Question about HP Color LaserJet 2600n Printer
Misprint notice -
Says the "printed page" has been incorrectly placed on the paper.
To continue, press the Select button at the device.
I did this and nothing changed.
The landscape comes half off the page and the rest blank
    Guru:
  • HP Master
  • 829 Answers
This could be because you are taking printout in potrait, select landscape and do the same.
Posted on Dec 22, 2008
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
Error Number : 1003 No paper. Load the paper in the cassette correctly and press the OK button on the printer. Plain paper of A4, Letter, B5, and A5 sizes will be fed from the cassette because...
Another possible reason for getting this error is a dusty printer. I don't dust very often so dust piles on everything, including my printer. My daughter wanted me to print something for her and the first page went through just fine. But the second never started and I got error 1003. I had plenty of paper loaded and my settings for the size of paper were correct. I dusted out my printer and everything else printed just fine. My theory is the top paper had dust bunnies on it that were pulled into the printer when it pulled the first page in. Maybe the dust got caught on a sensor that told the computer there wasn't any paper. Regardless of what happened, a quick cleaning fixed the problem. I just wanted to throw in my two cents for anyone out there that may have a dusty printer and run into this error.
Sep 08, 2011 | Canon PIXMA iP1500 InkJet Photo Printer
NO BLACK PRINTING on my Canon mx310 printer. in case of misprint please align head
Follow the steps below to align the printer
  1. Press and release the On/Off button located in the upper left-hand corner of the operations panel to turn the power on. Open the sheet feed cover on the rear paper tray. Pull out the paper support until it stops at its fully extended position.
  2. 2 Open the paper output tray. Flip the paper output tray extension out. Load a sheet of letter-sized plain paper in the rear tray. Slide the paper guide to the right until it is snug against the left side of the paper.
  3. 3 Press and release the Home button on the control panel. The Home screen will be displayed on the LCD panel. Press the Up or Down Arrow button to scroll through the menu. Select the Settings option. Press and release the OK button. Select the Maintenance option. Press and release the OK button. Select the Auto head align option. Press and release the OK button.
  4. 4 Wait for the confirmation screen to be displayed on the LCD panel. Select the Yes option. Press and release the OK button. Wait for the printer to automatically align the print head and print the alignment sheet. This process should take approximately 4 minutes.
Regards,
Shawn
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
My canon pixma 480 has thin horizontal lines. tried cleaning and deep cleaning where is the head alignment tool?
The instructions as copied from the Pixma 480 "onscreen manual." (Only the text -- not the images -- could be pasted into the solution. Hope you can follow the text.) Steve G.
Prepare 2 sheets of A4 or Letter-sized plain paper
1. Make sure that the power is turned on, and load 2 sheets of A4 or Letter-sized plain paper in the Rear Tray.
2. Open the Paper Output Tray gently, and open the Output Tray Extension.
3. Print the print head alignment pattern.
- Press the Menu button.
- Select Maintenance, and press the OK button.
- Select Print head alignment, and press the OK button.
Note: To print the current head position adjustment values, select Head alignment print in the Maintenance menu and press the OK button. See Selecting Menus on the Top Menu Screen.)
- Select Yes, and press the OK button to print alignment sheet.
- Check the pattern is printed correctly, select Yes and press OK button.
- Confirm the displayed message and press the OK button.
The Print head alignment screen appears.
4. Adjust the print head position.
- Check the printed patterns, and use the (Left) or (Right) button to select the number of the pattern that has the least noticeable streaks for column A.
Note: If it is difficult to select the best pattern, select the pattern that has the least noticeable white streaks.
(A) Less noticeable vertical white streaks
(B) Noticeable vertical white streaks
(C) Less noticeable horizontal white streaks
(D) Noticeable horizontal white streaks
- Repeat the same procedure to input the pattern number for each column from B to L, then press the OK button.
- Select Yes to continue printing, and press the OK button.
- The second page of print head alignment sheet will be printed.
- Confirm the message for print head alignment, and press the OK button.
- Check the printed patterns and use the (Left) or (Right) button to input the number of the pattern that has the least noticeable horizontal streaks for column M.
