Question about Toshiba 57H81 57" Rear Projection Television
Toshiba 57H81 57" TV Power
I have a Toshiba 57H81 57" TV . The red power supply light which is normally on when the tv is off is flashing and the TV won't power on. I tried unplugging and replugging and different wall sockets and that hasn't helped. It still won't turn on. Any ideas of what could be the problem and how to fix it?
  • bcclbegley Dec 22, 2008
    We woke up this morning to the same exact problem. I'm not sure that ours is the same model, but it looks similar and it's the EXACT same problem.
  • bsyds73 Dec 28, 2008
    I have the same problem, but mine will sometimes turn back on after being unpluged.
I have a toshiba 55hx70 same problem,repair guy just left said it was the power supply and wasnt worth fixing 350 to 400 dollars The tv is 9 years old and they wouldnt even take it to shop. Its been a great tv firs thing to go wrong.. Wo nder if I could replace it myself???
Posted on Dec 29, 2008
The menu keeps flashing on and off. I have turn the tv off 4 or 5 times but it still keeps flashing the light on the bottom of tv goes blue then red really fast
How old is your TV? This normally indicates a power problem. It could be any of the following: power supply on the TV, faulty power strip, faulty wall outlet, faulty circuit board inside the TV, faulty power cord/plug, bad airflow/clogged vents restricting air movement into the TV (can cause intermittent power faults),bad sensor inside TV. This is not completely inclusive by any means. It does mean that you should have it looked at. Someone knowledgeable/skilled should be able to determine the cause fairly quickly using a multimeter.
Apr 25, 2017 | Televison & Video
Red light flashes on tv but wont turn on
Please take this steps on how to determine the problem:
1. Open the back cover.
2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
4. If the power supply output is normal..The problem could be on the main board...
5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope this solution will be helpful..
Jun 07, 2012 | RCA Televison & Video
My tv has a red button on the front that flashes and no picture comes on when we try to turn it on with the remote
The Toshiba sets were well known for bad capacitors in the power supply. I recommend getting it assessed.
Mar 19, 2012 | Toshiba 32AX60 32" TV
Hi Hi have a toshiba regza 32av555db that was working fine however it will now not turn on, the red standby light is flashing and the green on light flashes also. I have tried a different remote for the...
Problems it is not the tv remote control.This tv have a dying power supply board,that the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jul 11, 2011 | Toshiba 32AV555DB 32" HDTV-Ready LCD TV
Does not power up, red light next to on/off button just flashes. I rebooted the tv and it still has the same problem.
Hello
Some of the secondary voltages [low voltages of 12V and 8V], either one among the said is missing inside the circuitboard of your TV. It may be due to a component [Regulator] mistake, or loose sodering joints. You just give a mild hit with your palm, on the cabin of the TV while it stops. Do not hit it with any hard material. Use your palm only for this. If Tv comes alive again; it means that there is a loose contact inside the main board of the TV. Just find the exact point, and resolder it. If this doesn't help, check for the low tension voltages. As the red light flashes, means 5V power supply inside your TV is ok. Check the other two and the main supply rail, normally 125VDC, and related componets fitted with it. There may have a small value resistor in series with this power supply rail to LOT [usually less than 2 Ohms or so]. It will generate a small amount of heat while working. Check its sldering contact also for loose contact.
Oct 18, 2010 | Toshiba 32HFX71 32" TV
Toshiba big screen tv
I have a 50" big screen tv by toshiba. I need a replacement protective screen or a place I can get it.
Aug 26, 2008 | Televison & Video
Toshiba TheaterView
Called Tv tech. He said it was the power supply connectivity. common problem in rear projection Tv's. Cost to replace was anywhere between $300.00 and $400.00 dollars. Time for a new tv :-(
Feb 21, 2008 | Toshiba 50A60 50" Rear Projection...
Tv shuts off
My TV turns on and off constantly, it wont stay on for more than 2 secs. Please help.
Aug 25, 2007 | Toshiba CN36V51 TV
Toshibe CF32G50 - Red Flashing Light
YOUR SET IS TRIPING MAYBE POWER SUPPLY IN TV SET
Jul 11, 2007 | Toshiba CF32G50 32" TV
Toshiba 57H81 57" Rear Projection Television Logo
240 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
