I can not hook up my Canon XH-A1 3CCD HDV Camcorder to my computer
  • ryantmer May 11, 2010
    As in you cannot physically connect it? It should have come with a cable, probably USB, that you can plug into your computer. Also, make sure the drivers have been installed.
  • 617 Answers
I don't believe the tape part is compatible,it's in Analog not Digital.If you record to the memory stick that is digital and computer compatible.The video cassette will need converting into digital just as you would a VHS tape.You will need to purchase a converter or take the tape to a photo shop.They can convert it to a readable disk for you.Sorry,that's a really nice camcorder.But it's not compatible with a computer as is.
Posted on Jan 04, 2010
How can I transfer my recordings
Hi Greg, you need to provide more information, for instance , from what medium to what medium, (media types.) Please add the detail and resubmit
Jun 02, 2015 | Canon XH-A1 High Definition Mini DV...
Canon Xh a1 won't turn on, HDV and Power are blinking
It could be the blown fuse that located on the main circuit board.
Dec 18, 2014 | Canon XH A1 Mini DV Digital Camcorder
Canon xha1 won't turn on and hdv light keeps blinking
Same Problem, same day, have you found any solution?, i stored the camera for abut 6 months following the Manual specifications, keeping the camera away from humidity, dust, even light and unmounted batteries, but it didn't turned on when i really needed it, I tried changing batteries, power source, i've already checked the lock/standby and the main dial, anyone help please!
Jun 17, 2011 | Canon XH A1 Mini DV Digital Camcorder
MacBook Pro/FCE does not capture video from XH A1 any more. Message: Cannot initialize HDV deck-please connect camera.
Play the tape on the camera before connecting it to the mac and loading up the software. You could always see if iMovie is giving the same error message too... This usually fixes the problem for me and usually arises when switching between SD and HD on the camera.
Dec 22, 2009 | Canon XH A1 Mini DV Digital Camcorder
Please help me...When I connect my canon xh a1 to FCP 6.0 it says Unable to Initialize Capture Device Device is not connected or the capture preset is not setup correctly. You may still log offline...
Try playing the tape before connecting up to the mac with the firewire and before loading FCP up. Usually fixes it for me when using either iMovie to import or FCP
Jul 16, 2009 | Canon XH A1 Mini DV Digital Camcorder
How download issue!
I you want to read the card only with out the cable you need to get one of thease. This is just one I picked. Just do a search for cadr reader on the site. If you need to get the soft ware juse download it from the canon web site.
http://shop4.frys.com/product/5727912?site=sr:SEARCH:MAIN_RSLT_PG
Good Luck
Jan 22, 2009 | Canon XH A1 Mini DV Digital Camcorder
Getting poor quality uploads to my pc from my Canon XH-A1
You need to upgrade you ingest system. Windows Media Player(and your system card) probably can't handle the load. Try "Scenalyzer" it's economical, versatile and stable( http://scenalyzer.com/).
Jan 14, 2009 | Canon XH A1 Mini DV Digital Camcorder
When I capture HDV footage from my XH A1 to Final Cut Pro 5, the footage is out of sync. The video is playing like in 110%, or something like that. The original footage is in 24f mode. It doesnt happen in...
Make sure the properties for the project you start after the ingest match the frame rate you used to record. Reads like 29.97 speed setting looking at images recorded at 24f.
Jan 01, 2009 | Canon XH A1 Mini DV Digital Camcorder
Get Final Cut Pro 5.04 to communicate with my XH A1
Many HDV cameras and decks are able to play and record DV as well as the higher-resolution HDV format. Additionally, many of these HDV devices will attempt to automatically change their settings to match the format of the tape that it's playing. Here are some tips for using these types of devices with Final Cut Pro / Final Cut Express.
Tip: Make explicit settings on your HDV device. Instead of using an "Auto" setting, make your own settings on your HDV device to keep the communication going between it and Final Cut Pro / Final Cut Express. This also helps Final Cut Pro / Final Cut Express keep things running smoothly with HDV devices that handle both DV-NTSC and DV-PAL.
For example, say you're using an HDV deck to capture footage from a tape that was recorded as DV-NTSC. Before capturing in Final Cut Pro / Final Cut Express, make sure that you set the deck to DV mode specifically—don't rely on Auto mode. With some devices, you may need to disconnect it from FireWire to change the mode.
For a common capture workflow, this sequence of steps can provide the best results:
  1. Quit Final Cut Pro / Final Cut Express if it's open.
  2. Insert your tape into your HDV deck or camcorder.
  3. Use the device's menus to set it to match the format that's recorded on the tape.
  4. Connect your HDV device to your computer with a FireWire cable.
  5. Open Final Cut Pro / Final Cut Express.
  6. Choose an Easy Setup for DV or HDV (whichever matches the format recorded on your tape).
  7. Proceed to Log and Capture.
Tip: Quit Final Cut Pro / Final Cut Express before changing modes. It's generally a good idea to quit Final Cut Pro / Final Cut Express before you change the mode on your device from DV to HDV, or from HDV to DV, and then re-open the application again.
Tip: Use an Easy Setup to play back non-default HDV format footage on your HDV device. You can use Final Cut Pro / Final Cut Express to make your HDV device play back footage in its non-default HDV format. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as 1080i50. Or perhaps you have a 1808i50 HDV device and you want to play back footage that was recorded as 1080i60. To do this, follow these steps:
  1. Connect your camera to your computer.
  2. In Final Cut Pro / Final Cut Express, choose an HDV preset Easy Setup that matches the format of the tape's footage (you don't need to restart Final Cut Pro / Final Cut Express).
  3. Your device's LCD display should automatically display a switch to 60 or 50, indicating the type of media that's being played.
Playing back non-default DV format footage on your HDV device You can also use your HDV device to play back footage in its non-default DV format too. For example, maybe you have a 1080i60 HDV device and want to play back footage that was recorded as DV-PAL. Or maybe you have a 1080i50 HDV device and want to play back footage that was recorded as DV-NTSC. If so, follow these steps:
  1. Make sure that your device is in DV/DVCAM mode.
  2. Put your device into Play/Pause mode, then open the Log and Capture window in Final Cut Pro / Final Cut Express.
  3. Make sure that your device's LCD (or other readout screen) displays the same format as your tape or Final Cut Pro / Final Cut Express will misinterpret what type of device you have.
Tip: Avoid recording both HDV and DV formats on the same tape. Use separate tapes whenever you want to record in a different format. If you need to record over existing footage in a different format (for example, you have a tape with DV-PAL on it, but you want to record over it with HDV 1080i50), it's a good idea to black and code the tape, or completely record over the old footage with contiguous recording in the new format. If the tape contains even a second of, say, DV in the middle of an HDV tape (or vice versa), it could cause unexpected results later when you try to capture video from that tape.
For more information, see HD and Broadcast Formats and the Final Cut Pro / Final Cut Express User Manual, available under the Final Cut Pro / Final Cut Express Help menu
Dec 04, 2007 | Canon XH A1 Mini DV Digital Camcorder
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
