Apple mail gmail shuts down when down loading attachments report two apple still a problem i have macbook leapord 2gigs ram 60g on hard drive
    Master:
  • Computers & ... Master
  • 168 Answers
YOu may check the gmail status Gmail Running Status Up or Down Down Reporter and fix the problem now.
Posted on Mar 07, 2017
  • 741 Answers
This is not your fault nor you're computers fault. Gmail (I use it myself) is sponsored by Google. Try www.google.com and there is a place you can report your problem too.
Posted on Dec 23, 2008
2009 MacBook is locking up after OS loads. My 8yr old might have dropped but will not admit. Could the HD but shoot from a fall? This came on suddenly. HD is not full
if you think this is what happend then yes somthing may of come lose inside.
to check if its the hdd try doing a restore it might be somthing missing when it trys to bootup.,if the hdd had shut down you would not get it to were it is now,
Apr 01, 2015 | Apple MacBook Pro Summer 2009 Core 2 Duo...
Password for my macboor air
Sadly enough there's no other way to get back into your installation. If you need to backup your data, either boot into windows with the bootcamp drivers installed or take out your hard drive and plug it into a pc. Once you have a backup completely shut down your macbook and plug it in. Press and hold CMD+R and turn the Macbook on, it should now boot into recovery, where you can format and reinstall OS X.
Mar 18, 2014 | Apple 13.3 MacBook Air 1.6GHz 2GB RAM...
My apple macbook air will not reboot. it turns on but does not reboot completely then it shuts down and tries to reboot again and again. apple logo appears and the spinning icon rotates but never goes...
It may be a possibility that the hard drive has gone bad or a connection to the hard drive. The spinning wheel and apple signify the kernel boot, or in other words, the process in which the machine finds the hd and os/software.. you need to bring your machine into an authorized repair center to have a system diagnosis to verify that no other parts of the machine are bad. That model is notorious for having bad hd's.
Nov 24, 2010 | Apple MacBook Air
How do I fix my macbook the start up screen with the apple wont stop loading
Take your RAM chips out and re-insert. Sometimes they get jostled out of position. If that don't help, then replace the RAM chips with new ones that you know work. Also, the RAM your using may not be enough memory. Then the next culprit would be a failing hard drive, so replace it and re-install the OS. The next expensive culprit would be the logic board has given up the ghost.
Sep 04, 2010 | Apple MacBook Mac Notebook
Boots up but shuts down before opening ?
The software on the hard drive is not loading correctly and is giving the command to shut down. Reinstalling the OS should clear that up.
May 26, 2010 | Apple MacBook Mac Notebook
My macbook recently got a new hard drive, and now it will not recognize my iTouch.
sounds like while the hard drive was being replaced the usb outlets were tampered with. bring it into apple to replace your hard drive
Apr 07, 2010 | Apple 13.3 MacBook Intel Core 2 Duo 2.2GHz...
Mac keeps shutting off by itself
Hello, this is called a "hard reboot" and can occur because of faulty RAM memory (have you added extra ram recently?).
It can also come form a dead hard drive, or a dead fan, causing overheat
Apr 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
A Frozen 2008 Macbook Air
try You can force a frozen MacBook Air — or any current Mac laptop — to shut down and restart without removing its battery. You just hold down the power button for a few seconds until the machine shuts off, then wait a few seconds, then turn it on again.
Mar 08, 2009 | Apple 13.3 MacBook Air 1.8GHz 2GB RAM 80GB...
Mac notebook
The most likely cause is a bad hard drive or a corrupted file. Start up the computer in safe mode. (Hold down the shift key while starting) that will force the macbook to run extended tests on the startup drive. If it finds any errors it may be able to correct them. If that fails use the startup disk that came with your laptop and start from it (hold down the C key during start up) that will allow you to use disc utility to try repairing your hard drive.
If the macbook fails to boot to the DVD or into safe mode. Try reseating the RAM chips. Hope some of that helps.
Aug 06, 2008 | Apple MacBook PC Notebook
Macbook start-up
http://www.retrodata.co.uk/notice_apple_seagate_drives.php
May 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
113 people viewed this question
Alun Cox
David Payne
David Payne
