind the bobbin and it says to press the...
Yamata FY101-1A
Bobbin winder on Brother sewing machine 270d has a...
Yamata FY101-1A
Hi there, I cannot find the way to force my RX-V3800...
Yamata FY101-1A
i can see that the loooper stiches on the right side are...
Yamata FY101-1A
The auto threader unit has fallen off. How to I repair...
Loading problems.
Repair Service
Find Sewing Machine Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