- Repeat the same procedure to input the pattern number for each column from N to R, and press the OK button.
Jan 12, 2011 | Canon Pixma MP480 All-In-One InkJet...
Printer hp laserjet 2420 error 41.2 dan error 68.2
The 41.2 printer error means beam detect misprint error. To resolve this try the ff:
  1. Press c00099410.jpg (Select). The page containing the error automatically reprints if jam recovery is enabled.
  2. Turn the printer power off, and then turn on the printer power.
  3. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 ,
The error 68 regardless what number follows after it is about Storage Error. One or more printer settings saved to storage device x are invalid and have been reset to factor defaults. To resolve this:
Press c00099410.jpg (Select) to clear the error and continue printing. Printing can continue, but unexpected behavior might be experienced because an error occurred in permanent storage.
Hope this helps.
Thank you for using FixYa.
Nov 26, 2010 | HP LaserJet 2420 Printer
SAYS GOT PAPER JAM
With the message should say where is the paper jam. If you can not find this information you can try:
  1. Pull the paper tray, specified on the Display Screen, completely out of the printer.
  2. Remove any jammed paper from inside the tray slots. Make sure there are no pieces of paper jammed in the tray slots.
  3. Make sure to use paper within specifications and that the paper is loaded correctly in the tray. See the Related Items below for additional information.
    NOTE: When the paper edge guides are correctly adjusted, there may be a small space between the paper and the guides.
  4. Adjust the length and width tray guides:
    1. Length guides: Press the sides of the guide, and then slide the guide until the arrow on the guide point to the appropriate paper size labeled on the bottom of the tray. When properly positioned, the guide will click into place.
    2. Width guides: Slide the width guides until the arrows on the guides point to the appropriate paper size labeled on the bottom of the tray. When properly positioned, the guides click into place.
  5. Remove the top sheet of paper from the tray.
  6. Re-install the paper tray in the printer, and make sure it is completely closed.
  7. Make sure the pick truck and ****** roller set is installed and seated properly. Clean or replace both of these roller mechanisms, if necessary. See the Related Items below.
If none of this clean the JAM message you might want to power OFF/ON the device.
If that also does not clear the message you can go a bit deeper and reset the device. THIS WILL CLEAR ALL YOUR SETTINGS, might inclusive clean TCP/IP settings. So I advise you to print configuration report first then.
If you wish to do this here are the steps. NOTE: Resetting NVRAM returns stored parameters in the image processor board NVRAM to their factory default values. The print count and the Adobe firmware serial number are not affected by this reset. You can reset the PostScript NVRAM using the Service Tools menu or the Service Diagnostics menu.
To reset the printers NVRAM using the Service Tools menu:
NOTE: Print a Configuration Page before resetting NVRAM. See the Related Items below for additional information.
  1. Press and hold the [Up] arrow button on the Control Panel, and then press the [OK] button. This will automatically display the Service Tools menu on the Display Screen.
  2. Press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Reset NVRAM], and then press the [OK] button.
To reset the printers NVRAM using the Control Panel:
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Service Tools], and then press the [OK] button.
  4. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main screen.
NOTE: The Configuration Page can be printed to help solve printing problems and obtain the best results from the printer. Access this page from the printer's Control Panel.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Printer Setup] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Configuration Page], and then press the [OK] button to print.
  3. Press the [Up] or [Down] arrow button to select [Exit], and then press the [OK] button to return to the Main Menu.
Aug 27, 2010 | Xerox Phaser 8560DN Laser Printer
Picture crops strange
HP Photosmart 7550 printers
  1. Ensure that the memory card has been removed from the memory card slot.
  2. Make sure plain white paper is loaded into the In Tray.
  3. On the control panel, press the Menu button. Using the directional arrows, select Clean Cartridges .
  4. Press the OK button.
  5. After confirming that paper is loaded into the paper tray, press the OK button.
  6. Once the level one clean cartridge test page has printed, examine the printed page. If the print is not clear and/or there are lines in the color bars, continue to Step 7. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  7. Press OK to print the second level clean cartridge page.
