Question about Pioneer DJm500 Professional DJ Mixer W/Effects System
No Rec Out on DJM500?
Is it possible to record using a USB interface with a red and white RCA Jack, it worked on my old vestax mixer but wont on the DJM500, if this is possible, what input do you put the RCA jacks in? I've tried connecting my speakers to the Booth Monitor out and the USB interface into the Master Out which someone told me worked, but then i had no sound from the speakers. Can anyone help? Cheers!
2 Suggested Answers
SOURCE: Is it possible to record
yes just use the booth out as your record out..... then you can use the booth volume as another recording level also......... if you need the booth and the master use the XLR master out for your master and then you can use the other RCA master out as you record out .................
hope this helps
Posted on Apr 13, 2011
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
How do i hook up and ipod and/or computer to the Gem Sound CMP500
you need to connect the player to a dj 2 channel mixer using a red and a white RCA CABLE ...(line 1) then into (line 2) ... from pc /laptop ... need a stereo mini jack to 2 RCA (RED / WHITE) INTO back of the mixer ... before turning on please remember to set volume on pc/laptop 80% MAX ... and DISABLE EQ's or FX ... dj mixer has all the EQ / FX needed :
Mar 05, 2013 | Gem Sound CMP500 Dual CD / Mp3 / USB...
How to record from decks to mac air?
get a USB interface sound card, then come out of the mixers REC OUT or BOOTH, in to the USB's LINE IN or MIC.
Then you'll need some recording software installed.
Mar 03, 2013 | Technics SL-1210 Turntable
Behringer mixer Eurorack UB802 is losing partial stereo signal in one channel. When I record (audacity software) I can hear both channels but displays one channel. Is it my computer's audio jack t
Sounds like the output cable from the 802 is not correctly pinned to your input on the computer. Fred is on the right track but you may need to take it a bit further.
It may also be helpful to use a Pro USB audio interface such as the Digigram UAX220v2 (line level version).
If you wish to use the computer's on board sound card consider an IHF/Pro interface that converts balanced audio to unbalanced , and the proper cables. Two 3-wire balanced 1/4-inch from the 802 to the left and right inputs of the interface (XLR Male), then RCA (Red and White) to a 1/8-inch TRS Plug cable onto the the computers audio input.
Henry Engineering's Matchbox HD comes to mind.
Good Luck.
Apr 24, 2012 | Behringer Eurorack Ub802 - Ultra Low-Noise...
Is it possible to record using a USB interface with a red and white RCA ******** a djm 500 to a laptop as it has no rec out
hope this helps
Jan 18, 2011 | Pioneer DJm500 Professional DJ Mixer...
How can I hook my berhinger xennx1202fx to my pc using usb 2.0 will an interface that hooks up to the rca stereo jack then to the pc vi usb work
Refer to a Professional Music For a Cake Walk Pro it a Professional Device you install betwen you PC and your Mixer with Software you install to control all you want ..
Sep 30, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Need to record from turntables to cassette deck.
Bypass the reciever. Just mixer to tape deck. You will get a better recording anyways!
Apr 13, 2009 | JVC Audio Players & Recorders
Playing a ipod on a djm-500
Use a male Twin Phono to 3.5mm stereo jack plug lead. The two phono connectors need to be male, so that they can plug into the red & white line sockets at the back of the DJM 500.
Are available in any audio products store.
Regards
Rob
Jan 24, 2009 | Pioneer DJm500 Professional DJ Mixer...
Recording
I always use either one of the Master Output's (you have two, ones a jack the other a phono so use the one you've not got pklugged into your amp), or the monitor output...assuming you're not already using these for instance in a club environment.
Personally I've been using a phono to headphones jack cable from the monitor putput into my laptop (using Soundforge to record), the advantage being you can change the level of the recording volume using the monitor vol, without affecting your Master Volume whilst you're having a mix!
Hope that helps...
Dec 22, 2008 | Pioneer DJm500 Professional DJ Mixer...
Using the dp-01 as a interface mixer
If you're asking about being able to use the DP-01s knobs and sliders to control the virtual knobs and sliders on some PC recording software the answer would be 'no'.
But if you just want to use the DP-01 to act as a mixer for incoming signals (like microphones and or guitars or other instruments) the answer is 'kind of'. The DP-01 cannot act as a usb interface for your PC, but it can sit in front of a usb interface or sound card and act as a mixer of sorts to mix input from instruments through the monitor outs and then into your computers sound cards or usb interfaces audio-in jacks. You are however limited to two simultaneous inputs though as that is all the DP-01 can handle.
Cheers.
bd.
Oct 20, 2008 | Tascam DP01 All-In-One Recording Package...
Pioneer DJm500 Professional DJ Mixer W/Effects System Logo
71 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
