Question about Asrock P4VM890 Motherboard
Asrock K7S41/K7S41GX problem
I have a very frustrating problem with the above mainboards - put a system together in usual fashion - have built several machines now, this is first AMD system though - no boot - 3 beeps - checked beep codes = mem read/write error. Cutting a long story shorter, I now have replaced board, chip, memory, and run all combinations of original and replacement items. Jumpers are correct for FSB vs. chip speed vs.memory. Drives plugged and unplugged, monitor the same, keyboard and mouse also. Even tried power supply from another machine. Still always those 3 beeps. There must be something fundamental I've missed surely. Anyone come across a similar issue. Thanks in advance. Chandla installed a Asrock p4vm890, checked bios, installed netcard, rebooted. Not getting anything but 3 beeps.
  • 15,935 Answers
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Posted on Dec 22, 2008
  • blueextc3221
    blueextc3221 Feb 13, 2009
    Thanks for using FixYa. Your Rating of my solution to your problem was THANKS FOR TRYING. I would appreciate a re-evaluation of your rating - as the answer I gave was correct. There are not many experts that provide answers to FREE questions beacuse anything under HELPFUL reduces their overall rating percentage.
    The description FixYa uses for the rating system is misleading - a THANKS FOR TRYING means the answer was not helpful in solving your problem.
    We are working toward a better rating description to help alleviate the bad ratings.
    I took the time and answered your question to the best of my ability and request a change to at least HELPFUL.
    Thank you.
I lost my mother board CD sis 963LUA
Hello try the site here:
http://www.asrock.com/mb/SiS/K7S41GX/?cat=Download
Please select your windows system.
Some of the files maybe needs to be unziped, before you install them.
Or this site:
http://www.foxconnchannel.com/ProductDetail.aspx?T=Motherboard&U=en-us0000111
The drivers should fit the mainboard.
If not, visit the mainboards or the pc`s homepage in search for the drivers.
Good luck.
Jan 31, 2013 | Computers & Internet
I am putting together an ASRock mobo. I am told NOT to use a 3.3v AGP card. as it will damage the board. ASRock K7S41 / K7S41GX. N Videa replys are not specific. I have 3 AGP video cards and have no idea...
Hi, you can download a manual here:
Your mainboard has AGP slot.
  • 1 slot for AGP 8X/4X 1.5V
  • http://www.asrock.com/mb/overview.asp?Model=K7S41GX
    http://www.nvidia.com/page/geforce2mx.html
    The to first one is AGP.
    The last one is PCI-E
    Graphics Processor: NVIDIA GeForce2 MX 200
    NVIDIA Model Number: 8859
    Memory: 64MB
    Outputs: DVI
    Interface / Slot Type: AGP
    • Installed Memory: 32
    • Interface Type: Video - 15 pin High-Density D-shell (VGA)
    • Video Chipset: NVIDIA GeForce2 MX400
    • Slot Type: AGP
    GeForce MX4000 Bus Type PCI Slot Memory on Board 64 MB DDR RAMDAC Support 270 MHz Max. Resolution 2048x1536 8/16/32 bit colors with 60Hz (Analog) Memory Interface 64-bit Display Output Dual VGA
    (1x On-Board VGA,
    1x MD9-pin port supports 1 x VGA) Operating System Support Windows® XP/2K/98//Me/NT 4.0
    Aug 28, 2011 | Asrock K7S41GX Motherboard
    My onboard VGA doesnot work anymore on my K7S41GX What can i do?
    You can buy an AGP video card. Your motherboard supports AGP 8X/4X with 1.5V for video card as an expansion card.
    Nov 02, 2010 | Asrock K7S41 Motherboard
    MB ASROCK K7S41 booting, but BIOS not Showed and Pan was show on. I was checked VGA card, Memory, and HDD but still do that. how to solve this problem ?
    Remove Battery and Memory Unplug push the start button Let it sit for 5 or 10 min Put back together and run...Hope this helps
    Apr 08, 2010 | Asrock K7S41GX Motherboard
    Can i use ddr 400 on the k7s41 gx
    The official specs say that it supports DDR333 tops. DDR400 should work fine but at the speed of 333.
    Oct 12, 2009 | Asrock K7S41GX Motherboard
    ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
    I had 3 beeps, pause, 3beeps, pause and so on.
    Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
    I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
    Aug 27, 2008 | HP Compaq dc5100 PC Desktop
    Powers on for a second and shuts down
    6ce1e4e.jpgmanual:
    http://72.14.253.104/search?q=cache:rM03zfMddCsJ:ftp://download.asrock.com/manual/K7S41GX.pdf+Asrock+K7S41+Motherboard+manual&hl=en&ct=clnk&cd=2&gl=au
    i am getting you this manual cause you can check what i am about to tell you here. make sure the jumper plugs are on the correct pins and that the BIOS settings match the configuration you have and especially make sure the power,reset,led,led2,powersw,speaker,sys pins that come from the power button and so on are over the correct pins on the motherboard!
    good luck!
    Oct 10, 2007 | Asrock K7S41 Motherboard
    Asrock k7s41gx
    it seems to me its a dust problem. any beeps?
    Sep 13, 2007 | Asrock Motherboard K7S41GX for AMD...
    Asrock P4VM890 Motherboard Logo
    512 people viewed this question
    Top Asrock Computers & Internet Experts
    David
    David
    Computer Links
    pankaj rautela
    pankaj rautela
    Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
