Question about Pioneer DJm500 Professional DJ Mixer W/Effects System
Recording Hi i was wondering if it is possible to record from a DJM500 mixer i cant see that theres a Record Output
I always use either one of the Master Output's (you have two, ones a jack the other a phono so use the one you've not got pklugged into your amp), or the monitor output...assuming you're not already using these for instance in a club environment.
Personally I've been using a phono to headphones jack cable from the monitor putput into my laptop (using Soundforge to record), the advantage being you can change the level of the recording volume using the monitor vol, without affecting your Master Volume whilst you're having a mix!
Hope that helps...
Posted on Apr 02, 2009
I want record 3 person's tolking with penasonic camera. there in only one micinput. how do i get in other 2 mic's sound
use a mike mixer that has more thatn 3 inputs and 1 output
make sure the one output matches your recorder
Oct 30, 2013 | Tascam DP01 All-In-One Recording Package...
Recording levels are low
There's no record level adjustment on the Masterlink. Increase the output level of your mixer, or add a variable level preamplifier between the mixer and the Masterlink.
Or, use the level adjustment on the Masterlink once the recording has been done, and before you write it to CD, either with level control or DSP normalisation
May 23, 2013 | Alesis MasterLink ML-9600
HOW DO I RECORD MY VOICE ON THE CTK-900 CASIO KEYBOARD?
Not according to the manual. It was not made that simple.
However, there are a few ways you can produce a recording of the music with your voice. Either mixing with the PC or Mac sound program, or using the output of the keyboard into a suitable mixer with preamp so you can get your levels correct- then record the output of the mixer to computer, or to tape.
Audacity is a wonderful little Sourceforge program to consider using along with the suite of programs and widgets Casio includes with the 900.
Apr 06, 2012 | Casio CTK810 61 Key Keyboard
I have a st69 and every time I record, the vocals while recording sound very chorus like in the headphones, but they sound fine when I listen to the play back, please help.
Check the mixer settings to be sure you are not sending multiple mixes or effects to the monitor (headphone) output. The output used for recording does not necessarily have the identical sound sources and mixing path as the headphone, so make sure the headphone is monitoring the same signal as the recording output.
Feb 07, 2011 | Sterling Audio ST69 Microphone
Is it possible to record using a USB interface with a red and white RCA ******** a djm 500 to a laptop as it has no rec out
yes just use the booth out as your record out..... then you can use the booth volume as another recording level also......... if you need the booth and the master use the XLR master out for your master and then you can use the other RCA master out as you record out .................
hope this helps
Jan 18, 2011 | Pioneer DJm500 Professional DJ Mixer...
HI, i cant get my mackie to record any audio, instrumenta, nore to record for live oline recording. what should i do?
you need a recording device to do it, a recording software and most of all an
interface.
Dec 05, 2010 | Mackie 2404-VLZ3 Mixer
Can't record vocals
You can use any mic you want but you have to go to the soundcard mixer and enable the source for recording from the recording properties. If you have a separate soundcard not the onboard one usually it will have it`s own mixer software so you open that up and set it to record from the microphone input if that`s where your mic is inserted. If you use the onboard sound card then go to control panel - sound and select the device you want and also set the recording source. In sonar you have to right click on the track in the left part of the screen. This brings up the properties for that track. The you select the sound card input and output for that audio track.
That shoudl solve your problem.
Of course you will get a much better result if you use a good mic plugged into a mixer or pre amp and send the source into the line in of your sound card and adjust the rest accordingly.
May 14, 2009 | Cakewalk Music Creator 4
DJ EQUIPMENT
Lot of possibilities.
The DP-01 is like a mixer with built-in recording capabilies. You could plug your tunrntables into your DP-01 inputs, assign the inputs to tracks(channels) on the DP-01, and then output those tracks to two channels on your mixer (which would be connected to your PA.
Alternatively, you could plug the outs from your mixer into the DP-01 either by routing individual channels from the mixer into the DP-01 inputs, or outputting the mix into a single track (or into two tracks in stereo on your DP-01). Just assign the DP-01 inputs as usual to the tracks you want to record onto.
Those are just a couple of basic ideas. You could also route a DP-01 track (or the whole mix) back out the DP-01 send loop and through some external processors and then back to tracks on your DP-01, or you could do this through the mixer and then record the final result on the DP-01.
Jun 28, 2008 | Tascam DP01 All-In-One Recording Package...
Realtek HD Audio Troubleshhooting?
I had the same problem with both my Biostar 550 and Gigabyte P35 motherboards, both of which use Realtek ALC888 HD audio. Its got lots of fancy eq and effects but a crippled record mixer with greyed out sliders. I emailed realtek and they responded that its a Mixer Record type audio mixer only and follows microsofts HD audio specification...so blame microsoft or Realtek...or both. There is NO workaround for this.
The solution is to use a sound card with AC97 audio or if youre lucky enough to find a newer one with HD audio and a less crippled mixer. Problem being the industry seems to have embraced Realtek who seems fixated on offering partially disabled mixers. I purchased a Diamond Xtreme 7.1 sound card from officmax for 30 bux. They also have a 5.1 version for 20 bux. The main rec output is set to a fixed level but the individual rec. sliders ARE enabled. Recorded audio ends up being about 10db low but you can always boost it n post production using a recording program like audacity (which the sound card comes with - there are newer versions of audacity available so dont use the included version). - The only way to get FULL functionality
- ALL sliders is to find an older AC97 audio card. There are good ones and bad ones so it may take a few. Try the Diamond Xtreme card first and if you dont like it you can always take it back. This link is for the $30 verson. http://www.officemax.com/omax/catalog/sku.jsp?skuId=21080508&searchString=diamond%20xtreme&category_Id=null
Dont hesitate to send Realtek a "concerned" (not nasty) email about this. Hopefully If they get enough...they MAY take it seriously...but I wouldnt cross my fingers.
Good luck,
Dave
May 21, 2008 | Microsoft Windows XP Professional With...
Recording not right
Check the recording buffer latency on your recording software. And so you know, you should max your ram out with that soundcard. or have everyone record there parts in as, 5 ins is alot for a machine to process, especially if youre recording to 1 track..brutal, and the final recording will be real muddy.
Keep me posted.
Oct 25, 2007 | Behringer (UCA202) Sound Card
Pioneer DJm500 Professional DJ Mixer W/Effects System Logo
352 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
