Question about Sharp AL 1215 Black and White Copier
Sf-1118 please help me i want to know how to adjust sharp copier sf-1118 needs to adjust rgst(registration).all my copying images are far from leading edges. thanks alot
  • Anonymous Apr 23, 2009
    we have badquality on copy of original and erro message of indicator onthe  panel
  • Ashish Sood May 11, 2010
    yes it is there when mannual feeding is there
  • 163 Answers
Plese write c interrup 0 interrupt 50 copy key 1 copy key,select c and then adjust registration by changing figures
Posted on Sep 23, 2007
  • 883 Answers
Does the same occur when the manual paper feed path is used?
Posted on May 20, 2007
Sharp sf 1118 shows error code of red image inform of a person beside or close to the green digital counter . Please I need.a solution thank you.
it means that the machine need service/ to change the P.M kit on the machine and clear the error code by entering the simulation on the machnie
Oct 14, 2015 | Sharp Office Equipment & Supplies
Registration problem konina 7065
timing adjustment, perform the following.
1. Access the 36 mode (power the machine ON while holding down on the 4 and 7 keys.
2. Press [2] Image adjustment.
3. Press [3] Timing adjustment
4. Press [3] Lead edge timing adjustment
5. Press [Copy Screen]
6. Load 11x17 paper into tray 1, make a copy of the pyramid chart, and check the output.
Standard value: 3mm max.
7. If the lead edge original amount is different to the standard value, press the C button while pressing the P button.
8. Enter a value from the numeric keys on the screen, and press (SET) key.
Setting range: 0 (small) to 99 (large)
1 Step = 0.064mm.
9. Repeat steps 5 to 8 until the lead edge original erasure amount becomes the standard value.
10. Press the [PREVIOUS SCREEN) key to return to the Timing Adjustment Menu Screen.
11. Power the machine OFF/ON to exit the 36 mode.
PLEASE NOT THIS IS A LEADEDGE ADJUSTMENT.THE REIGIST ADJUST IS THE SAME STEPS JUST CHOOSE REGISTRATION OPTION ,AND MAKE SURE TO FOLOW PROPER DIRECTION.
Jul 02, 2009 | Sharp AR C250A Color Copier
Diagnostic codes for Sharp SF-2014 copier
Sharp SF 2030 On power need enter operator key code, need reset.Please help.
Jan 06, 2009 | Sharp Office Equipment & Supplies
SHARP SF2014
Try using heavier paper say 80gsm. Or adjust light exposure if possible.
Oct 29, 2008 | Sharp SF 2020 Copier
Sharp SF-1118 copying machine H 4 Error
Open right side door and check for a jam in the fusing unit (the one that is normally hot). Remove jam carefully. Hit P * C * and enter 14. Push the start button like you are making a copy. Machine should reboot and code should not return. if it does, you may have a dirty themistor, or blown lamp.
Jan 01, 2008 | Sharp AR-207 Copier
Error CH uppon power up...copy lamp comes on scaner moves forward 2...3 inches shakes and machine stops...
OK, CH normally means the one of the covers(front or side panels) is open or the developer unit is unplugged try these to see if that fixes the problem. p.s When the covers are closed a small tab on the covers triger a interlock switch or optical switch. Hope this helps
Aug 22, 2007 | Sharp AR-160 Copier
Sharp AL 1215 Black and White Copier Logo
267 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
