Question about Philips DIRECTV H20 DTV Receiver
Directv H20 Receiver won't power up
I bought a used H20 unit and called Directv last night. They activated the card and told me to leave it on for 24 hrs. to load all sattelite info. It was working then. This morning it was off and won't power up. Can you help me?
  • 2 more comments
  • whaler97 Dec 23, 2008
    I tried unplugging and resetting and every other thing they recommend, but no luck. The power light will not even come on. I presume the box is dead. Is there any fuse or reset inside the box that I can check?
  • reckerrp98 Dec 24, 2008
    Just got an H20 from Ebay....appears to be DOA...and it won't power up. Anyone have any luck solving this one?
  • Anonymous Dec 30, 2008
    Did you every find a solution? I am having the same problem. I came home and a picture was frozen on the screen. Once I unplugged the receiver to try and reset it the power would no longer come on. No lights at all along the front. Is the remote the only way to turn on the power?
  • Robert DelRaso
    Robert DelRaso Dec 23, 2013
    Mine was a bad power supply - I was getting the AC voltage but on the power supply they have a circuit called bridge rectifier where it converts over to dc after secondary side of the transformer. Thats where I found out the DC side was dead on the power supply. If you rget your power supply board replace more likely you'll be all set.
You have a faulty power supply in the receiver.It has to be repaired,it seems to be a common problem
Posted on Jul 02, 2010
  • Robert DelRaso
    Mine was the power supply board was bad. The AC voltage was OK I read AC on meter but there was no DC Voltage coming out out of the secondary of the tranformer. There's also power transistors and a bridge rectifier circuitry which might also caused the DC voltage to die out - but it would be best to have your power supply board replaced. Worked for me.
    Habit-Forming:
  • 74 Answers
Try unpluging for 1 minute
Posted on Dec 23, 2008
  • 1 more comment
  • ccdhair Dec 23, 2008
    Check your cables. Be sure that you are not using a splitter on your SAT IN and that they are in the correct places.
    Get a volt meter and check cable it should be either 13 volts or 18 volts depending on station.
    Someone takes their time to attempt to help you and you give them a TWO rating?
    It would be better to not rate them at all!
    Thanks for Trying.
How do i hook my direct tv to the philips tv
This is what you'll need to do this:
  • Your DirecTV receiver, DirecTV access card, and your DirecTV satellite dish.
Step 1: You need to write down the serial number that is on your DirecTV access card onto a piece of paper that you will need for future reference. You'll need the number to activate your service with the DirecTV company. Now take your access card and insert it into your box, there is a slot either on the back or front side in which the card with enter.
Step 2: Plug the cable line that is coming from your satellite dish into the "Satellite In" plug on the back of your receiver box.
Step 3: Look for the "Out to TV" port on the back of your receiver, and use the proper cable, which should come with it, to plug it from the receiver into the proper port in the back of your TV.
Step 4: Power up the receiver and your TV (after plugging in the power cable and all) and tune into either channel 3 or 4, depending on where you live.
Step 4.5: You may be prompted to plug in a phone line, in which case you would need to plug in a phone cable into the back of the receiver, but this is only required as a one time thing, you may unplug it after activating your account.
Step 5: Once everything is set up (which it should be at this step), call DirecTV at 1-800-531-5000 to activate your access card, and you will need to use the serial code you copied down from it.
Step 6: After your access card is activated, enjoy watching on DirecTV!
Jan 03, 2011 | Philips Televison & Video
On the weekend my H20 receiver started with continues rebooting,until it got to the point that it stays on the boot with the lights of the 480i,720i,720p and 1080i they are blinking all the time first the...
I'm guessing you have the H20-600. They got recalled. More than likely, your receiver is bad.
If your installation was in the last 3 months, do your technician a favor and call him if he left his number or office number. Even though you have a faulty unit, a 'repeat service call' still counts against him and it could effect his work flow. Call them and they will do what they can to help you get a new unit without harming the technician's stats.
If your installation was not in the last 3 months, call DirecTV. This is pretty much a receiver issue (an issue like a bad connection or switch wouldn't cause this problem). You can probably try to get them to directly mail you a new box (you'll be able to ship your old one back for free) instead of forcing you to wait for a service call. If you have the H20-600, you can probably get the box for free but you'd definitely end up paying for the service call.
Mar 09, 2010 | Philips DIRECTV H20 DTV Receiver
Have green lights but no pic...also unit very hot
those units are known to go out after not long at all try doing a front panel reset by pushing the red button where the access card is you may have to do it several times to see if it will finally come up if not your looking at buying a new receiver
Aug 15, 2009 | Philips DIRECTV H20 DTV Receiver
Direct Tv Receiver No sound Black Screen
unplug the power from the reciever for a few moments. plug it back in and let it load. once its finished turn to channel 201. Usually it the reciever is on an unavailable channel (channel with no programming) when it restarted it will go back to that unavailable channel hince the black screen and no sound.
Jan 01, 2009 | Philips DIRECTV H20 DTV Receiver
HDMI interface issues
If you swapped directv receivers and the problem followed to a different tv then there is something wrong with the directv receiver. Need to run satellite setup again on this receiver to fix. repeat satellite setup is accessible through the setup submenu by pressing menu from the directv remote. look under satellite submenu once in setup
Dec 23, 2008 | JVC HD-52Z575 52" Rear Projection...
DTV H20-600
I do not have an schematic for this receiver. This receiver might not use LM317 or TIP42C but a different voltage regulator, try to locate where the 20 volts line from the power supply and follow it to anywhere near the LNB tuner circuitry. This type of IC is normally mounted on a heatsink.
Lastly if you are a subscriber, give you satellite service porvider a call to get a replacement.
Nov 08, 2008 | Philips DIRECTV H20 DTV Receiver
DTV H20-600
Before we get into measuring any voltage. Read the info from this link and see if that applies to the receiver that is acting up on you.
Nov 02, 2008 | Philips DIRECTV H20 DTV Receiver
DVR S4040R Tivo box
Your hard drive may have crashed. Can you hear any disk activity when you plug in the unit? The hard drive can be replaced, but probably better to either just get a replacement unit (you can get them on eBay for $40 or less) or upgrade to a newer receiver.
Jul 15, 2008 | Samsung SIR-S4040R DirecTV DTV Receiver /...
H20 Reciver power up problems
same problem on two different h20 receivers - called directv and explained the situation each time. since these are leased receivers, new ones on the way.
Apr 19, 2008 | Philips DIRECTV H20 DTV Receiver
Philips DIRECTV H20 DTV Receiver Logo
1,607 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
