Question about Maytag MER5775Q Electric Kitchen Range
Timer on the Maytag range keeps beeping and shows F1
We have to unplug the range before the entire house goes crazy.  You can cancel it but it comes back on on its own
  • 318 Answers
The F1 code is usually an internal failure of the control board. it may have a failed oven sensor that is causing the control to think it is over temp and the sensor is alot cheaper to replace first, usually about 50 bucks. to replace the control board will usually cost about 150-200 bucks. but try the sensor first.
Posted on Dec 28, 2008
Please advise on how to reset the F1 code? The continuious beeping is driving me crazy .. Thank you
It sounds like you need a new heat sensor installed. It will run you about $175.00 +/-
Jun 01, 2009 | Kenmore Kitchen Ranges
Timer tone goes off with F1 display
Hi arl3933,
The "F1" error code description is a System Watchdog Circuit. Please press "CANCEL", if beeping continues after 30 seconds, please check the main control board(ERC). Here are basic test that will help you to determine if the ERC or touchpad is defective.
1. Unplug the range power cord or turn the power off to the range at the circuit breaker.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back.
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Hope it helps.
Thank you for using FixYa.
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag electric range shows F1 error message and beeps what does this mean? and now it permanently shows this message and not thee closk
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 03, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Electric stove fault code F 1-2 when using the oven(s)
F1-2 Runaway Cook Lower Oven Check the sensor 1050-1100
ohms, wiring, control
F1-8 Keypad Shorted Replace Control
Here is the link for you to print off the service manual on your range
http://www.servicematters.com/maytag_library/docs/16010107.pdf
PLZ Rate my service
Feb 17, 2008 | Maytag MER6772 Gemini Electric Kitchen...
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
F1 shows on display and beeps constantly.
The F1 error code relates to a defective touch pad or clock (ERC). It seems that the reason for it in your case is some liquid entered the unit during its cleaning. Unplug the power cable and wait for few hours, In case it will not help, apart the ERC unit and and dry the touch pad and the clock. Good luck!
Apr 04, 2007 | Jenn-Air JES9800AAS Electric Kitchen Range
Error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Jun 08, 2006 | Maytag MER5530 Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
101 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