  8. Once the second level clean cartridges test page has printed, examine the printed page. If the print is not clear and/or there are line in the color bars, continue to Step 9. If the print quality is acceptable and there are no flaws with the color bar, select No using the directional arrows, then press OK .
  9. Press OK to print the third level clean cartridge page.
Dec 08, 2008 | HP PhotoSmart 7550 InkJet Printer
Would not print C5280 Flashing Failure Print Cartridge allignment
Solution
  1. Load unused plain white letter or A4 paper into the input tray.
  2. Press the Setup button.
  3. Press the down arrow button to select Tools and then press OK .
  4. Press the down arrow to select Align Printer and then press OK . The unit prints a test page, aligns the printhead, and calibrates the printer.
  5. After the success or failure message displays, click OK to continue. Recycle or discard the alignment page.
Cause An incorrect type of paper is loaded in the input tray. If you have color or photo paper loaded in the input tray when you align the printer, the alignment might fail.
Nov 04, 2008 | HP Office Equipment & Supplies
Sqeaky paper feed
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=238800&prodTypeId=18972&objectID=c00001617 the HP site for your printer Over time, particles of toner and paper accumulate inside the HP LaserJet 2300 series printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Clean the paper path and print-cartridge areas every time that the print cartridge is changed or whenever print-quality problems occur. As much as possible, keep the printer from dust and debris. Cleaning the outsideback to top of page Clean the outside of the printer with a cloth that has been dampened with water. NOTE: Do not use ammonia-based cleaners on or around the printer. Cleaning the paper path and print-cartridge areasback to top of page Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems. Use the following steps to clean the paper path and print-cartridge areas: 1. Turn the printer off and unplug the power cord. 2. Open the top cover. Figure 1: Top cover opened example 3. Remove the print cartridge. Figure 2: Print cartridge removed example CAUTION: To prevent damage to the print cartridge, do not expose it to light for more than a few minutes.Be careful not to touch the transfer roller (the black, rubber roller located underneath the print cartridge). Skin oils on the roller can cause print-quality problems. 4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge cavity. Make sure not to touch the transfer roller with fingers, as the oil can contaminate the roller, resulting in print quality defects. Figure 3: Paper path area and print cartridge cavity example 5. Reinstall the print cartridge and close the top cover. Figure 4: Print cartridge reinstalled example NOTE: If the print cartridge is difficult to reinstall, make sure that the registration plate has been flipped back down into position and that the print cartridge is pushed firmly in place. 6. Plug in the power cable and turn on the printer. Cleaning the fuserback to top of page Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of print jobs. To ensure optimum print quality, HP recommends using the cleaning page every time that the print cartridge is replaced or on an automatic pre-established interval. The cleaning procedure takes about 2.5 minutes to complete. A message (either CREATING CLEANING PAGE or CLEANING) appears on the printer control panel display while the cleaning is taking place. NOTE: Use plain paper to print the cleaning page. Please note that this is a two-step process. First print out the cleaning page using the following directions, then follow the directions on the cleaning page itself to reinsert it back into the printer to perform the cleaning. Use the following steps to run the cleaning page: 1. If the printer model includes a duplexer, open the rear output bin. 2. Press example(Select button) to open the menus. 3. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE, and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY, and then press example (Select button). 5. Use example (Up button) or example (Down button) to scroll to CREATE CLEANING PAGE, and then press example (Select button). 6. Perform the following to complete the cleaning process. 1. Remove all paper from Tray 1. 2. Use example (Up button) or example (Down button) to scroll to CONFIGURE DEVICE and then press example (Select button). 3. Use example (Up button) or example (Down button) to scroll to PRINT QUALITY and then press example (Select button). 4. Use example (Up button) or example (Down button) to scroll to PROCESS CLEANING PAGE and then press example (Select button). 5. Load the cleaning page created in step 5 above into Tray 1 with the print side down and the arrow towards the printer. 7. If the printer model includes a duplexer, close the rear output bin. Let me know if that helped. Good luck, Tim
Mar 14, 2007 | HP LaserJet 2300 Printer
HP Color LaserJet 2600n Printer Logo
369 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
