Question about ViewSonic VX924 19" LCD Monitor
Monitor Blinking My LCD monitor has been blinking (2 sec blank - 1 sec on) for a couple of days now. I connected the monitor onto another computer and it still blinked. I also fixed another monitor to the same computer and it worked fine. I changed the power code and switched off speakers and no difference. Any suggestion fix would be appreciated.
  • 1 more comment
  • Sunil Pathirana Apr 08, 2007
    It's actually a ViewSonic VE710s, and is 1.5 yrs old.
  • anchukwi Aug 04, 2008
    My computer monitor blinks with grey and black lines. It is so regular and disruptive that I cannot use it. Please, help with troubleshooting it.
    Austin
  • Anonymous Aug 22, 2008
    when i open the monitor of my computer it has a sound and then blink....
    my computer is always use for games and search and chatting...
    i am afraid that when i continue to used it can caused a trouble...
    could u help me...
Hello guys
I had the same problem. My LCD ViewSonic VX 924 has been blinking
For repar it i changed the following capacitors : 100uF/400v
330uF/25v and 330uF/35v
if that always flickers you can also change the two 470uF/25v capacitors
The link for a pic Alime and Capacitors
http://img25.imageshack.us/my.php?image=alimefsp0351pi01.jpg
DO NOT TOUCH NOTHING D'OTHERS ANS DISCONNECT ELECTRICITY CABLE BEFORE PROCEEDING
Posted on Mar 06, 2009
The first thing to check is that your graphic card is not sending an image with an incorrect resolution or refresh rate to the monitor (1280x1024 at 75Hz max). You should also make sure the power cord is fine. And eventually try the monitor on another computer.
We had 4 of theses monitor viewsonic monitors having these symptoms at work. The first 3 were replaced by since they were still under warranty (3 year!).
It was indeed a problem with the power supply unit. I dismantled the monitor and had a close look at the PSU (which is also the inverter in that model). Pair of 680uF 16V capacitors at the top were bumpy and one had its plastic casing melted. Changed these two and the monitor stopped blinking!!!
Although it stopped blinking the back-lighting would turn itself off 3 seconds after it was turned on. (I could still see the picture on the screen but without the back-lighting).
To fix that, I reduced the brightness of the monitor halfway. And it's now working fine! I suppose the inverter board can't handle the full brightness anymore.
Hope this helps.
Posted on Jan 25, 2008
  • ViewSonic Master
  • 12,061 Answers
This is a Common problem MOST if NOT ALL, problems like this with this type of fault it is invairably a problem with the Power Supply, in the PSU Electrolytic capacitors dry out and often cause this type of exact problem... It is a relitively simple fix, by replacing the caps with new ones... Any good shop should be able to fix for a modest fee.. OR if ya know anyone handy with a soldering iron maybe they could do it for you there are generally about 4 - 6 to replace... in the PS section, just do them all to be safe
Posted on Jul 30, 2007
Hi All
It seems to be a common problem for LCD ViewSonic VX 924 at least. Mine was blinking when plugged it in to digital cable and did not work at all with analog one.
There is a powerful transistor at the PSU which overheated so exessive heat damaged capacitors nearby.
In my case I have just replaced the two 470uF/25v capacitors and 330uF/25v
Posted on Apr 29, 2009
  • 31 Answers
I agree with Silverdragon in that it's usually the cheap capacitors used in many monitors. I have fixed several monitors by replacing the capacitors in the power circuit. You can read about it and see pictures here: Fix an LCD Monitor
Posted on Oct 18, 2010
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
My LCD monitor blinks after switch on the power. display appear and go blank again appears and go blank and again and again.......................
1. Make sure the computer is switched on.
2. Check to see if the monitor cable has bent pins.
3. Make sure the signal cable is properly connected to your computer.
4. The energy saving feature may be activated.
Thanks for choosing FixYa
Oct 11, 2010 | Philips 190B7CB LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor Blinking
HI SrFixer -
Since you were able to attach another monitor to the computer and it worked, that would indicate that the problem is not a computer problem but a problem with either the monitor or the monitor cable (data). Try another monitor cable on the monitor that didn't work and see if that works. If it still does not work, then I am afraid that your monitor has gone bad and needs replacing.
Hope that helps
Michael
Nov 28, 2008 | Computers & Internet
Acer Al 1714. LED light is blinking (orange not green).Monitor black.
Well, suddenly it worked again. But I waited the whole day >.>
Aug 22, 2008 | Acer AL1714 17" LCD Monitor
Blinking monitor
Ok well I think ya have a Power Supply problem with ya Monitor...
But to be sure try it on another PC see if problem follows, if NOT then maybe ya Video card is starting to bug out?
But I punt for the PSU in the Monitor.. As an aside check the Pins inside the Monitor connector see they are all OK
Jun 14, 2008 | ViewSonic VX924 19" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
AL2216W LCD monitor "Power status Green blinking" & No display.
LOOKS LIKE A BURN SOLDER !! , open the monitor , check the PC BOARD around the transformer area , look for burn spot or cold solder , RE solder it , try again , hope this helps please rate solution and thanks AJ
May 06, 2008 | Acer AL2216W LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
25,379 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
