Question about Zanussi IZ12 Front Load Washer
Water in Drum...No Longer Working
A pipe burst in my basement and filled the drum with about 4 inches of water.  The machine makes a noise when I attempt to start it, but it won't turn on.  How expensive is this going to be?  Is there anything short of a new dryer or big bucks to fix it that I can do?
  • Zanussi Master
  • 3,463 Answers
I suspect that the motor has seized with the ingress of water, and will probably require new one fitting
Likely to be expensive. You should not really be trying to use it if it has had water in it until you have it checked for electrical safety.
Does not your household insurance cover you for burst water pipes and the resulting damage caused by this event?
Plz rate my solution.
Thanks.
Posted on Dec 22, 2008
The machine is displaying ELoOOOO and making a noise. How do I clear/fix this? Cheers, Phil
its clearly trying to empty the drum of water maybe there's a blockage problem in the outlet water hose as the machine cant advance till the water censor switch tells the programmer that the machine is ready to fill by being empty first please blow into the water outlet pipe to perhaps clear the blockage eric
Dec 21, 2017 | Washing Machines
Machine is filling with water but the drum wont turn or spin
MOST LIKELY THE MOTOR IS SHOT OR THE BELT AROUND THE DRUM CAME OFF THE DRUM
Feb 06, 2013 | Washing Machines
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
My Indesit WE165 fills up with water
there is a little hose that runs from the back of the pump
up to a pressure switch that contols water level in drum
I had a problem similar to this and found hose had split making
the drum overfill, replaced hose cured problem
Apr 19, 2009 | Indesit W 123 Front Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Banging pipes when washing machine fills
it is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
Sep 17, 2008 | LG Washing Machines
Water will not shut off
Usually there is a thin pipe from the bottom of the drum to a pressure switch at the top of the machine. As the machine fills the water goes up the pipe from the drum and increases the air pressure in the pipe to a point where it's enough to switch the switch inside. If the pipe gets blocked with washing powder it will not switch off and the machine will keep filling. The pipe is connected to a sort of flat round box with a few wires on it. If you can take the top or back off the machine you should see it and be able to clean the pipe out yourself.
Jun 26, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Water just keeps running
check the drain hose to make sure that it is not stuck too far down in the house stand pipe it only need to be in the pipe 5-6 inches
May 12, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Zanussi IZ12 Front Load Washer Logo
50 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
