Question about LG WM2277HSW XL Front Load Stackable Washing Machine
LG tromm WM2277HS - loud vibrating problems
LG tromm WM2277HS front load washer vibrates very loudly during the spinning process. I double checked and found the washer was level. It started doing this a month ago. The washer is about 2 and a half yrs old. Any help would be greatl appreciated! thanks in advance.
  • edfox1998 Apr 16, 2009
    Washing Machine Vibrates loudly during spin cycle
SOURCE: vibration during spin cycle
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 13, 2008
SOURCE: kenmore washer model 41740042990
there is a concrete block (a counter weight) inside the unit. maybe it fell off the bracket. remove back panel (after unplugging) and check it.
Posted on Feb 05, 2008
SOURCE: vibration
use motorcycle strapdowns and large eye hooks
Posted on Sep 05, 2008
praky16
  • 744 Answers
SOURCE: lg tromm wm2277hs stops when it gets to the rinse
hi
  • If there is no water in the unit:
    1. Make sure that both valves at the water source(s) are turned on all the way.
    2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
    3. Check inlet valve operation
  • If there is water in the unit:
    1. Check Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
  • Check there is not a siphon problem
  • Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Check pressure switch operation
  • Check flow meter operation
Posted on Jul 24, 2009
  • 497 Answers
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Posted on Sep 15, 2009
Loud noise when spinning ? bearing gone machine .
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 25, 2011 | LG WM2301HW Front Load Washer
Loud knocking during spinning
heatman101
Aug 21, 2011 | GE WSXH208A Front Load Washer
Maytag Neptune - MAH5500BWW makes loud, loud noise during spin cycle. What parts are necessary to repair the unit? I assume there are bearings and seals needed. Thank you.
heatman101
May 26, 2011 | Maytag Neptune MAH5500B Front Load Washer
Very loud noise during spin cycle
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Jan 27, 2011 | Whirlpool Duet GHW9150P Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
Washer makes loud noise during spin cycle
heatman101
Aug 31, 2010 | Kenmore 4292x Front Load Washer
Very loud vibration during the spin cycle, how do you control this only 2 wks old
check the inside of the machine (have to unsrew the top of the machine)each corner should have a rod wich the drum balances on perhaps one has come loose or a spring is gone. possible lol i hope this is some help to you
Apr 26, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Feb 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Vibration during spin cycle
Dec 13, 2008 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
252 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
