Question about Rollei Prego dp5200 Digital Camera
Rollei prego Lense assembly stuck in out position and will not return into camera case, Mechanical failure,remaining camera functions inactive. I have removed the battery serveral times and given the unit a sharp tap, but to no avail, please advise. H
  • Anonymous Mar 18, 2008
    my camera is a rollei prego da7325 and is experiencing a similar problem with the lense stuck out and will not function at all.prior to the problem happening,the camera took one picture and then a message saying replace batteries came up. i replaced the batteries (which were fine) but to no avail as the camera failed to turn on the functions;it did however project the lense outwards and that was it.tried removing the batteries for a while but no result.
2 Suggested Answers
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
  • 102366 Answers
SOURCE: How to format sd card for rollei prego da5? I put
The DA5 works with SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You have to use SD cards, 2GB and smaller.
Posted on Sep 29, 2011
How to format sd card for rollei prego da5? I put a new 4GB sd card in my rollei, camera says: "Your card has to be formatted. Click ok." When I click ok, it says: "Card cannot be...
Sep 29, 2011 | Rollei Prego DA5 Digital Camera
I am looking for the manual for this camera,either original or download
You can download a scan of the manual from
http://www.butkus.org/chinon/rollei/rollei_prego_90af/rollei_prego_90af.htm
Jan 29, 2011 | Rollei Prego 90 35mm Point and Shoot...
Where can I get a scan disk 512 mb?
I believe that you are referring to a SD card. You can buy them here:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007962%20600006188&IsNodeId=1&bop=And&Order=PRICE&PageSize=20
(Note: 1GB = 1000MB)
If this helps please vote for my solution.
Dec 13, 2010 | Rollei Prego DP5300 Digital Camera
I HAVE LOOKED EVERYWHERE FOR A BATTERY FOR MY ADVENT DIGITAL CAMERA (ADV 1182E) BUT NO LUCK. CAN ANYONE TELL ME IF ANOTHER BATTERY CAN BE USED??.
Three years ago a guest on FixYa wrote this:
quote
Here's a list of cameras that use the same battery.
ADVENT:
ADV1172E
BENQ: BENQ:
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
KONICA MINOLTA: KONICA MINOLTA:
DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
PREMIER: PREMIER:
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
ROLLEI: ROLLEI:
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
End quote
Nov 27, 2010 | Cameras
My camera lens won't open and is stuck in one place.
(I'm not sure this is a 'Solution' or not, so please don't 'ding' me if you find this of no use)
I had a similar problem with a Fuji E550. The power button on the camera was pressed while it was INSIDE the carrying case and the lense jammed agaist the inside of the case. It would not move and the camera would not function until this was cleared.
DO THIS AT YOUR OWN RISK!
A camera 'expert' suggested that I twist the lense to it's fully extended position while the camera is turned off. I must say it did grind a bit while I did this and left me feeling a bit queezy.
But, once I turned the camera on the lense returned to it's normal 'start' position, closed once I powered off the camera, and has worked ever since.
If you aren't comfortable doing this (and I wouldn't blame you if that were the case) you'll need to take it into a camera shop for repair.
Good Luck.
May 22, 2009 | Polaroid i532 Digital Camera
Mount for rollei pqs lense to nikon dslr body
The rollei 600x mount lenses communicate to the camera via the gold plated contacts. In addition, the 350mm PQS is a medium format lens. There is currently no such adapter.
Apr 06, 2009 | Rollei 350mm f/5.6 Zeiss PQS Lens
I have a Rollei prego 130WA film camera as of 01/08. Switch on procedure has failed whereby a clicking sound is made and vibrations are felt through the casing. Function panel on the rear initiates, but no...
Assumin this has not been caused by damage - the camera should be replaced under warranty.
sent it back to vendor or contact customer support at Rollie
Aug 20, 2008 | Cameras
Format error
my camera shows format error
Jul 05, 2008 | Cameras
Advent camera battery charger
ADVENT:
ADV1172E
BENQ: BENQ:
PREMIER: PREMIER:
ROLLEI: ROLLEI:
Hopefully this will broaden your options when searching for a compatable charger.
Mar 23, 2008 | Cameras
Rollei Prego dp5200 Digital Camera Logo
Top Rollei Cameras Experts
Harrie
james laughton
james laughton
Tony Parsons
Tony Parsons
Are you a Rollei Camera Expert? Answer questions, earn points and help others
