Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Door lock is on
THE OVEN IS NOT ON CLEAN CYCLE BUT THE OVEN DOOR IS LOCKED AND I HAVE SOME BUNS THAT NEED TO BE BAKED NOW
  • davidfiel146 Dec 22, 2008
    Problem solved - Thank you
  • 1,031 Answers
Hold the lock button for 3-5 seconds or Find the main circuit breaker for your oven. Turn it off for fifteen minutes, then flip it back on. This should allow the door to open. Another thing sometimes, the dial for self clean will hang up, but this should fix it.goodluck hope this helps
Posted on Dec 22, 2008
  • Starnley Johnwells
    Starnley Johnwells Dec 22, 2008
    pls appreciate by rating as fixyaa. thanks
Door does not lock
How to Fix a Door That Won't Lock on a Self-Cleaning Oven ...
homeguides.sfgate.com > ... > Mortgage & Loan Payment Basics
Modern self-cleaning ovens have a locking mechanism to secure the door ... Replace the mechanical lock if you do not have continuity on both microswitches.
Why can't I lock the oven door when baking? ' ShopYourWay
www.shopyourway.com > Derek Austin > Questions
However, the oven will not allow me to lock the door while baking. ... other range that I am aware of does not offer a feature to lock the oven when it is operating.
Dec 28, 2015 | Ovens
Why is the oven stuck with a "Door Locked" error?
Just guessing but did you just use the clean cycle???? During clean, the oven temp gets high enough to trip the door lock safety thermostat. This is to keep owners from trying to open the door when oven is too hot from clean cycle. It sounds like that safety didn't reset to normal when it cooled off and therefore the door is still locked. With door locked you may need to get oven out of the wall and remove top cover to get to the lock system and thermostats. Make sure power is off before doing any of this.
May 02, 2015 | GE JKP30WMWW 27" Built-in Single Electric...
I was baking dinner and the kids walked by and looked oven door. Now i can't get it to open. Its a magic chef/ self cleaning oven
Need to know the exact model to be sure, but usually there is a button that says "lock" or has a padlock icon that you press and hold for a minute or so to lock and unlock.
Also, if they started a cleaning cycle, that will lock the door, too.
Apr 21, 2011 | Ovens
I have an older model double oven by Kenmore - probably 15-18 years old. I was baking bread in foil three days ago and the oven set on bake 325 degrees. (I had been cooking a roast in it for several hours...
Hi.
the oven may have locked in consequence of the self cleaning cycle.
After unplugging, allow the oven cooling down for few hours.
If the is still locked, then the high temperature generated in self cleaning cycle may have damaged temp probe, door latch, or electronic control.
Parts must be tested to discover the fault.
Call Kenmore at the number listed on the owners manual.
Regards.
Mar 03, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Gerangeoven door won't open
Is it in time bake?
Oct 04, 2009 | GE Ovens
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Self-cleaning gas oven
Door lock motor has probably failed.....Self clean on many
ovens can be a self destruct mode. Door latch motors, sensor
probes and even the electronic controls can be destroyed by
this operation. On many freestanding stoves the lock motor is located in the right rear (looking from the front) with a long rod connected to the lock. remove the motor and unhook the rod from the motor cam. Sometimes bending a coat hangar into a hook and sliding from the right side into the lock you can unlock the door.
Jun 02, 2008 | Frigidaire Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
62 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
