Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Motor capacitor seems to be burnt, motor does not run
170 K model, a black wire exits the motor runs through a capacitor I think, then back into motor/pump. The device says CBB20, 370 VAC, 50/60 Hz and Max Temp 90c. One end of the capacitor looks to be melted with gray colored bubbles. Why would this happen and do I just replace it with a new one?
  • 92 Answers
I would replace that and the high heat limit control, it deffinitly got to hot.
Posted on Jan 23, 2009
Air conditioner comes on but does not blow air out
if the AC is coming on with no air output the problem is that although the compressor is running - the fan motor is not.
This can be because of a 'switch' malfunction, a wire burnt into, a bad fan capacitor or a bad motor.
Of the four possibilities the easiest two to identify are the 'wire that has burnt into,' and a bad fan capacitor. A wire that is burnt into is obvious and so is (sometimes) a bad fan capacitor. A fan capacitor which btw - is a little module (usually gray or silver in color) with wires attached to it. I would check all my wires to it and to the fan motor and anywhere else I could in the unit. Also examine the fan capacitor itself - looking for burnt damage or a 'bulge' in the module which are direct symptoms of a bad fan capacitor.
If it's the capacitor you can remove it making sure you mark your wires in such a way you can connect them up after acquiring a new capacitor.
You can buy capacitors at any Air Conditining Supply house - and they will run about $15-$25 or less.
A bad motor is usually indicated by the motor 'not starting/running' and/or 'the motor being hot to the touch' - there's not much that can be done these days if the motor is bad but replace it. And unless you're really mechanicaly inclined and have plenty of specility tools I would not attempt it. A Service Tech is the best bet here, and you're looking at a repair bill of around $150-$250.
A 'switch' problem is really not that likely but for a nominal fee (usually around $35-$50 you can buy a switch and change out the old one. Like I said this is not likely the problem and I would probably not do this on a hunch.
good luck!
Apr 27, 2010 | Whirlpool ACQ158XP Wall/Window Air...
I have an outside unit mfr Goodman, model # CKL-49-1. The blower motor isn't working. I'm able to hear it attempting to start. How do I check this motor to see if it's bad? Thanks
You have bad capacitor on your unit it may not look bad but chances are it is just get the microfarad rateing of the side of the cap. should be like 55.5 55 7.5 something like that. Also check your fan motor. last. I have changed hundreds of caps this year. Russ
Jul 16, 2009 | Goodman CKL36AR36 Air Conditioner
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
RUNS BUT WHEN THE COMPRESOR COMES ON IT GOES RIGHT BACK OFF AND WILL NOT COOL. THERE IS A BLACK CYLINDER WITH TWO WIRES PLUGGED IN TO IT AND THEY APPEAR TO BE BURNT. THE SYSTEM WILL TRY TO RUN BUT THEN...
that black cylinder is a capacitor check the mfd rating and voltage rating (ex 30mfd 440v)
and replace it andrepair the burnt wires
if it still doesnt work get a boost capacitor(increases starting torque) and install that to the capacitor
Aug 01, 2009 | Heating & Cooling
Our air conditioner does not seem to be blowing any cool air...it basically just seems to be acting like a regular fan
The compressor is probably not runnng. The Main reasons that this will happen
1 - A bad run capacitor (silver or metal capacitor)
It’s either shorted, grounded or open.
If it’s shorted a lot of times it will bulge out, (sometimes slightly)
2 - A bad start kit ( plastic capacitor and Relay connected to it )
The capacitor is either shorted or open
The relay either has an open coil between terminals #1 and #5
Or the relay is stuck.
Any time you change the capacitor or relay you should change
the other, especially if they are over a year old.
3 - A loose, burnt or disconnected wire
4 - Wired wrong
5 Compressor is open (windings burnt open)
6 Low on charge not getting enough cooling back to compressor, (Feel top of compressor to see if it’s hot it shouldn‘t be)
7 Some compressors have a black plastic overload under the compressor cap which could be bad.
Jul 30, 2009 | Heating & Cooling
The unit is a 12000 BTU energy efficient model purchased from Lowes 3 years ago. It is not cooling. The fan runs fine but it just isn't cooling. The filter doesn't need cleaning. What could it be?...
The compressor is probably not running.
4 - Wired wrong
Jul 30, 2009 | Frigidaire 12,000 BTU Compact II Room Air...
No power
i think you have a bad phase or you are not getting the correct volts going in try switching the hot wires red to black and black to red and check each set of windings for continuity
Jun 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Connecting a motor starting capacitor
New Capacitor
herm start on the compressor
fan start on fan motor
c run or power to both compressor and fan
Apr 25, 2009 | Kenmore 75085 Air Conditioner
Craftsman 25 gal compressor -- need MOTOR wiring schematic!!
Hey joe if the motor starts up and runs you have wired it correctly if the capacitors werent correct it would not start up and go into run position
Feb 04, 2009 | Air Tools & Compressors
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
177 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Paul Carew
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
