Question about Canon imageRUNNER C3200 Copier
Error 000001-0004 when i switched on my imageRUNNER 2620N it shows this error ihave tried to switched on and off the righthand power switch no help
  • 92 Answers
You have a problem with the thermistor in the fixing unit or is the DC controllerPCB
Posted on Dec 22, 2008
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
IR400 xerox machine shows main swicth on off & E243 code error
What is the error code that is displayed? If it turns right off, hold the main power switch till the display screen display's the error code. Write it down and let the forum know what it is, it will help with a answer.
Sep 06, 2013 | Canon imageRUNNER 400S Copier
After cleaning waste toner container still showing waste toner full i cleaned the bottle and sensor path (transparent) error cleared and still showing wast toner box full
Did you clean the actually sensors in the copier it self???? Where the bottle goes in to place??? Try that and make sure the clear plastic is clean and turn the main power switch off then back on. Good Luck
May 04, 2013 | Canon imageRUNNER iR C2880 Color Copier
E 000733-0001 error, what to do
that error comes from main board or dc controller just try to reset first to reset that error you need to enter to the simulation mode just press the ff. *, 2&8 , * then select COPIER then select FUNCTION then select CLEAR and then select ERROR then press OK then turn off/on the power switch
Dec 14, 2010 | Canon imageRUNNER 5000 Copier
Ihave problem with canon ir 600 .Error show E677
E677 communication error between machine & pc.
Thanks, i am waiting for your feed back & if you satisfied then thumps me please.
Feb 01, 2010 | Canon imageRUNNER 600 Printer
I have a problem with my cannon irc 2620n , just show me this error code E220, i guees is same happen with scan lamp , but i wonna know , wat willi mean , en how can i kan fix up, pleas help me i willi...
Does your "lamp" is turned on when you open the cover? If not it could be that you have bad lamp controller pcb.
Try to manually pull the lamp on right side, and then turn on the copier, if lamp assy is moved in left position withaut error, that means that position sensor is OK, and you need to focuse yourself on "lamp"/ LED
Sep 29, 2009 | Canon IMAGERUNNER 2230 Copier
Printing C4 Envelopes on a CANON 2620N
try to use this link
Aug 09, 2009 | Canon imageRUNNER C3200 Copier
Error 000001-0004 ON MY IMAGE RUNNER 2620N,000001-0003 on3200n
ok that code has nothing to do with your drums that code is for a error in the fuser unit, you have to reset it in this order ADD FUNC key// then hold down the 2 & 8 keys at the same time / then ADD FUNC key again... screen should change to serv mode.... then in this order.touch copier/func/clear/err. ok turn off copier then back on... if code comes back you have a bad fuser unit swap it out clear the code again then try the new unit
Dec 22, 2008 | Canon Office Equipment & Supplies
Canon gp225 showing error e803
What error code is showing on the display sceen " Exxxx" it could be a bad laser unit or a bad polygon mirror ass'y.
Jan 29, 2008 | Canon imageRUNNER 8500 Copier
Canon imageRUNNER C3200 Copier Logo
130 people viewed this question
old marine
old marine
