Question about Sony KP-57WV600 57" Rear Projection HDTV-Ready Television
The gel in a projection tv has leaked out
The gel that is in the lens has leak out
Http://cableorganizer.com/mg-chemicals/projection-tube-coolant.html pls chk this sit u will get the details of the coolant.....
Posted on Jan 05, 2009
I have a buzzing noise from inside the TV
immediately check your plyback connectors and wirings.there is a leak in your high voltage and this is dangerous so be carefull..to locate the leak,open the back cover of your tv enough to see the inside components...specially the plyback transformer..power on the tv and look for the arking of the high voltage.it is like a lightning strong light that produces the buzzing sound..once you see the source of the leak..power of the the tv.use a silicon adhesives (silicon gel) a silicon that is use by the glass intallers to bond the mirrors use on the display show room..apply the silicon on the leak area .apply a large amount of it to be sure there is no leak...once it is bonded you can power the tv right away...to check whether the leak is cured...
good luck hope this helps you..
please rate my help tnx.
May 29, 2010 | Samsung HCL4715W 47" Rear Projection...
Oil from lences leaked out and got on al the chips and wires what do i do
This is projection tv coolant. You need to clean all region on board where the liquid leaked and remove the tube who leak and flush the coolant. after good cleaning of tube and lens, reassable them and refill with new coolant.
Apr 22, 2010 | Sony KP-53HS30 53" Rear Projection...
Under the lens is a leaking. and the color is messed up.
The silicone liquid coolant is leaking, you can try looking here:
www.mcmelectronics.com
Nov 15, 2009 | Philips 60PP9202 60" Rear Projection...
TV will not show a pic just sound but when movie playing can view
  1. Sounds like you have a video prioblem. But before you go spending money on a service call. Unplug the TV and take the back off. Next with a bright flashlight check the boards in the set for coolant fluid that has leaked onto the board. The fluid will be clear and kind of have a gel like feel to it. If you see it your set is unfortunately toast because parts are NLA (no longer available) Good Luck
Aug 23, 2009 | Mitsubishi VS-60603 60" Rear Projection...
I need to know where i can get cooling gel for my projection tv
You can order Projection fluid at Electronix Parts 1-800-223-3205.
Dec 22, 2008 | Sony KP-57WV600 57" Rear Projection...
Is the service tech lieing
Well, it could be true that that is your problem, but see what kind of estimate they will give you for fixing it, a big tv like this will cost quite a bit to fix. You could attempt to fix it yourself but I don't want to be the one to tell you how as I don't want to be the reason if you should get hurt from working on this. If it costs too much to fix, then projection tvs are not for your parents and you should try something cheaper and get an lcd tv. Circuit city has a 32 in for under $500. Basically if the gel leaked all over the tv, it may cost quite a bit and this isn't fun for them or for you. If you have any other questions, let me know
Oct 22, 2008 | Televison & Video
Picture tube gel leak
The best way to clean it is to remove the board completely and wipe up as much as possible, then use qtips with rubbing alcohol to remove the left over residule the alcohol will dry quickly, but still allow the board to air day a full 24 hrs before reinstalling it in the TV.
Aug 16, 2008 | Televison & Video
Projection tv problem lens
Good Day;
Hey, Thomas;
As you stated very few companies provide the rubber seals.
The best thing to use is silicon, place it where the seal is. Remove the CRT from the unit, drain the fluid, clean area, replace with Ethylene Glycol. Make sure you let the silicon to set up, about 24 hours.
Good Luck, Day, Big Irish.
ps call if problem at mmrkcar@yahoo.com.
Jun 14, 2008 | Sony KP-51HW40 51" Rear Projection...
Dead tV
That cooling fluid leaking on to the main boards is corrosive. A lot of alignment stuff for pulling tube and fixing leak. best done by repair tech. $300.00
Apr 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Sony KP-57WV600 57" Rear Projection HDTV-Ready Television Logo
124 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
