Question about Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA
Freezer just stopped won't even turn on
-18 degrees outside plus wind blowing against the wall my freezer just stopped, I mean there is nothing no click no attemped to start It has a Matsushita-Embraco Elec,ind compressor p/n 4-35031-001 sticker SD43C90JAV6
  • Todd Born
    Todd Born May 11, 2010
    is the ionside light working? also how cold is it around the unit.
  • 943 Answers
Hi with those temperatures It wont come on Its too cold. It will work ok
Posted on Dec 23, 2008
Why is the temperature fluctuating.
Service engeener always checks the average temperature inside freezer or refrigerator compartment. When you turn on freezer, the compressor starts to circulate gas through the system and the temperature in the freezer is decreasing (go to minus). When inside of the freezer reaches the set temperature the compressor is switched off and temperature will increasing. What will be the difference of inside temperature depends on the type of refrigerator and type of thermostat or sensor and moves to max. 8-9 degrees. With the advent of new "No Frost" refrigerator, this difference was reduced to only a few degrees Celsius, thanks to the fan inside the refrigerator and NTC sensor.
So 29 + 14 = 43; 43/2 = 21.5 which means that your average temperature of -21.5 which is not too much deviation from the set temperature of -18 and I think that is ok.
Dado
Jun 13, 2014 | AEG 10.35 cu. ft. / 293 liter Upright...
Freezer wont go below -9 degrees
This information does not mean anything to us if you didn't specify the model. In what temperature range a freezer works we knew thanks to the stars.
One star (-6 degrees centigrade) is perfect for making ice cubes and is sufficiently cold to keep food for three or four days.
** Two stars (-12 degrees centigrade) stores food for fifteen to twenty days.
*** Three stars (-18 degrees centigrade) will keep food safe for up to three months.
**** Four stars (below 18 degrees centigrade) means that the compartment provides the ideal conditions for freezing down fresh and pre-cooked foods.
Dado
Oct 27, 2013 | AEG Freezers
My Kenmore Freezer, 5649215011, won't get cold
Yes it is. You probably have a bad capacitor since it probably as been outside for this long. It is subject to aging even when not in use. This should be an inexpensive job.
Feb 13, 2013 | Kenmore 5 cu. ft. / 142 liter Upright...
Danby DUF408WE Upright Freezer not working
Does the compressor feel warm to the touch. If it does, it will be proof that the thermostat is calling for cooling and is probably good. For the obvious questions: Is the freezer in an area below 80 degrees F, is the wall outlet in good shape and not hot to the touch, is the freezer plug not blistered around the prongs, is the door gasket against the face all the way around the mating surface on the chasis. If the compressor is hot, listen for a click every 2 to 5 minutes. If the click is present the starter is your last best hope. The click is the compressor trying to start. Without the proper tools you are pretty much up against a wall. One last suggestion is to check for loose wires under the compressor terminal cover. I would suggest you look up the compressor manufacturer for a visual on cover removal. Dont forget to unplug before attempting compressor cover work. I hope you havent tried to put screws through the outside walls of this freezer or damaged the shelves inside. Both are fatal for the freezer and no repair can be made. Good luck.
Jun 03, 2012 | Danby DUF408WE Upright Freezer
Freezer only cools to 34 degrees Took outside ,cleaned out still not reaching proper temperature(10 to -10 F). Hovering around mid 30"s. Problem first noticed when nothing would freeze in doors. Seal...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned warmer which makes REF. colder or vice versa.
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Aug 01, 2011 | GE 20.3 cu. ft. / 575 liter Upright...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer due to brown out then power restored now low temp alarm
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
Feb 14, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer stops and start
ice cream is always the last to freeze and a temp of minus -10 degrees is usually required to get it to get hard. if you put the ice cream in the door it will be especially tough to freeze. a good thermometor is a good investment as you can observe the temps. usually ten degrees or 20 degrees is what they run. yes they do cycle on and off as long as they hold temps thats good. the outside of the freezer gets warm because the hot compressed refrigerant is spread through piping near its surface giving up its heat of compression . setting the stat to max will freeze the ice cream eventually but utility bill suffers . good luck
Jun 03, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Haier 5 cu. ft. / 142 liter Chest Freezer HCM050PA Logo
207 people viewed this question
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Mike Squire
Are you a Haier Freezer Expert? Answer questions, earn points and help others
