Yes i'm on my laptop but my desktop has this message that keeps popping up saying that the system will shut down in 1 minute and there is nothing i can do about it....can anyone help me..
  • 37 Answers
Hi
First check any virus is their or not..
thank you
Posted on Dec 22, 2008
Hp pavillion tx200 running vista shuts down a few minutes after startin up
2018 and still running DEAD VISTA.
all support is gone on XP and VISTA now.
google and hp says no TX200, TX2000 yes
did you skip 1 zero? if yes why, that make help 1000x harder.
shut down has nothing to do with hdd cleanups ever.
nor the broswer, ever
its power issue, only.
i presume you forgot to say LAPTOP?
answering for TX2000 now a laptop.
the all time #1 reason for any laptop to shut down by self.
is overheating
ever clean all lint out of this old PC>?
HP Pavilion tx2000 CTO Entertainment Notebook PC
this is listed on HP unsupported page, all TX are now dead PCs.
it is 10 years old, 2008 made , mostly.
test 1; does the fan run? are all vents clear.
test 2: does PC stay running with that old shorted huge battery removed. running on AC pack only. does it?
if it does not run at all the AC pack is dead. now.
if it runs great the battery is bad as all are this old. no battery lasts for 10 years, bringing us now to battery #2
test 3: get that old RTC coin cell out of the PC now. its NO GOOD.
if not cured yet.
my guess is you have things inside or attached to PC (USB:)
that are shorted.
all models in any PC up to 10 modules of any kind can in fact short.
if they do the PSU (regs) overload and the SHUTS OFF
the prevents fire and prevents need for silly fuses.
in fact the regs are smart fuses (dynamic) inside.
easy so far, can you get this far?
Jun 22, 2018 | HP Computers & Internet
When I plug the unit into power, the CPU fan runs very fast but no boot, and then when I press power on the fan slows down and the PC boots normally. It shuts down in about 30 minutes with no sign of...
Sounds like you are overheating. One way to tell if it's overheating is you say it will run for about 30 minutes then shuts down. When it shuts down try rebooting to see if the boots successfully. If it fails to boot successfully right after it shut down then you are probably overheating. If you wait awhile to let it cool down for 30 minutes or so and if you reboot and it does it successfully you definitely have a overheating problem. If I remember correctly all those compaq sr series have loud and fast running fans. Computers overheat because of three reasons for the most part: 1) A fan has stopped working. 2) The Thermal Paste on the CPU and Heat Sink has dried up or is not thick enough to keep the unit cool. 3) Dust has clogged the fan vents and inside the computer. Fortunately for you desktops don't have to be completely disassembled like laptops to get to the fan, CPU and heatsink. Just pop the case and you'll see the components attached to the motherboard
Mar 18, 2012 | HEWLETT-PACKARD Compaq Presario SR5518F...
I open my laptop up and all that appears is the desktop background...nothing else. How do I get it going?
Force a restart... Unplug any power and pop the battery out. Give it a minute, then pop battey back in, and power wire if needed.. Press power on buttn. Should start up. It may give a black text screen with start up options saying shut down wrong.. Just use Normal Start up.
Dec 09, 2010 | Acer Aspire Notebook PC
My laptop worked fine on night then in the morning i started having problems. These are the problem that i am having my with my HP Pavillion 6910us Laptop. 1. My laptop comes on but cuts off after 5 to 6...
Hi
At some point if you can get the computer to stay up for a while, you should go into control panel and check your
POWER settings. The other thing you should try if you haven't already is to shut the computer off and pull out the battery. Then after a minute re-install the battery and see
if that helps.
Good Luck
Joe
ps: If I come up with any ideas I will post.
Mar 04, 2017 | HP Pavilion Dv6910us Notebook
I have a dell latitude laptop my problem is, it takes over 5 minutes to power off. I click shut down screen goes to desktop screen no icons about 5 minutes later it says its shutting down screen goes black...
