Question about Dacor ECS127 Epicure Stainless Steel Electric Single Oven
I turned my oven on (6 burner electric oven range by Dacor) and it was preheating - I then heard a buzzing and looked at the window of the oven door and it was like something was going catch fire. I tried to think if I had anything in there and opened the door and concurrently shut the oven off. The back corner of the heating element was glowing much brighter and flashing than the rest. I was scary - do the elements go in these ovens? I have had it for a little over 5 years now.
  • Dacor Master
  • 3,463 Answers
It is quite common for oven elements to fail.
Disconnect, and fit new one
Plz rate this solution.
thanks.
Posted on Dec 22, 2008
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
    Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
    Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
    Fridgedaire Oven burner sometimes doesn't light
    The ignitor is not working right and is going bad....
    have the repair man replace the ignitor, or DIY....
    Check out this tip about your problem...
    Oven not Working or Oven not Heating
    Oven Problems Replacing the Igniter
    heatman101
    dddddddd76
    May 18, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    I want to re-set high temperature limit control,
    if you open the oven door all the way, then, look under the control panel (where the top of the oven door seats) you will see a plate that has 6 to 8 screws holding it in place.Remove the screws of that plate with a phillips screwdriver.You will possibly need a flashlight to look inside the space where the reset switch is located... but it is THERE. Make SURE that you TURN OFF the circuit breaker or... UNPLUG the range... B4 you proceed to reset. Look for the Red Button on the back side of one of the limit control switches. Press it in till it clicks. (sometimes you'll hear it... sometimes you wont). Plug baack in ro reset your breaker switch, Turn on your oven and see if it works. If it does... then replace the vent plate close your oven door and now your cook"n with gas...well... electricity really.
    May 13, 2010 | Dacor ECS130 Epicure Electric Single Oven
    Frigidaire gallery stove, oven not working,
    Morison,
    The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
    May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    PCS 127 does not heat up. Fan and preheat start.
    We were able to unscrew the plate that sits behind the latch. 6 screws I believe. Look towards the middle back-right side you will see a red switch. Click it twice. Before we put plate back we tested oven and it worked!!! Hope this info will help you. Dacor oven has been a real problem and I'm a kitchen designer. Will never recommend Dacor anything to my clients after many oven issues.
    Jan 25, 2010 | Dacor Ovens
    Oven and coil burners work one time then the next time neither one warms up, try again later and it works again. started last week when the oven preheated put in food to cook and half hour later noticed...
    If this is an electric range, it sounds like you are not geting 220v all the time. check were your cord or house power hooks up to range. You may find one side of the 220 line burnt. Shut off power and repair conections. or call a qulified tech.
    Nov 22, 2009 | Ovens
    Frigidaire FES367ASE Slide in range
    Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
    Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
    I think my heating element for the Dacor 6 burner range went
    Hi there.
    You have faulty oven element. and nothing more serious than that.
    Simply disconnect and remove the faulty element, and fit a new one.
    Problem solved!!!.
    Plz rate my solution.Thanks.
    Dec 22, 2008 | Dacor ECS127 Epicure Stainless Steel...
    Dacor epicure electric oven
    On my Dacor oven whenever I use the self cleaning feature it trips the breaker and the oven doesn't heat up. It can be reset, but you need to take off the front panel and reach way back for the red reset button.
    Nov 04, 2007 | Dacor ECS130 Epicure Electric Single Oven
    Dacor ECS127 Epicure Stainless Steel Electric Single Oven Logo
    189 people viewed this question
    Top Dacor Ovens Experts
    Vitaliy Gins
    Vitaliy Gins
    Oloyede Monsuru
    Jose Pino
    Are you a Dacor Oven Expert? Answer questions, earn points and help others
