Question about Zanussi 24 in. DE6744S Free-standing Dishwasher
Not Heating Machine carrying out all cycles but the water is not heating.
  • 1 more comment
  • Terry Warmington Apr 08, 2007
    If I replace the heater is there any other possibilities that would cause the water not to heat ?
    Would you happen to know where the Temp sensor is located on the machine. ??
  • babooooon Jan 20, 2009
    my zanussi dishwasher only goes through a full cycle now and then,plus it only washes in cold water.
    President:
  • 1,462 Answers
Don't replace heater till you have tested continuity across it other items which can cause no heat are module temp sensor
Posted on Apr 08, 2007
Washes indefinitely - water does not heat.
perhaps a call to a service man locally will be your best choice . none I have ever worked on had heating as an option .
Jun 02, 2015 | Bosch Washing Machines
Changing washing machine heating elemant
washers dont have heating elements, they use hot water from the hot water tank, most likely clogged screen at either end of the hot water hose, replace or clean screen(s) check for screen at water valve, bad,weak or burned solenoid on water valve, replace valve, reason wash cycle is long----- water restriction during fill and rinse cycles they are controlled by the water level switch
Jul 09, 2012 | Washing Machines
Hoover vision hd washing machine is not heating water?
Possible failure of the heating element. Please check the continuity of the coil and if possible the voltage to the coil , if there is voltage at the cycle then the element is open.
check this link: heating element.
Jun 26, 2012 | Hoover Washing Machines
Indesit IDl705 flashing lights 1+2 during heating cycle and will not carry on. Have checked pump and all is fine, also checked float device.
If a machine cant do what its trying to do then it wont carry on. It will just sit there.
If its doing this while its supposed to be heating then my money is on the heater being at fault.
Oct 26, 2011 | Indesit W 123 Front Load Washer
Lights on, no wash cycle starts
Check that the machine is heating the water. if it is not, then it is likely the heating element at fault, or one of the two thermostat switches that control it.
It will not continue if it is waiting for the water to heat.
Try it with just a rinse and spin. If it rotates on this, then it will be a heater fault, as no heating is selected in this cycle.
If it will not spin on that cycle, troubleshoot the drive and motor. Check belt condition and motor brushes for wear.
Feb 16, 2010 | Indesit WA 115 Front Load Washer
My dishwasher is sticks in between washing cycles
These mechanical timer machines have to follow a series of logical steps to complete the program - ie, empty. fill to level 1. wash. heat to temp. etc etc
My guess is the machine is not heating, as you say it works for part of the program - or possibly it is not emptying correctly? check water heating element and drain pump.
Program 4 eco is a separate program from 3, using low temperature washing - the machine does stop between 3 and 4 normally and doesnt carry on through.
Jan 30, 2018 | Siemens 24 in. SE64A630GB Built-In...
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
Machine runs for about 5 minutes on normal cycle than stops and flashes f 05. It works on other cycles
F-05 is the error problem for :Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed in between the running machine.
Check the Water Temperature Sensor, Heating Element and Element Relay and Check connections to the Sensor, Heating Element and Relay
in this case mostly the sensor needs replacement some times its only the case of sensor getting loose.
you can get new sensor from
www.repairclinic.com
thanks.
Jul 13, 2009 | Whirlpool Washing Machines
Cycle starts but water doesn't fill past heating elements.
I think that the problem is the water inlet valve if the machine is not filling at all.
If the machine is not filling to the correct level, it may be the float switch.
Apr 27, 2009 | Zanussi 24 in. DE6544 Built-in Dishwasher
Zanussi 24 in. DE6744S Free-standing Dishwasher Logo
245 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Archie Ferrarini
Archie Ferrarini
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
