Question about Dacor ECS127 Epicure Stainless Steel Electric Single Oven
I think my heating element for the Dacor 6 burner range went
The stove was on and I heard a buzzing then saw a flash in the oven, shut off the oven and then with the light on I saw one corner of the heating element which looked like it was going to explode. Any advice on what is going on and how to have this fixed?
  • Dacor Master
  • 3,463 Answers
Hi there.
You have faulty oven element. and nothing more serious than that.
Simply disconnect and remove the faulty element, and fit a new one.
Problem solved!!!.
Plz rate my solution.Thanks.
Posted on Dec 22, 2008
While cleaning oven I lifted bottom element heard a pop. Now neither the stove or oven will not come on. The indicator lights do not light up either.
The "pop" was the sound of the heating element shorting to ground so naturally nothing works now.
Jan 18, 2017 | Ovens
Kenmore oven 317b6034
It sounds like the heating element is faulty. If it has a short, it will have a damaged place. A short causes a build up of amps until it can't take anymore and then a action will happen like a fuse blowing, which it the noise you hear. You can get replacement elements on Amazon fairly cheap. To fix, unplug the stove. Lift and tug on the element to pull it out of the socket. It is usually easy.
Rich Long
Jan 26, 2014 | Kenmore Ovens
We have a whirlpool double oven, model RBD245PDB12. Oven cooks well but, will not stay off, buzzes long and short intermittently throughout day and night flashing F2 code or E6.
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Feb 13, 2012 | Whirlpool Ovens
Oven temp heats higher than set
The control board is bad. One of the relays has fused and you will need to replace the control board.
Jan 07, 2012 | General Ovens
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
My question concerns a Kenmore glasstop electric oven (model #790.95200100). While operating the oven at 450 degrees and the back right burner at level 5, I heard an audible "pop" and saw a flash of light...
After letting the stove cool, I pulled the entire unit out from the wall and discovered scorch marks on the wall. Opening the back panel revealed a simple fix: the "element on" light module had shorted and was visibly scorched and melted. Looks like a simple replacement (and some wire stripping where the leads fused). Stove currently works with the affected wires capped off (while I await a replacement module).
Sep 14, 2009 | Kenmore Ovens
My oven made a buzzing sound,and and smoke came out form the oven. Now it wont heat up, but the top stove still works...Any ideas? Thanks
fryed switch or fryed burner
if smoke came from inside stove likely the burner is fryed
try setting oven to broil and see if it heats up
if it does replace lower burner
Jul 31, 2009 | Ovens
Oven will not heat
Although I am not familiar with this oven, living in the u/k, I would say that without any doubt the oven element(s) have failed, more so if the fan is working, so I would have hesitation that you replace the suspect element (s)..
Plz let me know how you get on.Thanks.
Jan 03, 2009 | GE JKP15 Electric Single Oven
Dacor ECS127 Epicure Stainless Steel Electric Single Oven Logo
202 people viewed this question
Top Dacor Ovens Experts
Oloyede Monsuru
pvfjr
Level 1 Expert
Tyler T
Level 1 Expert
Are you a Dacor Oven Expert? Answer questions, earn points and help others
