Question about Icom IC-R5 Handheld Scanner
Programming an Icom IC R5 scanner
I own a Icom IC R5 communications receiver this is different to any other I've used due to the limited key pad even though I have an instruction book I can't work out how to get a frequency programmed into the memory channels... Any ideas????
  • Anonymous Dec 23, 2008
    just got mine cant make head or tail of the programming
    Problem Solver:
  • 17 Answers
This is a problem with any scanner which has no keypad..
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Posted on Feb 02, 2009
I have just got the icom ic-r5 and can not get any thing can u help
Posted on Feb 15, 2009
Can someone at the store program my ICOM IC-V8 handhelp police scanner if i take in to them?
Answer is yes.
Look up your local Icom dealer.
They mostly are small communications companies (not big box stores like Best Buy etc) used to dealing with commercial customers but happy to see personal walk in customers too.
I would expect charge for basic programming to be around $50 - $60.
Regards
John
Mar 19, 2017 | Icom Radio Communications
I have been using the IC-R5 for a few years now with no problems except when using it during the summer. If the weather is hot, after being switched on for a period of time the scanner just starts to bleap...
The occilator that "locks" the VFO (like a clock signal) is gong out of range. The higher temps are affecting the temprature controlled occilator. I would send the unit to ICOM for repair.
Jun 21, 2010 | Icom IC-R5 Handheld Scanner
Icom f-10 vhf,wish to programme,have speaker jack plug and software,how do you get the radio into programming modr??????????
Go to ICOM's web site and down load the free software. Otherwise, download the manual there in PDF format. You can go to RadioReference.com for more information.
Jan 28, 2010 | Icom IC-R5 Handheld Scanner
I have an Icom IC-R5 hand held reciever that needs to be programmed. How do I program this reciever? Please Help, Thank You in advance.
It is a bit long winded but, if you are familiar with how to store frequencies into memory numbers, it is almost the same for all the alpha numeric banks, then the rest of the programming is very similar to this method with the additions of tone, code, duplex up or down for each individual frequency etc. My advice is to write your own notes on a large sheet of paper and develop a chart with all your fcys in list order and where you have put them in banks, add how you got there and only refere to the manual if you get really stuck (the manual tends to be too vague and complicated to follow). if your scanner is empty at the moment, this is your best opportunity to learn the hard but best way to programme this lovely beast! ps the scanner is very good once you have mastered it...
Sep 22, 2009 | Icom IC-R5 Handheld Scanner
Ic-r5 scanner will not connect to my xp computer
If you have re-loaded the software and then connected the scanner the pc should say "found new hardware" if this is not the case then the port may be inactive, try loading the software using windows add new progs in control panel and see if this solves the problem. You can check the ports by going into control panel / system / device manager / ports. By the way, are you using the ICOM OPC 478 lead with the inbuilt electronic converter in it!
Jun 17, 2009 | Icom IC-R5 Handheld Scanner
If you where going to Buy one radio which one would you Buy?
I am a marine electronics technician with 28 years experience. I have also been a licensed amateur radio operator for the past 12 years. Based on my professional experience with both brands (Icom and Yaesu), I have to advise you to go with one of the Icom units. The Yaesu is a good radio, but Icom's customer support is far superior. I have had no problems dealing with their service department over the years, something I can't say about Yaesu.
Hope this helps.
Feb 21, 2009 | Icom IC-R5 Handheld Scanner
Programming issues with Icom F21
What you have is a programming issue. The radios need to be "cloned" so they will all work together. You can buy the software on line for about $65.00 then you can change frequencies when ever you want.
Nov 17, 2008 | Icom IC-R5 Handheld Scanner
Icom F21
It's a frequency error. It can be corrected, just give me some time, I need to figure something out first. It might take me a day or two.
Sep 06, 2008 | Icom IC-R5 Handheld Scanner
No fm reception
look for a button called mode and press that, it should switch it to fm narrow (communications) or fm wide ( fm broadcast stations) or am
Aug 13, 2008 | Icom IC-R5 Handheld Scanner
WHY CANT I GET AIR TRAFFIC CONTROL OR AIRCRAFT ON MY IC-R5
The only thing you can do about this problem is to buy a Uniden product.However the problem about this is that it does not get all frequencies unlike this model.
Dec 01, 2007 | Icom IC-R5 Handheld Scanner
Icom IC-R5 Handheld Scanner Logo
1,998 people viewed this question
Top Icom Radio Communications Experts
Steve
johncassells
Level 1 Expert
Are you an Icom Radio Communication Expert? Answer questions, earn points and help others
