Question about Sharp Televison & Video
QUESTION!!! Not a problem!!!Question: When I turn my LCD LC60C52U on in the upper right corner a small green square appears and in it is Cable Analog 3 Audio: Mono. I have Service Electric Cqable and I know they broadcast in digital and stero, Why does the TV keep indicating it's receiving in analog and mono? If this is the case?? Sam
How do i plug in my19v4fcf wierd plug
Posted on Apr 26, 2009
  • 916 Answers
It may be a setting on the TV some stations only broadcast in Mono. But most likely check your tv settings and make sure it is in stereo mode.
Posted on Dec 22, 2008
HP Pavilion dv6 7040 TX Laptop screen on right hand upper corner turns dim and after some time becomes uniform
Being a led screen maybe one or more of them have gone bad
Or if you are lucky just a faulty lcd ribbon cable
Mar 25, 2014 | Computers & Internet
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
Samsung syncmaster 931a... connected to computer
Hi, its unlikely to be the cable. Most likely cause of this is a faulty inverter board. If you are lucky it will only be 1 or 2 blown capacitors which are easily identifiable and replaceable once you have got inside it. it could however, be almost any of the components on the inverter board or even a failed backlight but this will require further testing and a knowledge of LCD monitor workings.
Nov 03, 2009 | Computers & Internet
Cable/Analog Icon on screen
Usually the DISPLAY Button on your TV remote will toggle through several different functions: 1 sec, 5 sec, Always on..... Press button until display on TV is off. Or see if there is an ON SCREEN DISPLAY portion in the TV Menu and turn it to off if you have not checked that already.
Apr 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
An annoying "2" in the upper rigth corner of my TV.
I had the same problem. I manually rebooted the box and the 2 was gone. Hope this helps.
Dec 21, 2008 | Samsung LN32A550 32 in. LCD TV
Big grey/black spot
Is it a fuzzy spot or an actual hard edged black spot?LCD televisions can have a loss of pixel display- most very small. Was the TV hit with something or dropped against something (the screen)?
OR Try this first:
Black box appears on the screen
• Closed-captioning might be on. Check the Analog or Digital Caption option in the Setup menu.
Please let me know if your problem is solved. Thank You.
Aug 15, 2008 | RCA LCDX2722W 27 in. Television
Analog
Seeing the word "analog" on your screen means the monitor has recognized video input on the vga "analog" input connection.
Most computers output "analog" vga (15 pin) which must be converted to digital for a flat panel monitor to display the image.
Many LCDs now have both analog and digital inputs.
Mike
May 01, 2008 | ViewSonic VP191b 19" LCD Monitor
Green box keeps popping up in upper right corner
You should be watching your dvd's on an input and not on tv analog 3. Every time the tv "senses" a signal change in the audio that screen will pop up. Connect the DVD player to the tv by using either the red, white and yellow (composite) connections or using the green, blue, red, white and red (component). Once you are on an actual input that box will stop popping up.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Meaning of Green square icon on upper left corner
I have the same camera. The green square icon appears while the camera is saving the picture. From your description, I think you were using "Shot Confirmation", and this setting was cleared during the repairs. Have you tried going into the Setup mode (on the dial) and reselecting Shot Confirmation? (p. 143 in the manual)
Jan 17, 2007 | Nikon Coolpix 5400 Digital Camera
Televison & Video Logo
105 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
