Question about Hoover SteamVac F5914-900 SpinScrub Upright Vacuum
Getting started?! i got this from a friend who can not tell me how on earth to use it... what do i do? how do i start it up?.. how do i use it?
  • spanrock Jan 01, 2009
    i got this from a firend all that happens is that the water comes out fine. But the bottom tank is not filling up. Dosen't seem to have any sucktion. Juust air blowing out.
  • 125 Answers
I have an Electolux Diplomat that is about 25 years old. A friend recently fixed the switch for me but now the cleaner is blowing instead of sucking. Hose is on correct end. How do I reverse it?
Withould opening your device it's not possible to tell you what's the problem.
Guess you should call your friend or atake it to a repair service to check your vacuum but it's quite probable you should start thinking in getting a new one.
Oct 19, 2015 | Vacuums
The vacuum wont start
It could be many different things. Start with making sure full voltage is coming through the power cord, the switch and all wiring connections to the motor. If all power is ok to the. Motor you will need to check the motor to insure it is working properly.
Mar 01, 2014 | Eureka AirSpeed Gold Bagless Upright...
Dyson high pitch noise
Dear Tasha ,
I suggest that you clean out the tubes and see if any paper has been rolled into the bottom. P.S. Do you know how tall 170 cm is in feet.
Feb 25, 2014 | Vacuums
U5445-900
This is a good start, try this link...
Product Manual Search
Check your power cord and power supply, check the plug is clean and free from corrosion or dirt.
Plug another appliance into the same socket to check there is power at the socket.
Note: Electricity can cause serious injury even Death.
Isolate your power supply from the mains switchboard.
Switch off and Unplug your appliance from the wall socket before attempting any repairs.
If its still under warranty, take it back to the store or manufacturer for replacement.
Call a serviceman to test the appliance for you,
If not you could...
Check your fuse in the device, you will have to dismantle the appliance. Some of them have a fuse to protect the motor.
Get your Multimeter and do some tests...
Test the flexible cord connections
Electrical tests included, visual inspection, Earth continuity, Polarity and Insulation resistance.
Examining cord for Damage
Disconnect flexible cord from power supply.
Check cord along the whole length for obvious damage
1: Visual Inspection
A visual test is necessary before using test instruments to ensure that all specific safety requirements are meet.
Check the general condition and safety of the cord, plug, cord anchorage, terminations and of the appliance itself.
2: Earth Continuity.
The earthing system of an electrical installation must be installed in a manner that will allow circuit protection devices to operate if there is a fault between live parts (other than Neutral) and the mass of earth.
What to check: For class (one) 1 protectively earthed appliances only, test for very low resistance between exposed appliance metalwork and the earth pin of the plug. this resistance should be as low as possible and must not exceed 1 ohm. Note: the Exposed metal parts of a class 2 double-insulated appliance must not be earthed.
Equipment requirements:
A Multimeter (Digital or analogue) Set on a ohm scale or an insulation tester that also has a continuity scale.
A set of leads.
3: Polarity
Why is this test necessary:
An incorrect connection of phase and neutral conductors to fittings and appliances is extremely dangerous and has been the cause, either directly or indirectly of many shocks and fatalities.
What to check:
Polarity tests are carried out to ensure that every single-pole switch operates in the active conductor or the circuit in which it is connected.
A Multimeter (Digital or analogue) Set on the resistance scale when the SUPPLY is NOT connected.
or a voltage indicator set on a suitable voltage rating when the supply is not connected.
4: Insulation Resistance
Why this test is necessary:
All live conductors (including Neutrals) and live parts must be insulated to prevent - Electric shock hazards from inadvertent contact.
- Fire hazards and equipment damage from short circuits.
What to check:
Insulation resistance tests must be made between:
- Active conductors of a poly-phase circuit
- Active and Neutral
- Active and Earth
- Neutral and Earth
The insulation resistance between appropriate components shall be not less than 1 mega-ohm minimum
An insulation resistance tester which maintains an output of 500 volts when loaded with a 1 mega-ohm resistance.
A set of leads.
Different countries adhere to spicific Electrical (safety) Regulations and standards
This information is only intended to enlighten the novice, guide and remind someone already in the field of electrical installations.
DO NOT attempt any electrical repairs unless you have the appropriate background or training.
Feb 02, 2014 | Hoover U6630-900 WindTunnel Bagless...
How does the moon affect earth
The moon is larger than moons of other planets and helps slow the earth to have 24 hours days that we know. It gives us the tides. It protects earth from asteroids or other dangers
Nov 25, 2013 | Vacuums
It didnt come with the owners manuel or attatchments! and i cant get the wand to come out
Hello, call Dyson at the toll free number. Tell them what happen you didn't get the attachment and manuals and warranty card. Give the model number, serial number, where you purchased it and any other information they might require. Dyson has a 5 year warranty on there products. I hope this help you. GB you...stewbison
Walk gently upon this earth, and she will be good to you...
Aug 21, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
The kirby wont start no power
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
Jun 20, 2010 | Kirby G6 Bagged Upright Vacuum
Hi i got a red green and black wire cable and I
Partial solution. Rob's clarification request is very valid, and you shouldn't mess with electrics if you are not completely sure what you're doing. That said, my guess is that you are in Europe (possibly the UK). Confusion can be caused by relatively recent changes in colour codes, so older and newer wires are coloured differently. Basically, red and brown signify "live", black and blue signify "neutral" and green signifies "earth" (or "ground"). So if you are just joining these cables, red goes to brown, and black goes to blue. But what about the green...?  Some machines are designed to be earthed, others are designed to be not-earthed, and it's not clear to me why you have an earth wire in one cable and not in the other. If the green is in the cable that brings power in to the machine, then it should be fixed to some metal part of the machine It can be FATALLY dangerous if you fail to earth a machine that should be be earthed. I repeat, if you are not absolutely sure what you are doing, don't risk it. Anyway, post more details and it looks like there's at least two of us out here who can help you.
Mar 05, 2009 | Electrolux Epic 6500 Vacuum
Blockage
get a longer poker - bamboo for example and clear it that way. there is no magic
Apr 24, 2007 | Electrolux Centralux Vacuum
Hoover SteamVac F5914-900 SpinScrub Upright Vacuum Logo
207 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
