Question about Emagic EMI 6|2m External Sound System
Am having have a problem with my 6to4 adapter and i can brows
Acer laptob modle no-4310 i have audio driver plz solve this problm
Posted on Dec 23, 2008
Can not pair to my computer.
If you see this status associated with a Microsoft 6to4 Adapter on a computer running Windows Vista in a home environment, you may be able to uninstall the 6to4 adapter to resolve the problem. To uninstall the 6to4 adapter, right-click it and click Uninstall. After you uninstall the 6to4 adapter (or if the problem is not associated with the Microsoft 6to4 adapter), it may also be helpful to run an automated troubleshooting service from the Microsoft Support Web site (http://go.microsoft.com/fwlink/?LinkId=192795).
If your computer is part of a business network, consult your network administrator for the most appropriate action. There may be company tested drivers for your computer or there may be other considerations before you disable any IPv6 components.
Jan 18, 2016 | Computers & Internet
Repair microsoft 6 to 4 adapter on a toshiba satillite l355-
One solution is to uninstall and reinstall the device driver in the device manager.
To do this, press the Start button, then right click on the "Computer" entry, and the "Manage" entry.
Double click on "Device Manager" and find the 6to4 adapter. Right click and select "uninstall"
Restart your computer.
In the Device Manager again, in the top bar select "Action" then "Add Legacy Hardware" then click next. Select "Install the hardware that I manually select from a list" > Network adapters > Microsoft > Microsoft 6to4 Adapter. Then click finish.
Restart again.
If this does not fix the problem, disable the error by opening the start menu, typing in "cmd", right click and "Run as administrator".
In the window that pops up, type
netsh in 6to4 set state disable
then press enter. And restart your computer.
Oct 08, 2013 | Toshiba Satellite Computers & Internet
I need to reinstall microsoft 6to4 adapters
microsoft 6to4 adapters? Not sure I know what that is?
Dec 01, 2012 | Computers & Internet
What is the driver for microsoft 6to4 adapter #8
Hi Friend,
6to4 adapter is a component used for transmitting IPv6 packets trough IPv4 network correctly.
In some scenarios, there will be a code 31 or code 10 error appearing beside this component. A possible reason is, the network adapter doesn't support this feature. You may update the driver for your network adapter or chipset, and then try to Uninstall and reinstall the this component.
To Uninstall the component, right-click the item in Device Manager and select Uninstall.
To reinstall the component, in Device Manager, Action - Add Legacy Hardware - Next - "Install the hardware that I manually select from a list" - Network adapters - Microsoft - Microsoft 6to4 Adapter - Next - Finish the wizard.
If the steps above doesn't solve the problem, your network adapter is not a supportive one for this component. You can completely ignore this error, if there isn't IPv6 network deployed in the environment. The error won't affect your system.
To remove the error message, please right-click the Command Prompt and run as administrator, type the command netsh in 6to4 set state disable, press Enter. The component will be disabled and hidden.
Regards
Chiranjeet
Sep 17, 2010 | Computers & Internet
6 to 4 adapter no working and 1 Sat adapter #2 adapter not on, so I cant connect to internet, how can I fix this
I would like to bring to your notice one of the issue that came across with a Vista based PC of a EU who reported in his mail that in "Device" manager their are 6 to 4 adaptor is listing by name itself and for this he is unable to install any drivers as it is showing that the drivers are not installed for it. Even though EU is able to browse the internet.
Normally the above issue is related to TCP/IP transmission protocol that uses by Vista. As Vista by default support IPv6 TCP/IP protocol for data transmission over the network. 6to4 adapter is a component used for transmitting IPv6 packets trough IPv4 network correctly. If the drivers for this component is not properly installed or corrupted there will be a code 31 or code 10 error appearing beside this component. You may update the driver for your network adapter or chipset, and then try to uninstall and reinstall the this component as mentioned below. I am enclosing a snapshot of the issue along with the mail so that you can also have a clear idea of the issue.
=======Uninstalling 6to4 Adaptor==========
1. Click on Windows icon, and enter device manager into the Start Search field.
2. Right Click on all 6to4 adaptor and select uninstall from the droplist.
=====Reinstalling 6to4 Adaptor===========
2. From the device manager window select "Action".
3. Select "Add Legacy Hardware".
4. Click on Next.
5. Select "Install the hardware that I manually select from a list".
6. Select Network adapters from the window.
7. Select "Microsoft" from left window.
8. From right window select "Microsoft 6to4 Adapter"
9. Click on next and finish the wizard.
After performing the above steps issue shoule get resolve. If the issue persist then, I request you to disable this device in device manager. By disabling this it will not effect your internet browsing or your wireless conectivity, as Microsoft also confirm this in their database. In order to disable this device perform the below said steps.
1. Click on Windows icon.
2. Select Accessories.
3. Right click on "Command" prompt.
4. Select "Run as administrator".
Once the command window open, type the below said command.
After typing the above command press enter key on the keyboard.
After performing the above steps restart the PC.
Apr 05, 2010 | E-Machines eMachines Desktop PC
6t04 code 31
To solve this problem with 6To4 adapter device with code 31, make sure you do the following:
1). Make sure you have all the updates installed for vista, such as, Important and Recommend updates.
2). [Right Click] my computer icon, and select (properties).
3). Select (Device Manager).
4). [Right Click] on the 6To4 icon, and select (Update Driver Software).
5). Click [Browse my computer for software drivers].
6). Click [Let me pick from a list of device drivers on my computer].
You should see the Microsoft 6To4 adapter listed?
If not you must uncheck the [] box show compatible hardware.
7). Then scroll down the list of Manufacture until you find (Microsoft), NOT Microsoft Corporation!
8). Click on (Microsoft) as the Manufacture and scroll down about two clicks, you should see 6To4 adapter.
9). [Left Click] on Microsoft 6To4 adapter and (Click Next), it should load the drivers as normally.
Dec 04, 2009 | Dell Inspiron 1545 Notebook
6T04 Adapter failure
That 6to4 adapter has been a problem for as long as I have been aware of it but I only have that issue when I use my print server. I don't believe the 6to4 is your actual wireless. Are you using a wireless print server?
Sep 04, 2009 | Packard Bell 1580509280 Network Adapter
6to4 adapter not working...
Check the device status under the Device Manager. if the status of the device was just "drivers were not installed..." you may simply click on update driver button on the same window. If the error is code 10 or device could not start, the problem has something to do with the hardware. call the manufacturer of your laptop and check the warranty if it is still covered.
Jul 16, 2009 | Enterasys Network adapter
Emagic EMI 6|2m External Sound System Logo
Top Emagic Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you an Emagic Computer and Internet Expert? Answer questions, earn points and help others