There may be nothing running in task manager that you can see but there is still something running,My advice is to take it to your local Geek Squad or preferred computer tech you most likely have a virus that is slowing down your computer process.
Sep 24, 2010 | Dell Latitude D531 Laptop Computer PC...
MY Dell laptop running XP will run in safe mode but shut down after 2 minutes in normal operation. When I start it defaults to safe mode but allows me to restart and comes up temporairialy in normal mode...
Hi Friend, If your system only boot up in safemode, you should try a Clean Boot of your machine to help given steps, 1- click Start, and click Run. The Run window appears(From the safemode desktop) 2-. In the Open box, type msconfig and then click OK. The System Configuration Utility appears. 3- go to the General tab and click Selective Startup radio button. 4- Un-check all options with the exception of "Load System Services" & "Use Original BOOT.INI". 5- Click Apply, and then click Close. 6- When prompted to restart the computer, click Yes. Now if it boot up in normal mode you should get a message to the effect of the changes you just made in msconfig, don't worry about it, but make sure you put a check in the box that says "Do not show me this message again" and click the "OK" button.
Thanks,
Jan 01, 2010 | Toshiba Satellite A100-S8111TD Notebook
CD drive not working
Based on your indication the CD drive is clean, and you know the cables are attached to it, inside the computer. (Flat ribbon IDE interface cable, and 4-pin Molex connector power cable)
1.Go to Device Manager
Left-click on Start. Right-click on My Computer. Go down, and Left-click on Properties. Left-click on the Hardware tab. Go down, and Left-click on Device Manager.
Left-click on the + sign to the left of, DVD/CD-ROM drives.
Right-click right on the name of the CD drive.
(Example: Lite On DVDRW LH-20A1P.
eMachines Support indicates the T5212 has a DVD burner drive, and a CD drive. Right-click on the CD drive name))
In the drop down list, Left-click on Properties.
Left-click on the Driver tab
Go below, and Left-click on the Update Driver 'button'. Now go below, and Left-click on OK.
Close all windows, go back to your desktop screen.
Shut your computer down normally. (Start>Turn Off Computer>Shut Down)
Do Not Restart. We need a 'Hard Shut Down'.
Wait 1 minute, turn your computer on.
Still doesn't work?
Let's play hard ball.
2.Go back to Device Manager. Left-click on the + sign to the left of DVD/CD-ROM drives. Right-click on the name of the CD drive. Left-click on Properties. Left-click on the Driver tab.
This time go down, and Left-click on the Uninstall 'button'. Go below, and Left-click on OK
There will be a Microsoft 'squawk box' that comes up. "Warning you are about to uninstall this device"
Left-click on OK. (It IS okay!)
Close all windows. Shut down your computer normally. (Again, we need a 'Hard Shut Down'. To Restart a computer is known as a 'Soft Shut Down')
Wait 1 minute. Turn your computer on.
After Windows loads all the way, and all of your Start Menu programs have loaded, you should see a pop-up out of your system tray. (Bottom of Windows desktop screen)
"Found New Hardware", and perhaps another one, "Found XYZ CD drive". (XYZ = the CD drive name)
No still?
The driver for your CD drive, is located within the Windows XP operating system on your computer.
If your CD drive does not work now, I suggest it has failed.
Drives such as Optical drives, and Harddrives, are mechanical devices. Their 'Lifespan', is rated in so many hours of usage. Your CD drive may be at the end of it's 'Lifespan'.
Oct 04, 2009 | Sony VAIO PCV-RX462DS PC Desktop
There are sentence say connect to i-tunes and i
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Sep 23, 2009 | Apple iPhone 3G
My dvd home theatre system ht tx75 keeps shutting down
protection error message means that your unit's fan is not working
it is a feature to keep your unit from overheating
check if there is anything blocking the fan of your unit from rotating
if problem still persist replace the fan
May 28, 2009 | Samsung HT-TX72 Theater System
Computers & Internet Logo
20 people viewed this question
Alun Cox
David Payne
David Payne
